8340-F120-Z7CB-B5H0-756 数据手册
Magnetic and Hydraulic-Magnetic Circuit Breaker 8340-F...
Description
Single and multipole magnetic circuit breakers with trip-free mechanism
and toggle actuation. A choice of fast magnetic only or hydraulically
delayed switching characteristics (S-type MO or HM CBE to EN 60934)
ensures suitability for a wide range of applications. Industry standard
dimensions and panel mounting. Options include auxiliary changeover
contacts, or relay trip function. Low temperature sensitivity at rated load.
Approved to CBE standard EN 60934 (IEC 60934).
Typical applications
Control equipment, communications systems, transportation, power
supplies.
8340-F...
1-pole
2-pole
Standard current ratings and typical internal resistance values
Technical data
Current
rating (A)
Curves and internal resistance per pole (Ω)
F1
F2
K1, M1, T1, K2, M2, T2
0.02
1493
953
2669
2457
0.05
276
152
452
376
0.1
58
37
100
94
0.25
8.2
6.0
15.5
14.7
0.5
2.3
1.47
3.9
3.2
0.75
0.98
0.63
1.65
1.56
1
0.58
0.35
0.95
0.90
2
0.145
0.096
0.26
0.20
2.5
0.096
0.061
0.15
0.15
3
0.065
0.048
0.10
0.10
5
0.025
< 0.02
0.042
0.040
6
< 0.02
< 0.02
0.029
0.028
8
< 0.02
< 0.02
< 0.02
< 0.02
10
< 0.02
< 0.02
< 0.02
< 0.02
12
< 0.02
< 0.02
< 0.02
< 0.02
15
< 0.02
< 0.02
< 0.02
< 0.02
16
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
25
< 0.02
< 0.02
< 0.02
< 0.02
30
< 0.02
< 0.02
< 0.02
< 0.02
40
≤ 0.01
≤ 0.01
50
≤ 0.01
≤ 0.01
For further details please see chapter: Technical Information
Voltage rating
3 AC 415 V; AC 240 V, 50/60 Hz; DC 80 V
(higher DC ratings to special order)
Current ratings
0.02...50 A 1-pole (40 + 50 A DC only)
0.02...30 A multipole
Auxiliary circuit
6 A, AC 240 V;
3 A, DC 28 V
1 A, DC 65 V;
0.5 A, DC 80 V
Typical life
3 AC 415 V, AC 240 V:
0.02...30 A
6,000 operations at 1 x IN, inductive
10,000 operations at 1 x IN, resistive
DC 80 V: 0.02...25 A
0.02...30 A
40 + 50 A
6,000 operations at 1 x IN, resistive
Ambient temperature
-40...+85 °C (-40...+185 °F)
Insulation co-ordination
rated impulse
pollution
(IEC 60664 and 60664A)
withstand voltage
degree
2.5 kV
2
reinforced insulation in operating area
Dielectric strength
(IEC 60664 and 60664A) test voltage
operating area
AC 3,000 V
pole to pole (2- and 3-pole) AC 1,500 V
main to auxiliary circuit AC 3,000 V
switching to trip circuit AC 1,500 V (version -X)
Insulation resistance
> 100 MΩ (DC 500 V)
1,200 A at AC – 2,000 A at DC
Interrupting capacity Icn
0.02...20 A
25...30 A
IN
(UL 1077)
AC:
1-pole AC 250 V/3,500A AC 250 V/3,500A
DC:
(UL 489A)
Degree of protection
(IEC 60529/DIN 40050)
Vibration
with toggle down:
Corrosion
Humidity
Mass
Issue C
96 hours at 5 % salt mist
to IEC 60068-2-11, test Ka
240 hours at 95 % RH
to IEC 60068-2-78, test Cab
approx. 65 g per pole
2-pole
3-pole
1-pole
2-pole
AC 250 V/3,500A
3AC 250V/3,500A
0.02...50 A
0.02...30 A
AC 250 V/5,000A
3AC250V/5,000A
DC 80 V/3,500 A
DC 80 V/3500 A
2,000 A
operating area IP40
terminal area IP00
10 g (57-2000Hz) ± 0.76 mm (10-57 Hz)
at 0.9 x IN
directions 1, 2, 3, 4, 5: 10 g (57-2000 Hz) at 1 x IN.
with curves F1, F2 in all planes:
10 g (57-2000 Hz) ± 0.76 mm (10-57 Hz)
at 0.8 x IN,
to IEC 60068-2-6, test Fc
10 frequency cycles/axis
Shock
100 g (11 ms) at 1 x IN, directions 1,2,3,4,5
100 g (11 ms) at 0.8 x IN, direction 6.
with curves F1, F2:
to IEC 60068-2-27, test Ea
www.e-t-a.com
3 - 19
3
Ordering information
Type No.
8340 magnetic circuit breaker with toggle actuator
Mounting
F flange mounting
Configuration
1 with mounting nuts 6-32 UNC
4 with mounting nuts M3
9 snap-in frame
Number of poles
0 single pole, switch only
1 single pole protected
magnetic,
2 two pole protected
hydraulic-magnetic
3 three pole protected
4 four pole protected
5 two pole, protected on one pole only
6 four pole, protected on poles 1, 2 and 3 only
7 two pole, switch only
Panel hardware
0 without panel hardware
Terminal design (main contact)
K3 screw terminals with metric thread, M4
(recommended for IN ≥ 20 A)
K4 screw terminals with metric thread, M5 (IN = 40 A)
P1 blade terminals
X1 blade terminals with separate switching
and relay circuit
Characteristic curves
Characteristic curve F, instantaneous trip:
F1 DC
trip at 1.01-1.5 x IN
F2 AC 60/50Hz trip at 1.01-1.5 x IN
Characteristic curve K, short delay:
K1 DC
trip time at 2 x IN: 0.16-1.2 s
K2 AC 60/50Hz trip time at 2 x IN: 0.13-1.6 s
Characteristic curve M, medium delay:
M1 DC
trip time at 2 x IN: 0.6-7.5 s
M2 AC 60/50Hz trip time at 2 x IN: 2.2-20 s
Without characteristic curve:
Q0
switch only
Characteristic curve T, long delay:
T1 DC
trip time at 2 x IN: 10-70 s
T2 AC 60/50Hz trip time at 2 x IN: 15-150 s
Relay trip X:
X1 voltage trip at DC, instantaneous trip
X2 voltage trip at AC, instantaneous trip
Other curves to special order (e.g. pulse delayed,
high inrush currents, capacitive loads)
Actuator colour / design
A black, long toggle
B white, long toggle
C blue, long toggle
K black, short toggle
L white, short toggle
M blue, short toggle
Z black, without toggle, with slot
other colours to special order
Marking on actuator
0 without marking
L I-O; ON-OFF
N I-O; ON-OFF (IN on housing top)
Auxiliary contacts
H0 without auxiliary contacts
H1 with auxiliary contacts, gold-flushed
H2 auxiliary contacts, gold-flushed
on one pole only (multipole)
H3 auxiliary contacts, gold-flushed
on poles 1 and 3 (3 and 4-pole)
Auxiliary contact function
4 1 change over contact
Auxiliary contact
terminal design
2 blade terminal 2.8-0.5 mm
Current ratings
0.02...50 A
8340 - F 1 1 0 - P1 M1 - A L H1 4 2 - 30 A
Voltage rating
only curves X1, X2
DC 5, 8, 12, 24 V
AC 110, 220, 240 V
Options
H
higher flammability
rating
Approvals upon
request
Approval (optional)
U UL 489 A
8340 - F
3 - 20
1
1
ordering example
Homologations
Authority
Voltage ratings
VDE (EN 60934) 3 AC 415 V; AC 240 V; DC 80 V
DC 80 V
UL 1077, CSA
DC 80 V
3 AC 250 V; AC 250 V
UL 489 A
DC 80 V
QPL (Sweden)
AC 240 V; DC 50 V
CCC
DC 80 V
Current ratings
0.02...30 A 1 to 6-pole
0.02...50 A 1-pole
0.02...50 A 1 to 6-pole
0.05...30 A 1, 2-pole
1...30 A
0.02...30 A
0.02...50 A 1, 2-pole
Internal connection diagrams
1-pole protected
magnetically
and relay circuit
11(C)
line 1
line 1
line 1
4
3
12(NC) 14(NO)
I>
I>
1-pole protected
hydraulic-magnetic
line 1
2 load
2 load
2 load
multipole
11(C)
11(C)
line 1
unit 1
12(NC) 14(NO)
12(NC) 14(NO)
I>
I>
2 load
2
11(C)
1
unit 2
12(NC) 14(NO)
I>
2 load
unit 3
unit 4
3
8340 - F 1 1 0 - P1 M1 - A L H1 4 2 - 30 A - ... - ... - U
www.e-t-a.com
Issue C
Dimensions
Flange mounting
Configuration: F1/F4
Actuator: long toggle
ON
OFF
41.2
1.62
41.2
1.62
OFF
30°
3
.118
5.5
.217
3.3
.130
ON
30°
14.4
.567
30°
30°
17.5
.689
Configuration: F9
1
4
1
2
3
50.8
2.00
4
19
.748
Ø15
.591
4.3
.169
26.7
1.05
42.2
1.66
27.4
1.08
Actuator: short toggle
ON
8.6
.339
30°
2
3
50.8
2.00
66
2.60
19
.748
30°
5.5
.217
OFF
30°
30°
5.6
.220
3.3
.130
3
OFF
ON
1
4
2
3
Actuator: without toggle, with slot
30° 30°
30° 30°
OFF
OFF
ON
3.3
.130
ON
4
2
3
5.3
.208
1
number of poles: 1-4
pole
1
2
3
4
Applicable for nominal dimensions without direct tolerance indication:
DIN ISO 286 ± IT13
pole:
1
2
3
4
Cut-out dimensions
max. panel thickness: 2± 0.5 mm
19
.748
Cut-out dimensions
max. panel thickness: 3 mm
mounting thread M3
or 6-32 UNC-2B
mounting depth
max. 4.5 mm/.177 in.
tightening torque max. 0.33 Nm
19.2±0.2
.756±.008
DIN ISO 286 ± IT13
38.1±0.12
1.50±.005
57.15±0.12
2.25±.005
Issue C
1.66±.004
Ø16±0.12
.630±.004
42.2±0.1
26.7±0.1
1.05±.004
.138±.004 (M3)
+.004
.157-.006 (6-32UNC)
19.05±0.12
.750±.005
55.4±0.2
2.18±.008
3.5±0.1 (M3)
+0.1
4 -0.15 (6-32UNC)
76.8±0.2
3.02±.008
57.6±0.2
2.27±.008
38.4±0.2
1.51±.008
This is a metric design and millimeter dimensions take precedence ( mm )
inch
www.e-t-a.com
3 - 21
Terminal design / Dimensions
K3/4 screw terminals
tightening torque max. 1.2 Nm
Actuator configuration
K3 screw terminals M4
K4 screw terminals M5
Actuator long
1
1
4
3
Actuator design
number of poles: 1 - 4
Configuration: F1 / F4
2
OFF
.382
OFF
16 A
6
.236
9.4
.370
38.8
1.53
OFF
OFF
16 A
OFF
OFF
OFF
16 A
OFF
OFF
OFF
OFF
16 A
Actuator short
P1 blade terminals
OFF
OFF
16 A
16 A
1
4
3
2
9.6
.378
Configuration: F9
6
.236
3
38.8
1.53
Actuator long
blade terminals
DIN 46244-A6.3-0.8
OFF
X1 blade terminals
with separate switching and relay circuit
16 A
4
3
OFF
16 A
16 A
OFF
OFF
OFF
OFF
OFF
OFF
16 A
16 A
16 A
16 A
16 A
16 A
16 A
number of poles: 1
Configuration: F1 / F4 / F9
2
9.6
.378
1
OFF
Actuator: Z (black, without toggle, with slot)
9.8
.386
29.3
1.15
38.8
1.53
6
.236
blade terminals
DIN 46244-A6.3-0.8
OFF
OFF
16 A
16 A
Auxiliary contacts
version H (standard, asymmetrical gold-flushed terminals,
silver contacts
Installation drawing
1
2
10.2
.401
5.1
.200
blow out outlet CBE
Terminal design P
1
.039
12
14.5
.571
5
.197
17.9
.705
14
1
.039
Terminal design K
11
blade terminals
DIN 46244-A2.8-0.5
terminal
area
mounting area
4
.157
2
.079
8
.315
42
1.65
29
1.14
30
1.18
7
.276
1
.039
2
.079
7
.276
30
1.18
operating area
(reinforced insulation)
8
.315
42
1.65
29
1.14
blow out area
(minuaturable on request)
Trip time values indicated for front mounting on a vertical
even surface
inch
3 - 22
www.e-t-a.com
Issue C
Typical time/current characteristics at 23 °C / +73.4 °F
Curve F1 (instantaneous) for DC
Curve M0 (medium delay) for AC/DC
1000
1000
Trip time in seconds
10000
10000
100
10
1
0.1
0.01
100
10
1
0.1
0.01
0.001
0.001
2
3
4
6
5
7
8
… times rated current
9
10
11
12
Curve F2 (instantaneous) for AC 50/60 Hz
1000
10000
2
3
4
6
8
5
7
9
10
11
12
Curve M1 (medium delay) for DC
10000
100
10
1
0.1
0.01
100
3
10
1
0.1
0.01
0.001
0.001
2
3
4
8
5
7
6
9
10
11
10000
10000
1000
1000
100
10
1
0.1
4
5
6
7
8
8
5
7
6
9
10
11
12
9
10
11
12
0.1
0.01
3
4
1
0.001
2
3
10
0.001
1
2
100
0.01
Curve M2 (medium delay) for AC 50/60 Hz
Curve K1 (short delay) for DC
1
9
10
11
12
9
10
11
12
2
3
4
6
8
5
7
Curve K2 (short delay) for AC 50/60 Hz
10000
1000
100
10
1
0.1
0.01
0.001
2
3
4
6
5
7
8
N.B. All curves will only be maintained if the escutcheon is mounted on a vertical surface.
Other characteristic curves to special order (e. g. with impulse delay for inrush peaks).
Issue C
www.e-t-a.com
3 - 23
Accessories
Curve T1 (long delay) for DC
Splash cover with mounting plate and screws
10000
1 pole
Y 303 565 01
2
.079
16.7
.657
mounting holes
42.4±0.15
1.670±.006
100
10
0.1
1
.039
18
.708
0.01
Ø1
7.1
[.6
Ø
73
Ø4 3.5
[.1 [.13
57 8]
]- -M
632 3
UN
C
15.7
.618
1
30.7
1.20
1000
0.001
2
3
4
6
8
5
7
9
10
11
12
2 pole
X 211 118 01
Curve T2 (long delay) for AC 50/60 Hz
42.4±0.15
1.670±.006
2
.079
10000
Ø
3
[.1 .5 [.1
mounting holes
57
] - 38] 640.15±0.15
32 M3
40
UN
1.58±.006
1.57
C
Ø4
19
.748
1
19.2±0.1
.756±.004
6
10
15.7
Ø2
5
Ø.9 .15 ±0.15 .618
90 ±.0
1.49
100
2.2
.087
0.1
3 pole
X 211 119 01
1
2
3
4
6
5
7
8
9
10
11
mounting holes
59.15±0.15
2.33±.006
2
.079
12
15
0.
19
.748
2.2
.087
57
2.24
5±
.1 .006
25 0±
Ø .99
Ø
37.8±0.15
1.49±.006
Shock directions / Mounting attitudes
Toggle guard
Y 307 250 01
40
1.57
34
21
3.3
12
M3 NC
8] - 32 U
[.13 ] - 6.5
Ø3 [.157
Ø4
15.7
.618
42.4±0.15
1.670±.006
0.001
1.6 x 45°
.063x45°
0.01
37.9
1.49
Ø 3.5
Ø .138
17.7
.697
3
1000
5
6
50.5
1.99
inch
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
3 - 24
www.e-t-a.com
Issue C
