EM221102V
EM221102V
    EATON(伊顿)
    插件
EM221102V 数据手册
Plug & Header EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Pluggable Terminal Blocks EM2211 Series EuroMag Terminal Blocks Header with Flanges (Mates with EM2423, EM2443 Series); 3.81 Centers EM221106H SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.15” (3.81mm) Consult factory for 0.30" (7.62mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold to Length Agency Information: File E62622; CE Certified EM221109V Dimensions - mm (in) Compliance References Edge Connectors, One-Sided Boards HORIZONTAL Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 14 18.02 21.83 25.64 29.45 33.26 37.07 40.88 44.69 48.50 52.31 56.12 63.74 L 9.20 [.362] 2.60 [.102] 2.60 [.102] 6.90 [.272] 3.50 [.138] (2) M2.6 7.10 [.280] 0.80 [.031] 3.81 [.150] 1.20 [.047] Ø1.30 [Ø.051] 1.20 [.047] To convert to inches, divide by 25.4 PCB Hole Layout 9.20 [.362] 3.81 [.150] VERTICAL L Ø Ø Part Numbering System En Mn 2n 2n 1n 1 nn n Series n # of Poles Orientation 02 to 14 H - horizontal V - vertical PCB Hole Layout Mating Plugs: EM2423 pg. 82 EM2443 pg. 83 For additional product information, visit www.eaton.com/connectors 84
EM221102V 价格&库存
很抱歉,暂时无法提供与“EM221102V”相匹配的价格&库存,您可以联系我们找货
