EM359303VC
EM359303VC
    EATON(伊顿)
    插件,P=3.81mm
EM359303VC 数据手册
EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single Row Series EM3593 EuroMag Terminal Blocks Header (Mates with EM3553, EM3543, and EM3583 Series); 3.81 Centers EM359312HC EM359308VC EuroMag Series Plug & Header SPECIFICATIONS Ratings: 10A, 300V Center Spacing: 0.15" (3.81mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass, Tin-Plated Operating Temperature: 105°C (221°F) max., –40°C (–40°F) min. Recommended PCB Hole Diameters: 0.51" (1.30mm) Construction: Mold-to-length. Agency Information: File E62622; CE Certified Dimensions - mm (in) L (mm) Poles L (mm) HORIZONTAL 02 03 04 05 06 07 8.23 12.04 15.85 19.66 23.47 27.28 Edge Connectors, One-Sided Boards Poles 08 09 10 11 12 31.09 34.90 38.71 42.52 46.33 L 9.20 (0.062) 6.90 (0.272) 3.00 (0.100) * Dimensions in inches. To convert to millimeters, multiply by 25.4. 1.21 (0.062) 2.21 (0.087) 3.81 (0.150) Ø1.30 (Ø 0.051) 1.20 (0.047) 9.20 (0.062) PCB Hole Layout 3.81 (0.150) VERTICAL 3.60 (0.198) 2.93 (0.110) Part Numbering System En Mn 3n 5n 9n 3 n Series nn # of Positions 02 to 12 L 9.20 (0.062) 6.90 (0.272) 2.2 (0.087) 3.81 (0.150) Inches (Millimeters) n Orientation H - Horizontal V - Vertical C n Side Base C - Closed Mating Plugs: EM3553 pg. 78 EM3543 pg. 79 EM3583 pg. 80 For additional product information, visit www.eaton.com/connectors 81 Compliance References 1.80 (0.031)
EM359303VC 价格&库存
很抱歉,暂时无法提供与“EM359303VC”相匹配的价格&库存,您可以联系我们找货
EM359303VC
  • 70+7.25461
  • 100+5.53768
库存:300
EM359303VC
    • 1+7.94880
    • 200+3.07800
    • 500+2.97000
    • 1000+2.91600
