8340-G231-K4E1-A4H0-50A 数据手册
Magnetic and Hydraulic-Magnetic Circuit Breaker 8340-G2...
Description
Single and two pole magnetic circuit breakers with trip-free
mechanism and push/pull on/off manual actuation. A choice of fast
magnetic only or hydraulically delayed switching characteristics (Stype MO or HM CBE to EN 60934) ensures suitability for a wide range
of applications. Convenient threadneck panel or plug-in mounting,
and with a white push button indicator band showing clearly the
tripped/off position. Available with auxiliary contacts (1 x N/O, 1 x
N/C) for status signalling.
Approved to CBE standard EN 60934 (IEC 60934).
Typical application
Control equipment, communications systems, power semiconductors.
Standard current ratings and typical internal resistance values
Current rating (A)
Internal resistance (Ω) per pole
-F4/-F5
0.02
0.05
0.08
0.1
0.15
0.2
0.3
0.5
0.75
1
1.25
1.5
1.75
2
2.5
3
4
5
6
8
10
12
15
16
30
40
50
* 50 % ON duty / 60 min.
2043
583
94
35.6
22.9
9.89
5.02
2.44
0.789
0.392
0.246
0.145
0.10
0.083
0.059
0.048
0.028
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02*
< 0.02*
-E1/H1/R1
2 896
531
202
129
57.3
30.5
13.9
4.50
2.19
1.10
0.695
0.487
0.355
0.295
0.174
0.121
0.0729
0.0437
0.0329
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
-E2/H2/R2
2 660
542
199
127
55.7
30.5
13.7
4.42
1.82
1.08
0.686
0.472
0.337
0.291
0.168
0.118
0.0687
0.0449
0.0323
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
< 0.02
1-pole
8340-G2...
1
2-pole
Technical data
For further details please see: http://www.e-t-a.de/ti_e
Voltage rating
3 AC 415 V; AC 240 V, 50/60 Hz; DC 80 V
(higher DC voltages to special order)
Current ratings
0.02...50 A DC
0.02...30 A AC
Auxiliary circuit
1 A, AC 240 V/DC 65 V
0.5 A, DC 80 V
Typical life
3 AC 415 V, AC 240 V:
0.02...30 A 6,000 operations at 1 x IN, inductive
10,000 operations at 1 x IN, resistive
DC 80 V: 0.02...25 A 6,000 operations at 1 x IN, inductive
0.02...30 A 10,000 operations at 1 x IN, resistive
40 + 50 A
5,000 operations at 1 x IN, resistive
Ambient temperature
-40...+85 °C (-40...+185 °F)
Insulation co-ordination
rated impulse
pollution
(IEC 60664 and 60664A) withstand voltage
degree
2.5 kV
2
reinforced insulation in operating area
Dielectric strength
operating area
test voltage AC 3,000 V
Line to Load
test voltage AC 1,500 V
pole to pole (2- and 3-pole) test voltage AC 1,500 V
main to auxiliary circuit test voltage AC 1,500 V
switching to trip circuit test voltage AC 1,500 V
(version -X)
Insulation resistance
> 100 MΩ (DC 500 V)
Interrupting capacity
6 x IN at AC;
IEC 60934 - test sequence E 4 x IN at DC
(UL 1077)
AC:
DC:
IN
1-pole
2-pole
1-pole
2-pole
0.02...20 A
AC 250 V/3,500A
AC 250 V/3,500A
0.02...50 A
0.02...30 A
25...30 A
AC 250 V/3,500A
AC 250 V/5,000A
DC 80 V/3,500 A
DC 80 V/3500 A
Degree of protection
operating area IP40
(IEC 60529/DIN 40050)
terminal area IP00
Vibration
with button down:
10 g (57-2000 Hz), ± 0.76 mm (10-57 Hz)
at 0.9 x IN
other mounting planes: 10 g (57-2000 Hz) at IN
to IEC 60068-2-6, test Fc
10 frequency cycles/axis
Shock
100 g (11 ms) at 1 x IN, directions 1,2,3,4,5
100 g (11 ms) at 0.8 x IN, direction 6
to IEC 60068-2-27, test Ea
Corrosion
96 hours at 5 % salt mist,
to IEC 60068-2-11, test Ka
Humidity
240 hours at 95 % RH
to IEC 60068-2-78, test Cab
Mass
approx. 70 g per pole
www.e-t-a.de
1
ON
OFF
ø10.6
.417
ø8.4
.331
black
white
57.5
2.26
1.5
.059
3
.118
12.5
.492
18.2
.717
6.5
.256
tightening torque max. 4 Nm
M12x1
1 11 23 2(i) 24 12 2(k)
location pin for 3mm (.118 in.)
hole dia.
ø3+0,2
.118+.008
2.7
.106
9.5±0.2
.374±.008
9.5
.374
0.8
.031
.492+.008
Cut-out dimensions:
ø12.5+0,2
current rating in A
SW14
.551
5
Type No.
8340 Magnetic push/pull circuit breaker
Mounting
G threadneck panel mounting
Threadneck design
2 M12x1
Number of poles (main current paths)
1 single pole, protected
2 two pole, protected
3 three pole, protected
Panel hardware
0 without panel hardware
1 with hex nut M12x1 and washer 12/15
Terminal design
P1 blade terminals A6.3-0.8 mm (QC.250) (≤ 35 A)
K4 screw terminals M5 recommended for IN > 20 A
R1 round connectors ø6
Characteristic curve *)
Characteristic curve, instantaneous:
F4 DC
F5 AC 50/60 Hz
Short delay:
E1 DC
E2 AC 50/60 Hz
Medium delay:
H1 DC
H2 AC 50/60 Hz
Long delay:
R1 DC
R2 AC 50/60 Hz
Actuator colour
A black with white trip indicator band
Actuator marking
4 rated current
legible with location pin above (standard)
7 rated current
legible with location pin below
Auxiliary contacts
H0 without auxiliary contacts
H1 with auxiliary contacts
H2 with auxiliary contacts
on pole 1 only (2 pole types)
Auxiliary contact function
1 one each N/O and N/C
3 1 pair N/C (11/12)
Auxiliary contact terminal design
Current ratings (optional)
0.02...50 A
1.5
.059
1
Dimensions (1-pole)
19
.748
Ordering information
50
1.97
19.4 *
.764
* min. 25 for use with splash cover
panel thickness
max. 3 mm (.118 in.)
3-pole
2-pole
57
2.24
38
1.50
unit 1
8340 - G 2 1 1 - P1 F4 - A 4 H1 1 1 - 8 A ordering example
Please be informed that we have minimum ordering quantities to be
observed.
unit 2
unit 1
*) Other
characteristic curves upon request (e.g. pulse delayed, for high
inrush currents or capacitive loads)
unit 3
unit 2
Cut-out dimensions:
min. 40
min. 1.57
2-pole
min. 60
min. 2.36
3-pole
panel thickness
This is a metric design and millimeter dimensions take precedence ( mm )
inch
2
www.e-t-a.de
2043
Terminal design
1 N/O, 1 N/C
Terminal design -P1
1
10
.394
1
4.6
.181
6x6.8
6x.268
45
1.77
blade terminal A6.3-0.8
(QC .250) to DIN 4624
45
1.77
6.8
.268
18.2
.716
1
1 N/C
Terminal design -K4
terminal M5
tightening torque
max.1.2 Nm
terminal M5
tightening torque
max.1.2 Nm
1
1
55.2
2.17
(QC .250) to DIN 46244
11.4
.449
Terminal design -R1
Internal connection diagrams
22.5
.886
19.5
.768
1-pole, protected magnetically
line 1
11
23
12
24
double pole
line 1
11
23
12
24
unit 1
34
1.34
6
.236
I>
2(k) load
I>
2(k) load
Installation drawings
1
1-pole, protected
hydraulic-magnetically
Terminal design -P
line 1
Terminal design -K
11
11
23
12
24
unit 2
23
I>
blow out outlet CBE
12
2(k)
24
I>
2(k) load
8
blow out area
29
1.14
10
.394
25
.984
.197
Terminal design -R
5
Standard
Rated voltage
Current ratings
VDE
IEC / EN
60934
UL
UL 1077
AC 240/415 V
AC 240 V
DC 80 V
AC 250 V
DC 80 V
DC 80 V
UL
UL 489A
DC 80 V
CSA
C22.2 No
235
AC 250 V
DC 80 V
0.02 A…30 A
0.02 A…30 A
0.02 A…50 A
0.02 A…30 A
0.02 A…50 A
100 A (2 poles in
parallel)
0.05 A…30 A
(1 + 2 pole)
0.02 A…30 A
0.02 A…50 A
CQC
GB 17701
5
.197
3.5
.138
Authority
5
.197
2
.079
.315
Approvals
terminal area
24
.945
mounting
area
operating area
(reinforced insulation)
29
1.14
QPL
Sweden
Defence
Material
Admin.
AC 240/415 V
AC 240 V
DC 80 V
DC 110 V
MIL-C-55629 AC 240 V
DC 50 V
AC 240 V
AC 240 / 415 V
0.02 A…30 A
0.02 A…30 A
0.02 A…50 A
0.02 A…50 A (8340-G)
1 A…30 A (8340-F410)
1 A…30 A (8340-410)
1 A…30 A (8340-F420)
1 A…30 A (8340-F430)
inch
2043
www.e-t-a.de
3
Typical time/current characteristics
Curve F4 for DC, magnetic (instantaneous)
(IN >20 A, 50% ON period, 60 min.) at +23 °C / +73.4 °F
10000
1000
1000
100
100
Trip time in second
10000
Trip time in second
1
Curve F5 for AC 50/60 Hz (instantaneous)
(IN > 20 A, 50 % ED/60 min.)
10
1
0,1
10
1
0,1
0,01
0,01
0,001
0,001
2
3
4
6
8
5
7
… times rated current
9
10
11
12
1000
100
100
Trip time in second
10000
Trip time in second
10000
10
1
0,1
4
8
6
5
7
9
10
11
12
9
10
11
12
9
10
11
12
9
10
11
12
1
0,1
0,01
0,001
0,001
2
3
4
5
6
7
8
9
10
11
12
Curve H1 for DC (medium delay)
1
2
3
4
5
6
7
8
Curve H2 (medium delay) for AC 50/60 Hz
10000
1000
1000
100
100
Trip time in second
10000
Trip time in second
3
10
0,01
10
1
0,1
10
1
0,1
0,01
0,01
0,001
0,001
1
4
3
6
8
5
7
9
10
11
12
Curve R1 for DC (long delay)
2
3
4
8
6
5
7
Curve R2 (long delay) for AC 50/60 Hz
10000
1000
1000
100
100
Trip time in second
10000
Trip time in second
2
Curve E2 (short delay) for AC 50/60 Hz
Curve E1 for DC (short delay)
10
1
0,1
0,01
10
1
0,1
0,01
0,001
0,001
1
1
2
3
4
6
8
5
7
9
10
11
12
www.e-t-a.de
1
2
3
4
6
8
5
7
2043
Accessories
Socket
18-P10-Si
Polarized socket with
adapter
18-P10-Si-20025
(for ratings >16 A please contact E-T-A)
6.5
.256
5
.197
1.4
.055
33.3
1.31
25.8
1.02
10
.394
19
.748
80
3.15
top-hat rail
EN 50022-35x7.5
adapter X 200 409 01
G profile
EN 50035-G32
polarization recess
SW14
.551
female connector
thickness
0.4 mm
.016 in.
1
Splash seal, black, hex nut and O ring (IP54)
X 200 802 01 (nickel plated hex nut M12x1,
splash seal black)
SW 17
Actuator extension
X 200 803 01 (black button)
10
.394
223
8.78
ø15
.591
M12x1
M4 copper rail
tin-plated
19
.748
2.5
.098
SW 17
washer
A4.3 DIN 125
nickel plated
2
.079
cylinder-head-screw
M4x4 ISO 1207 nickel-plated
7
.276
ø12+0.2
.472+.008
Accessories for push button
Splash cover with hex nut and O ring (IP66 and IP67)
X 200 801 08 (nickel plated hex nut M12x1,
splash cover transparent)
X 200 801 03 (black finish hex nut M12x1,
splash cover black)
Bus bar (10-way) (supplied as a complete package)
for type 18 socket
(for max. 100 A continuous load),
more positions available on request
X 211 158 01 with terminal
X 211 158 02 without terminal
Phoenix terminal AKG 35
cross section max 35 mm2 (AWG 2)
1.2±0.5
.047±.020
M12x1
blade terminal A6.3-0.8 (QC .250)
to DIN 46244 polarized to ensure
correct connection
10 mm
.394 in.
depth
45.8
1.80
4
.157
retaining clip
(accessory)
Spring washer
Y 300 118 03
Hex nut
Y 300 116 02
fusible link
(constriction 1 mm/.039 in. thick)
9
.354
5.4
.213
190
7.48
10
.394
3.5
.138
Insulated sleeving for bus bars
Y 303 824 11
Retaining clip for socket 18-P10-Si
Y 300 579 11
Shock directions / Mounting attitudes
1
55.5
2.19
15
.591
52
2.05
3
mounting dimensions
6
ø1
.039
8
.315
60
2.36
4
2
35
1.38
5
~70
~2.76
100 quick-connect tabs 6.3 (.250)
DIN 46247 tinned brass,
insulated
2(
k)
Connector bus link -P10
X 210 588 01/1.5 mm2 (AWG 16), brown (up to 13 A max. load)
X 210 588 02/2.5 mm2 (AWG 14), black (up to 20 A max. load)
X 210 588 03/2.5 mm2 (AWG 14), red (up to 20 A max. load)
X 210 588 04/2.5 mm2 (AWG 14), blue (up to 20 A max. load)
1
11 23 2(i) 24 12
inch
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
2043
www.e-t-a.de
5
1
6
www.e-t-a.de
2043
