8340-G231-P1H2-A4H221-10A
    E-T-A
8340-G231-P1H2-A4H221-10A 数据手册
Magnetic and Hydraulic-Magnetic Circuit Breaker 8340-G2... Description Single and two pole magnetic circuit breakers with trip-free mechanism and push/pull on/off manual actuation. A choice of fast magnetic only or hydraulically delayed switching characteristics (Stype MO or HM CBE to EN 60934) ensures suitability for a wide range of applications. Convenient threadneck panel or plug-in mounting, and with a white push button indicator band showing clearly the tripped/off position. Available with auxiliary contacts (1 x N/O, 1 x N/C) for status signalling. Approved to CBE standard EN 60934 (IEC 60934). Typical application Control equipment, communications systems, power semiconductors. Standard current ratings and typical internal resistance values Current rating (A) Internal resistance (Ω) per pole -F4/-F5 0.02 0.05 0.08 0.1 0.15 0.2 0.3 0.5 0.75 1 1.25 1.5 1.75 2 2.5 3 4 5 6 8 10 12 15 16 20 25 30 40 50 * 50 % ON duty / 60 min. 2043 583 94 35.6 22.9 9.89 5.02 2.44 0.789 0.392 0.246 0.145 0.10 0.083 0.059 0.048 0.028 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02* < 0.02* -E1/H1/R1 2 896 531 202 129 57.3 30.5 13.9 4.50 2.19 1.10 0.695 0.487 0.355 0.295 0.174 0.121 0.0729 0.0437 0.0329 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 -E2/H2/R2 2 660 542 199 127 55.7 30.5 13.7 4.42 1.82 1.08 0.686 0.472 0.337 0.291 0.168 0.118 0.0687 0.0449 0.0323 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 1-pole 8340-G2... 1 2-pole Technical data For further details please see: http://www.e-t-a.de/ti_e Voltage rating 3 AC 415 V; AC 240 V, 50/60 Hz; DC 80 V (higher DC voltages to special order) Current ratings 0.02...50 A DC 0.02...30 A AC Auxiliary circuit 1 A, AC 240 V/DC 65 V 0.5 A, DC 80 V Typical life 3 AC 415 V, AC 240 V: 0.02...30 A 6,000 operations at 1 x IN, inductive 10,000 operations at 1 x IN, resistive DC 80 V: 0.02...25 A 6,000 operations at 1 x IN, inductive 0.02...30 A 10,000 operations at 1 x IN, resistive 40 + 50 A 5,000 operations at 1 x IN, resistive Ambient temperature -40...+85 °C (-40...+185 °F) Insulation co-ordination rated impulse pollution (IEC 60664 and 60664A) withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) operating area test voltage AC 3,000 V Line to Load test voltage AC 1,500 V pole to pole (2- and 3-pole) test voltage AC 1,500 V main to auxiliary circuit test voltage AC 1,500 V switching to trip circuit test voltage AC 1,500 V (version -X) Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity 6 x IN at AC; IEC 60934 - test sequence E 4 x IN at DC Interrupting capacity (UL 1077) AC: DC: IN 1-pole 2-pole 1-pole 2-pole 0.02...20 A AC 250 V/3,500A AC 250 V/3,500A 0.02...50 A 0.02...30 A 25...30 A AC 250 V/3,500A AC 250 V/5,000A DC 80 V/3,500 A DC 80 V/3500 A Degree of protection operating area IP40 (IEC 60529/DIN 40050) terminal area IP00 Vibration with button down: 10 g (57-2000 Hz), ± 0.76 mm (10-57 Hz) at 0.9 x IN other mounting planes: 10 g (57-2000 Hz) at IN to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock 100 g (11 ms) at 1 x IN, directions 1,2,3,4,5 100 g (11 ms) at 0.8 x IN, direction 6 to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-78, test Cab Mass approx. 70 g per pole www.e-t-a.de 1 Magnetic and Hydraulic-Magnetic Circuit Breaker 8340-G2... ON OFF ø10.6 .417 ø8.4 .331 black white 57.5 2.26 1.5 .059 3 .118 12.5 .492 18.2 .717 6.5 .256 tightening torque max. 4 Nm M12x1 1 11 23 2(i) 24 12 2(k) location pin for 3mm (.118 in.) hole dia. ø3+0,2 .118+.008 2.7 .106 9.5±0.2 .374±.008 9.5 .374 0.8 .031 .492+.008 Cut-out dimensions: ø12.5+0,2 current rating in A SW14 .551 5 Type No. 8340 Magnetic push/pull circuit breaker Mounting G threadneck panel mounting Threadneck design 2 M12x1 Number of poles (main current paths) 1 single pole, protected 2 two pole, protected 3 three pole, protected Panel hardware 0 without panel hardware 1 with hex nut M12x1 and washer 12/15 Terminal design P1 blade terminals A6.3-0.8 mm (QC.250) (≤ 35 A) K4 screw terminals M5 recommended for IN > 20 A R1 round connectors ø6 Characteristic curve *) Characteristic curve, instantaneous: F4 DC F5 AC 50/60 Hz Short delay: E1 DC E2 AC 50/60 Hz Medium delay: H1 DC H2 AC 50/60 Hz Long delay: R1 DC R2 AC 50/60 Hz Actuator colour A black with white trip indicator band Actuator marking 4 rated current legible with location pin above (standard) 7 rated current legible with location pin below Auxiliary contacts H0 without auxiliary contacts H1 with auxiliary contacts H2 with auxiliary contacts on pole 1 only (2 pole types) Auxiliary contact function 1 one each N/O and N/C 3 1 pair N/C (11/12) Auxiliary contact terminal design 1 blade terminals A6.3-0.8 mm Current ratings (optional) 0.02...50 A 1.5 .059 1 Dimensions (1-pole) 19 .748 Ordering information 50 1.97 19.4 * .764 * min. 25 for use with splash cover panel thickness max. 3 mm (.118 in.) 3-pole 2-pole 57 2.24 38 1.50 unit 1 8340 - G 2 1 1 - P1 F4 - A 4 H1 1 1 - 8 A ordering example Please be informed that we have minimum ordering quantities to be observed. unit 2 unit 1  *) Other characteristic curves upon request (e.g. pulse delayed, for high inrush currents or capacitive loads) unit 3 unit 2 Cut-out dimensions: min. 40 min. 1.57 2-pole min. 60 min. 2.36 3-pole panel thickness max. 3 mm (.118 in.) This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 www.e-t-a.de 2043 Magnetic and Hydraulic-Magnetic Circuit Breaker 8340-G2... Terminal design Auxiliary contact terminal design 1 N/O, 1 N/C Terminal design -P1 11 23 2(i) 24 12 2(k) 1 10 .394 1 4.6 .181 6x6.8 6x.268 45 1.77 11 23 2(i) 24 12 2(k) blade terminal A6.3-0.8 (QC .250) to DIN 4624 45 1.77 6.8 .268 18.2 .716 1 1 N/C Terminal design -K4 terminal M5 tightening torque max.1.2 Nm terminal M5 tightening torque max.1.2 Nm 1 11 23 2(i) 24 12 2(k) 1 55.2 2.17 11 23 2(i) 24 12 2(k) blade terminal A6.3-0.8 (QC .250) to DIN 46244 11.4 .449 Terminal design -R1 Internal connection diagrams 1 11 23 2(i) 24 12 2(k) 22.5 .886 19.5 .768 1-pole, protected magnetically line 1 11 23 12 24 double pole line 1 11 23 12 24 unit 1 34 1.34 6 .236 I> 2(k) load I> 2(k) load Installation drawings 1 1-pole, protected hydraulic-magnetically Terminal design -P line 1 Terminal design -K 11 11 23 12 24 unit 2 23 I> blow out outlet CBE 12 2(k) 24 I> 2(k) load 8 blow out area 29 1.14 10 .394 25 .984 .197 1 11 23 2(i) 24 12 2(k) Terminal design -R 5 Standard Rated voltage Current ratings VDE IEC / EN 60934 UL UL 1077 AC 240/415 V AC 240 V DC 80 V AC 250 V DC 80 V DC 80 V UL UL 489A DC 80 V CSA C22.2 No 235 AC 250 V DC 80 V 0.02 A…30 A 0.02 A…30 A 0.02 A…50 A 0.02 A…30 A 0.02 A…50 A 100 A (2 poles in parallel) 0.05 A…30 A (1 + 2 pole) 0.02 A…30 A 0.02 A…50 A CQC GB 17701 5 .197 3.5 .138 Authority 5 .197 2 .079 .315 Approvals terminal area 24 .945 mounting area 1 11 23 2(i) 24 12 2(k) operating area (reinforced insulation) 29 1.14 QPL Sweden Defence Material Admin. AC 240/415 V AC 240 V DC 80 V DC 110 V MIL-C-55629 AC 240 V DC 50 V AC 240 V AC 240 / 415 V 0.02 A…30 A 0.02 A…30 A 0.02 A…50 A 0.02 A…50 A (8340-G) 1 A…30 A (8340-F410) 1 A…30 A (8340-410) 1 A…30 A (8340-F420) 1 A…30 A (8340-F430) This is a metric design and millimeter dimensions take precedence ( mm ) inch 2043 www.e-t-a.de 3 Magnetic and Hydraulic-Magnetic Circuit Breaker 8340-G2... Typical time/current characteristics Curve F4 for DC, magnetic (instantaneous) (IN >20 A, 50% ON period, 60 min.) at +23 °C / +73.4 °F 10000 1000 1000 100 100 Trip time in second 10000 Trip time in second 1 Curve F5 for AC 50/60 Hz (instantaneous) (IN > 20 A, 50 % ED/60 min.) 10 1 0,1 10 1 0,1 0,01 0,01 0,001 0,001 0 1 2 3 4 6 8 5 7 … times rated current 9 10 11 12 0 1000 1000 100 100 Trip time in second 10000 Trip time in second 10000 10 1 0,1 4 8 6 5 7 … times rated current 9 10 11 12 9 10 11 12 9 10 11 12 9 10 11 12 1 0,1 0,01 0,001 0,001 0 1 2 3 4 5 6 7 8 … times rated current 9 10 11 12 0 Curve H1 for DC (medium delay) 1 2 3 4 5 6 7 8 … times rated current Curve H2 (medium delay) for AC 50/60 Hz 10000 1000 1000 100 100 Trip time in second 10000 Trip time in second 3 10 0,01 10 1 0,1 10 1 0,1 0,01 0,01 0,001 0,001 1 0 2 4 3 6 8 5 7 … times rated current 9 10 11 12 Curve R1 for DC (long delay) 0 1 2 3 4 8 6 5 7 … times rated current Curve R2 (long delay) for AC 50/60 Hz 10000 1000 1000 100 100 Trip time in second 10000 Trip time in second 2 Curve E2 (short delay) for AC 50/60 Hz Curve E1 for DC (short delay) 10 1 0,1 0,01 10 1 0,1 0,01 0,001 0,001 0 4 1 1 2 3 4 6 8 5 7 … times rated current 9 10 11 12 0 www.e-t-a.de 1 2 3 4 6 8 5 7 … times rated current 2043 Magnetic and Hydraulic-Magnetic Circuit Breaker 8340-G2... Accessories Socket 18-P10-Si Polarized socket with adapter 18-P10-Si-20025 (for ratings >16 A please contact E-T-A) 6.5 .256 5 .197 1.4 .055 33.3 1.31 25.8 1.02 10 .394 19 .748 80 3.15 top-hat rail EN 50022-35x7.5 adapter X 200 409 01 G profile EN 50035-G32 polarization recess SW14 .551 female connector thickness 0.4 mm .016 in. 1 Splash seal, black, hex nut and O ring (IP54) X 200 802 01 (nickel plated hex nut M12x1, splash seal black) SW 17 Actuator extension X 200 803 01 (black button) 10 .394 223 8.78 ø15 .591 M12x1 M4 copper rail tin-plated 19 .748 2.5 .098 SW 17 washer A4.3 DIN 125 nickel plated 2 .079 cylinder-head-screw M4x4 ISO 1207 nickel-plated 7 .276 ø12+0.2 .472+.008 Accessories for push button Splash cover with hex nut and O ring (IP66 and IP67) X 200 801 08 (nickel plated hex nut M12x1, splash cover transparent) X 200 801 03 (black finish hex nut M12x1, splash cover black) Bus bar (10-way) (supplied as a complete package) for type 18 socket (for max. 100 A continuous load), more positions available on request X 211 158 01 with terminal X 211 158 02 without terminal Phoenix terminal AKG 35 cross section max 35 mm2 (AWG 2) 1.2±0.5 .047±.020 M12x1 blade terminal A6.3-0.8 (QC .250) to DIN 46244 polarized to ensure correct connection 10 mm .394 in. depth 45.8 1.80 4 .157 retaining clip (accessory) Spring washer Y 300 118 03 Hex nut Y 300 116 02 fusible link (constriction 1 mm/.039 in. thick) 9 .354 5.4 .213 190 7.48 10 .394 3.5 .138 Insulated sleeving for bus bars Y 303 824 11 Retaining clip for socket 18-P10-Si Y 300 579 11 Shock directions / Mounting attitudes 1 55.5 2.19 15 .591 52 2.05 3 mounting dimensions 6 ø1 .039 8 .315 60 2.36 4 2 35 1.38 5 ~70 ~2.76 100 quick-connect tabs 6.3 (.250) DIN 46247 tinned brass, insulated 2( k) Connector bus link -P10 X 210 588 01/1.5 mm2 (AWG 16), brown (up to 13 A max. load) X 210 588 02/2.5 mm2 (AWG 14), black (up to 20 A max. load) X 210 588 03/2.5 mm2 (AWG 14), red (up to 20 A max. load) X 210 588 04/2.5 mm2 (AWG 14), blue (up to 20 A max. load) 1 11 23 2(i) 24 12 This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2043 www.e-t-a.de 5 1 6 www.e-t-a.de 2043
8340-G231-P1H2-A4H221-10A 价格&库存
很抱歉,暂时无法提供与“8340-G231-P1H2-A4H221-10A”相匹配的价格&库存,您可以联系我们找货
