EM252502
EM252502
    EATON(伊顿)
    P=5mm
    接线端子 间距:5.00mm 1x2P 自由悬挂
EM252502 数据手册
EuroMag Series PCB Mount Pluggable Terminal Blocks Poles Dimensions - in (mm) 0.197 (5.00) 0.197 (5.00) 0.10 (2.5) L (mm) 0.72 (18.3) 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 0.39 (10.0) Compliance References 02 03 04 05 06 07 08 09 10 11 12 13 L 0.13 (3.3) 0.095 (2.4) 0.57 (14.5) To convert to inches, divide by 25.4 0.11 (2.8) Part Numbering System En Mn 2n 5n 2n 5 nn n Series EuroMag Series L (mm) EM252503 # of Positions Mating Header: EM2535 pg. 88 02 to 24 For additional product information, visit www.eaton.com/connectors Edge Connectors, One-Sided Boards Poles Plug & Header SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.394” (10.00mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M3.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 7 lb-in. Construction: Mold-to-Length Connector Style: Rising Cage and Screw Agency Information: File E62622; CE Certified Terminal Blocks: Single Row EM2525 Series EuroMag Terminal Blocks Pluggable Block (Mates with EM2535 Series); 5.00 Centers 85
EM252502 价格&库存
很抱歉,暂时无法提供与“EM252502”相匹配的价格&库存,您可以联系我们找货
EM252502
  • 100+5.45305
库存:900
