2210-S232-P1F1-H0-0.8A 数据手册
Thermal-Magnetic Circuit Breaker 2210-S2..
Description
One, two and three pole thermal-magnetic circuit breakers with tripfree
mechanism and toggle actuation (S-type TM CBE to EN 60934/IEC
934). Designed for panel or plug-in mounting. Available with auxiliary
contacts (1 x N/O, 1 x N/C) for status signalling. Two and three pole
models are internally linked to ensure that both/all poles trip in the
event of an overload on one pole, even if the actuator is held in the ON
position. A choice of characteristic curves further extends the range
of applications possibilities for these CBEs. Special auxiliary contact
versions for industrial atmosphere and low voltages (e. g. 5 V) available
on request.
Approved to CBE standard EN 60934 (IEC 60934).
Suitable for use in distribution rails – see section Power Distribution
Systems.
2210-S2..
Typical applications
Process control equipment, robotics, machine tool control, communications
systems, instrumentation, rail vehicles. Special versions, e.g. for aggressive
environmental conditions and low voltages (e. g. 5 V) on request.
Ordering information
Type No.
2210 single or multipole thermal-magnetic circuit breaker
Mounting
S socket or panel mounting
Actuator design
2 toggle
Number of poles
1 1-pole protected
2 2-pole protected
3 3-pole protected
5 2-pole, protected on one pole only
Panel mounting
without hardware
1
with M3 thread
2
with 6/32 thread
Terminal design (main contacts)
P1 blade terminals 6.3-0.8 (QC .250)
Characteristic curve
F1 fast acting: therm.1.01-1.4xIN;magn.2-4xIN DC (DC only)
F2 fast acting: therm.1.01-1.4xIN;
magn.3.5-6.5xIN AC/ 4.5-8.5xIN DC
M1 standard delay: therm. 1.01-1.4xIN;
magn. 6-12xIN AC;7.8-15.6xIN DC
T1 delayed: therm. 1.01-1.4xIN; magn. 10-20xIN AC
T2 thermal only, 1.01-1.4xIN
M3 standard delay, low resistance: therm.1.4-1.8xIN;
magn. 6-12xIN AC; 7.8-15.6xIN DC
Intermediate position
H without intermediate position (standard)
Z with intermediate position
Auxiliary contacts
0 without auxiliary contacts
1 with auxiliary contacts in all poles
2 with auxiliary contacts in pole 1
(only multipole devices)
3 with auxiliary contacts in poles 1 and 3
(≥ 3-pole devices)
Auxiliary contact function (see diagram)
1 one each N/C and N/O (standard)
2 one N/O contact (23/24)
3 one N/C contact (11/12)
4 one N/C contact, closed in the
intermediate and ON position (-Z only)
Auxiliary contact - terminal design
1 same as main terminals
Current ratings
0.1...25 A
2
Technical data
For further details please see chapter: Technical Information
Voltage rating
AC 250 V*; 3 AC 433 V (50-60Hz); DC 65 V
(*UL: AC 277/480 V; DC 65 V)
Current rating range
0.1...25 A for curves M1, T1, T2
0.1...16 A for curves F1, F2, M3
Auxiliary circuit
1 A, AC 240 V/DC 65 V, resistive
Typical life
10,000 operations at 1 x IN, inductive
Ambient temperature
-30...+60 °C (-22...+140 °F) T 60
Insulation co-ordination
rated impulse
pollution
(IEC 60664 and 60664A) withstand voltage
degree
2.5 kV
2
reinforced insulation in operating area
Dielectric strength
(IEC 60664 and 60664A) test voltage
operating area
AC 3,000 V
main/aux. circuit
AC 1,500 V
aux. circuit 11-12/23-24 AC 1,000 V
pole/pole
AC 1,500 V
Insulation resistance
> 100 MΩ (DC 500 V)
0.1...5 A
400 A
Interrupting capacity Icn
6...25 A
800 A
curves F1, F2, M1, T1: 0.1...16 A
2,500A (at DC 32 V)
curve T2 :
0.1...25 A
15 x IN
curve M3:
0.1...2 A AC 200 A
DC 400 A
0.1...16 A 20...25 A
(UL 1077)
IN
AC 277 V 1-pole 5,000 A
2,000 A
AC 277/480 V
2-/3-pole
5,000 A
2,000 A
DC 65 V
2,000 A
2,000 A
Degree of protection
operating area IP30
(IEC 60529/DIN 40050)
terminal area IP00
Vibration
curve F1: 3 g (57-500 Hz), ± 0.23 mm (10-57 Hz)
curves M1, M3, T1, T2: 5 g (57-500 Hz), ± 0.38 mm (10-57 Hz)
to IEC 60068-2-6, test Fc
10 frequency cycles/axis
Shock
curve F1: 25 g (11 ms), directions 1, 2, 3, 4, 5
10 g (11 ms), direction 6
curves M1, M3, T1, T2: 25 g (11 ms), directions 1, 2, 3, 4, 5
20 g (11 ms), direction 6
to IEC 60068-2-27, test Ea
Corrosion
96 hours in 5 % salt mist
to IEC 60068-2-11, test Ka
Humidity
240 hours at 95 % RH
to IEC 60068-2-78, test Cab
Mass
approx. 50 g per pole
2210 - S 2 1 0 - P1 F1 - H 1 1 1 - 10 A ordering example
Remote trip coil available to special order.
Issue C
(260111)
www.e-t-a.com
2 - 11
Current Internal resistance (Ω)
rating
F1
F2
M1
T1
M3
T2
(A)
delayed
standard delay
thermal
for AC + DC
for AC + DC
42
11.7
5.6
2.9
1.75
1.42
0.75
0.5
0.22
0.136
0.083
0.057
0.041
0.032
0.021
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
77
23
10.2
5.7
3.7
2.6
1.39
0.9
0.36
0.19
0.141
0.091
0.051
0.040
0.027
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
ON
1
.039
OFF
43
1.69
3.5
.138
25
.984
12.5
.492
11.5
.453
24 12 2
10
.394
1 11 23
37.5
1.48
68
2.68
19
.748
6.8
.268
polarizing tooth
12.5 12.5
.492 .492
6x6.8 = 40.8
6x.268 = 1.61
blade terminals
DIN 46244-A6.3-0.8
(QC .250)
50
1.97
32
1.26
unit III
unit II
unit I
mounting thread M3 or 6/32
max. screw length 5.8 mm (.228 in.)
tightening torque max. 0.5 Nm
ø11
.433
12
.472
5.5
.217
24.2
10.4
6.0
3.9
2.7
1.53
0.98
0.42
0.24
0.17
0.12
0.073
0.055
0.039
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
2A
M1
92
26.1
11.6
6,6
4,1
3
1.65
1,10
0.47
0.28
0.183
0.124
0.077
0.063
0.045
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
2A
M1
162
39.3
17.5
9.2
6.8
4.2
2.8
1.6
0.78
0.42
0,26
0.18
0.12
0.092
0.054
0.025
0.02
≤ 0.02
≤ 0.02
2A
M1
162
39.3
17.5
9.2
6.8
4.2
2.8
1.6
0.78
0.42
0.26
0.18
0.12
0.092
0.054
0.025
0.022
≤ 0.02
≤ 0.02
multipole devices
16
.630
Approvals
Current ratings
Cut-out dimensions
0.1...25 A
32
1.26
3-pole
2-pole
1-pole
16
.630
ø11.5
.453
OFF position
ON position
12.5 12.5
.492 .492
1.5
.059
Toggle positions
90°
s
ø4
0.1...25 A
57
UL, CSA
Voltage ratings
AC 250 V; DC 65 V;
3 AC 433 V
AC 277 V; DC 65 V;
AC 277/480 V
.1
Authority
GL, VDE (EN 60934)
36.6
1.44
24
.945
recess with panel thickness
s > 1.5 mm (.059 in.)
ø11.5
.453
Shock directions
Installation drawing
operating area
(reinforced insulation)
3
5
6
4
1
current rating
1 11 23
24 12 2
2
5
.197
2
0.1
0.2
0.3
0.4
0.5
0.6
0.8
1
1.5
2
2.5
3
4
5
6
8
10
12
16
30.5
1.20
18
.709
low resistance
for AC + DC for AC + DC nur für AC
for DC only
Z
25° 25°
fast acting fast acting standard
delay
Dimensions
10.5
.413
Standard current ratings and typical internal resistance values
mounting area
(standard insulation)
This is a metric design and millimeter dimensions take precedence ( mm )
inch
2 - 12
www.e-t-a.com
Issue C
(260111)
Internal connection diagrams
Typical time/current characteristics
with auxiliary contact function 1 (one each N/O and N/C)
(...-H111-...) without intermediate position
(...-Z111-...) with intermediate position
(Z)
I
line
1
11
12
23
line
1
(Z)
0 I
12
24
I>
2
OFF position
11
23
(Z)
0 I
DC only
10000
1000
line
1
11
23
12
24
I>
I>
2
2
ON position
Trip time in seconds
-F1 0.1…16 A
24
100
10
1
0.1
with auxiliary contact function 4 (1 N/O, leading)
(Z)
I
line
1
23
(Z)
I
line
1
23
(Z)
line
I
1
2
0.01
23
0.001
1
24
24
2
24
4 6 8 10 20 406080100
… times rated current
-F2 0.1…7.5 A
I>
2
AC/ DC1)
I>
10000
2
ON position
1000
2
OFF position
I>
100
10
1
0.1
0.01
0.001
1
2
-F2 8…16 A
AC/ DC1)
10000
1000
100
10
1
0.1
0.01
The time/current characteristic curve depends on the ambient temperature
prevailing. In order to eliminate nuisance tripping, please multiply the circuit
breaker current ratings by the derating factor shown below. See also section
Technical information.
0.001
1
Ambient temperature °F -22 -4 +14 +32 +73.4 +86 +104 +122 +140
°C -30 -20 -10 0
+23 +30 +40 +50 +60
Derating factor
0.76 0.79 0.83 0.88 1
1.04 1.11 1.19 1.29
Multipole devices: all poles symmetrically loaded. With single pole overload,
thermal tripping will be at max. 1.7 x IN with curves F1, F2, M1 and T2, and at
max. 2.2 x IN with curve M3.
Issue C
(260111)
+60 °C
+140 °F
1)
2
4 6 8 10 20 40 6080100
+23 °C
+73.4 °F
-30 °C
-22 °F
Magnetic tripping currents are increased by 30% on DC supplies.
www.e-t-a.com
2 - 13
Multi pole devices: all poles symmetrically loaded. With single pole
overload, thermal tripping will be at max. 1.7 x IN with curves F1, F2, M1
and T2, and at max. 2.2 x IN with curve M3.
1)
°C -30 -20 -10 0
+23 +30 +40 +50 +60
Derating factor
1.04 1.11 1.19 1.29
-M1 0.1…6 A
-M1 8…32 A
1)
AC/DC
1)
-T1 0.1…6 A
1000
1000
1000
100
10
1
10000
10000
10000
100
10
1
10
1
0.1
0.1
0.01
0.01
0.01
0.001
1
2
0.001
-T1 8...32 A
1
2
-M3 0.1…5 A
AC only
AC/DC1)
0.001
1000
1000
10
1
1000
10000
10000
100
10
1
0.01
0.01
0.01
-T2 0.1…6 A
1
AC/DC
2
-T2 8…32 A
1
2
AC/DC
10000
10000
1000
1000
100
10
1
100
10
1
0.1
0.1
0.01
0.01
0.001
1
2
0.001
+60 °C
+140 °F
2 - 14
0.001
0.001
AC/DC1)
1
0.1
2
10
0.1
1
2
100
0.1
0.001
1
-M3 6...16 A
10000
100
AC only
100
0.1
2
AC/DC
(curves M1, M3, T1).
+23 °C
+73.4 °F
1
2
-30 °C
-22 °F
www.e-t-a.com
Issue C
(260111)
Accessories
slot for fitting labels from
Phoenix, Weidmüller, Wieland
Single mounting sockets
(with adapter)
(up to 16 A max. load)
17-P10-Si
17-P10-Si-20025
17-P70-Si
17-P70-Si-20025
(retaining clip Y 302 974 21 available on request)
blade terminal DIN 46244 part 2
C profile (2xA2.8-0.8) (QC 2x.110)
polarized blade terminal
DIN 46244-A6.3-0.8 (QC .250)
115
4.53
symmetrical rail
EN 50022-35x7.5
11
23
2(i)
11
14
14
10
.394
G-profile
EN 50035-G32
Bus bar 50 A (6-way) for type 17-P10-Si socket
X 221 760 01
71 ± 1.5
2.79 ± .060
25
.984
4.4
.173
6
.236
retaining
clip
10
.394
2
.079
12.5
.492
Outer dimensions of female
connectors to
6.3-1 DIN 46247 Ms-gal Sn
max. 16 A
busbar
max. 50 A
Bus bar (10-way) (supplied as a complete package)
for type 17 socket
(for max. 100 A continuous load),
e positions available on request
mor
X 211 157 01 with terminal
X 211 157 02 without terminal
Phoenix terminal AKG 35
max.cross section 35 mm2 (AWG 2)
max. 30
max. 1.18
cylinder head screw washer
M4x4 ISO1207
A 4.3 DIN 125
nickel plated
nickel plated
Bus bar 50 A, 6-way, for type 63-P10-Si socket
X 221 760 11
12.5
.492
10
.394
33.2
1.31
.315
7
.276
connectors to
max. 16 A
12.8
.504
pressure-relief joint
(1.1 mm (.043 in.)
thick constriction)
154.8
6.09
Insulating sleeving for bus bar (10-way)
Y 303 824 01
9
.354
5.4
.213
125
4.92
17
.669
busbar
max. 50 A
female
connector
M4 Cu rail, tin-plated
blade terminal
DIN 46244 A6.3-0.8
(QC .250), max. 25 A
8
71 ± 1.5
2.79 ± .060
25
.984
33.2
1.31
8
21
.827
insulation to
DIN 4102-B2
translucent
2
.079
75
2.95
6 x .268 = 1.61 6.8
.268
50
1.97
57.4
2.26
6 x 6.8 = 40.8
50
1.97
3.5
.138
polarized
recess
12.5
.492
blade terminal
DIN 46244 A6.3-0.8
.315
12
2
12
2
1 Line 1 Line
11
left-side terminal block
22.2
polarized blade terminals
7.4 DIN 46244-A6.3-0.8 (QC .250) .874
.291
6.25
12.5
.246
.492
50
1.97
57.4
2.26
64
2.52
64
2.52
2(i)
right-side terminal block
2-way
6-way mounting socket
mounting socket
23-P10-Si
63-P10-Si
(retaining clip Y 302 974 01 available on request)
insulation to
DIN 4102-B2
translucent
23
symmetrical rail
EN 50022-35x7.5
adapter X20040901
module
25
.984
11
12.5
.492
80
3.15
polarization recess
12.5
.492
2(k)
12
24
1
slot for busbar
4.4
.173
2
5
.197
41.3
1.63
2(k)
12
24
1
retaining clip
10
.394
1.4
.055
25
.984
33.3
1.31
25
.984
37
1.46
25.8
1.02
6
.236
G-profile
EN 50035-G32
6.5
.256
63
2.48
depth
10 mm
(.394 in.)
8.5
.335
57
2.24
47
1.85
42.5
1.67
17 plus
2.8
.110
6.3
.248
Phoenix, Weidmüller
7.4
.291
-P70
10
.394
68
2.64
-P10
45.8
1.80
10.5
.413
Module 17plus
For technical data see section Power distribution systems
inch
Issue C
(260111)
www.e-t-a.com
2 - 15
Accessories
Splash cover (transparent)
with fixing plate and screws (IP54)
for type 2210-S211-… (1-pole)
X 211 117 02
mounting holes
ø17+0,2
.669+.008
21
1.2
.047
fixing plate
19
.748
~70
~2.76
ø16.8
.661
39
1.54
Toggle guard for 1-pole units, black
X 221 617 01
38
1.50
21
.827
max. 4
max .157
for type 2210-S221-… (2-pole) and
type 2210-S231-… (3-pole)
X 211 118 01
1.2
.047
22
.866
32
1.26
mounting dimensions:
M3 - hole dia. 3.5 mm/.138 in.
5.5
.217
38
1.50
32
1.26
32
1.26
ø3.5
.138
9.5
.374
2.5
.098
3.6
.142
24
.945
R
.4 12
72
1
.039
R1
5
91
.5
12
.472
24.5
.965
fixing plate
For front panel mounting.
mounting hole
25+0.3
.984+.012
40
1.57
53
2.09
3pole .992±.004
.496±.004
3pole 25.2±0.1
32±0.1
1.26±.004
2pole 12.6±0.1
43
1.69
2
.827
31
1.22
100 quick-connect tabs 6.3 (.250)
DIN 46247 tinned brass,
insulated
max. 2
max .079
Connector bus links -P10
X 210 588 01/ 1.5 mm2, (AWG 16), brown (up to 13 A max. load)2
X 210 588 02/ 2.5 mm2, (AWG 14), black (up to 20 A max. load)
X 210 588 03/ 2.5 mm2, (AWG 14), red (up to 20 A max. load)
X 210 588 04/ 2.5 mm2, (AWG 14), blue (up to 20 A max. load)
inch
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
2 - 16
www.e-t-a.com
Issue C
(260111)
