EM221803H
EM221803H
    EATON(伊顿)
    插件
    TERM BLOCK HDR 3POS R/A 5.08MM
EM221803H 数据手册
Plug & Header EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Pluggable Terminal Blocks Series EM2218 Header with Flanges; (Mates with EM2118, EM3118 Series); 5.08 Centers SPECIFICATIONS: Rating: 12A, 300V Center Spacing: 0.20" (5.08mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -55°C (-67°F) min. Recommended PCB Hole Diameters: 0.059" (1.50mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM221804H EM221804V Dimensions - in (mm) Poles L (mm) L (Inch) Poles L (mm) L (Inch) 2 3 4 5 6 7 8 9 10 11 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.95 66.04 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 12 13 14 15 16 17 18 19 20 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 2.8 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 0.47" (12.00) 0.18" (4.50) L 0.10" (2.54) 0.33" (8.30) M2.6 0.20" (5.08) 0.04" (1.00) 0.07" (1.80) Ø.06" (1.50) Compliance References Edge Connectors, One-Sided Boards HORIZONTAL PCB Hole Layout 0.47" (12.00) 0.07" (1.80) 0.20" (5.08) VERTICAL 0.15" 0.04" (3.80) (1.00) L 0.47" (12.00) 0.10" (2.54) 0.33" (8.30) 0.20" (5.08) 0.18" (4.50) 0.15" (3.80) M2.6 Ø.06" (1.50) 0.33" (8.30) PCB Hole Layout 0.20" (5.08) Part Numbering System En Mn 2n 2n 1n 8 n Series nn # of Poles 02 to 22 Inches (Millimeters) n Orientation Mating Plugs: EM2118 pg. 96 EM3118 pg. 97 H - Horizontal V - Vertical For additional product information, visit www.eaton.com/connectors 98
EM221803H 价格&库存
很抱歉,暂时无法提供与“EM221803H”相匹配的价格&库存,您可以联系我们找货
