High Performance Thermal-Magnetic Circuit Breakers 446/447/449
Description
Single pole thermal-magnetic circuit breakers with tease-free, trip-free,
press-to-reset snap action mechanism and special dual button manual
release which avoids the danger of unintended disconnection (M-type
TM CBE to EN 60934). Surface mounted, compact design available
with fast acting, standard and delayed switching characteristics. Options
include auxiliary contact and remote electrical disconnection.
Typical applications
Heavy duty vehicles, battery systems, process control.
446-...
Ordering information
Type No.
446 / 447 / 449 single pole base mounting
Terminal design, mounting
K
screw terminals M12, insertion nuts M8
S
screw terminals M12, insertion nuts 5/16"
Manual release
H
standard
Version
N
general application (type 446 only)
FN
general application (types 447 and 449 only)
Auxiliary contacts (optional)
Si
2 electrically separate auxiliary contacts
with screw terminals M 3.5 and
blade terminals DIN 46244-C-MS-S
Remote trip (optional for types 447 and 449)
FA12 DC 12 V coil voltage
FA24 DC 24 V coil voltage
Current ratings
30...400 A type 446
100...400 A type 447
125...500 A type 449
447 - K - H - FN -
- 200 A ordering example
The exact part number required can be built up from the table of choices shown
above. Ordering references for optional features should be omitted if not required.
Standard current ratings and typical internal resistance values
Current
rating (A)
Internal
resistance (Ω)
Current
rating (A)
Internal
resistance (Ω)
30
0.006
100
< 0.002
40
0.0048
125
< 0.001
50
0.0038
160
< 0.001
60
0.0028
225
< 0.001
70
0.0025
300
< 0.001
80
0.0023
400
< 0.001
0.0019
449
0.0016
125
< 0.001
125
< 0.001
160
< 0.001
150
< 0.001
225
< 0.001
170
< 0.001
315
< 0.001
200
< 0.001
350
< 0.001
225
< 0.001
400
< 0.001
250
< 0.001
500
< 0.001
300
< 0.001
only with 50 % ON duty
350
< 0.001
400
< 0.001
Issue D
Voltage rating
Current rating range
DC 28 V
type 446: 30...400 A
type 447: 100...400 A
type 449: 125...500 A
Auxiliary circuit
10 A
Electrical remote disconnection (-FA)
operating voltage
DC 12 V or DC 24 V
operating current
approx. 18 A or 12 A
max. pulse time
10 ms < tON < 20 ms / tOFF > 10 s
switching time
< 20 ms
Typical life
1,000 operations at IN
2,000 operations mechanical
Ambient temperature
Insulation co-ordination
(IEC 60664 and 60664A)
Dielectric strength
operating area
main circuit to
auxiliary contacts
Insulation resistance
Interrupting capacity Icn
Degree of protection
(IEC 60529/DIN 40050)
Vibration
Shock
Corrosion
Humidity
90
100
449-...
Technical data
447
446
447-...
Mass
4
-55...+75 °C (-67...+167 °F)
Rated impulse
Pollution
withstand voltage degree
1.5 kV
3
Test voltage
AC 1,000 V
AC 1,000 V
>100 MΩ (DC 500 V)
10,000 A
operating area IP 40
terminal area IP 00
without auxiliary contacts:
10 g (56-500 Hz) ±0.76 mm (10-55 Hz)
with auxiliary contacts:
4 g (56-500 Hz) ±0.30 mm (10-56 Hz)
to VG 95210, sheet 19/IEC 60068-2-6, test Fc
without auxiliary contacts: 50 g (11 ms)
with auxiliary contacts: 20 g (11 ms)
to VG 95210, sheet 28/IEC 60068-2-27, test Ea
96 hours at 5 % salt mist
to VG 95210, sheet 2/IEC 60068-2-11, test Ka
240 hours at 95 % RH
to VG 95210, sheet 7/IEC 60068-2-3, test C
approx. 850 g
Approvals
Authority
VG 95345, part 15
QPL Sweden
UL
USA (847) 827-7600 - www.e-t-a.com -
Voltage ratings
DC 28 V
DC 28 V
DC 28 V
CANADA (905) 764-9510
Current ratings
125...500 A
125...400 A
30...400 A
100...400 A
125...350 A
(449)
(447)
(446)
(447)
(449)
233
Dimensions
Internal connection diagrams
line 1
40
1.58
60
2.36
ø26
1.02
23 OFF
.906
ON
15
.591
6
.236
hex nut M8 or 5/16"
14 mm/.551 in. usable thread length
tightening torque max. 3.5 Nm
ø20
.787
7
FA
2
2
hex nut
ISO 4032-M12-Cu2-E1P
tightening torque
max. 4.5 Nm
106
4.17
4
.157
.925
446-...
hex screw
ISO 4017-M12x30-Cu2-E1P
170
6.69
140
5.51
current rating in A
EIN ON
AUS OFF
AUS OFF
43.5
1.71
11
.433
DC
10000
1000
100
3.94
2
.079
Typical time/current characteristics at +23°C/+73.4°F
lock washer
DIN 137-B12X12CrNi 177
35
1.38
4
recommended
link for FA coil
protection
I>
8
6
FA-terminal (8)
N/C 4/5
23.5
I>
Trip time in seconds
13
.512
58
2.28
Si
4
N/O 6/7
104
4.09
5
30
1.18
line 1
100
10
1
0.1
12
.472
blade terminal DIN 46244-C-MS-S
0.01
flat head screw ISO 1580-M3.5x5
tightening torque max. 0.55 Nm
0.001
1
This is a metric design and millimeter dimensions take precedence
mm
inch
2
4 6 8 10
… times rated current
447-...
DC
449-... 125...400 A
449-... 500 A (50 % ON duty/60 min.) DC
1000
1000
100
100
100
10
1
1000
10000
10000
10
1
10
1
0.1
0.1
0.1
0.01
0.01
0.01
0.001
0.001
1
+75 °C
+167 °F
2
4 6 8 10
+23 °C
+73.4 °F
0.001
1
2
4 6 8 10
-55 °C
-67 °F
Circuit breakers with remote disconnection facility will trip 10 % faster.
234
DC
10000
1
2
4 6 8 10
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications without
notice is reserved.Product markings may not be exactly as the ordering codes. Errors and
omissions excepted.
Issue D
很抱歉,暂时无法提供与“446-S-H-N-200A”相匹配的价格&库存,您可以联系我们找货
