Female Card Edge
Sullins Female Card Edge
.100” [2.54 mm] Contact Centers, .690” [17.52 mm] Insulator Height,
Make Before Break Dip Solder/Card Extender/Right Angle
SPECIFICATIONS
• Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
• PA9T insulator
• Molded-in key available
• 3 Amps current rating for one contact energized
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
READOUT
MOUNTING STYLE
NO MOUNTING EARS (N)
DUAL (D)
OPEN CARD
SLOT (B)
TERMINATION TYPE
MBB CONTACT, .025” [0.64] SQ.
.030” [0.76]
.190” [4.82]
.425”± .025”
[10.80±0.64]
FITS Ø
.043” [1.09] MIN.
.150” [3.81]
.200” [5.08]
.100”±.025” [2.54±0.64]
FORMED TO FIT .062” [1.57] PCB
CARD EXTENDER (CS)
GBC_ _DCSN-S527
58
FITS Ø
.043” [1.09] MIN.
DIP SOLDER (CS)
GBC_ _DCSN-S36
RIGHT ANGLE (CA)
GBC_ _DCAN-S757
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
G B C 10 D CS N - S36
MODIFICATION CODE (Consult Factory)
-S757 = MBB, .150” [3.81] Row to Row on Right Angle
-S527 = MBB, Card Extender Accepts .062” [1.57 mm] PCB
-S36 = MBB, Straight Dip-Solder
MOUNTING STYLE
N = No Mounting
B = Open Card Slot Available for 50 position only
H = Clearance Holes
TERMINATION TYPE (Opposite Page)
Hairpin Bellows
CS = .025” [0.64 mm] Square Dip Solder/Card Extender
CA = .025” [0.64 mm] Square Right Angle
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
B = .000010” Gold
C = .000030” Gold
MATERIALS (INSULATOR/CONTACT)
G = PA9T/Phosphor Bronze
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
Termination
.000100” Pure Tin, Matte
CONTACT CENTERS
C = .100” [2.54 mm]
NUMBER OF CONTACT POSITIONS
READOUT (Opposite Page)
D = Dual
See Chart Below
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
D
.370 [9.40]
Open Card Slot (B)
.515 [13.08]
INSERTION DEPTH
A
B
C
.025 [0.64] SQ.
.690 [17.53]
.100 [2.54] TYP.
REFER TO
TERMINATION TYPE
(Opposite Page)
F
No Mounting (N)
POSITIONS/
CONTACTS
A±.008 [0.20]
B±.008 [0.20]
C±.015 [0.38]
D±.020 [0.51]
F±.020 [0.51]
40/80*
in
0.100
0.300
0.500
0.700
0.900
1.100
1.300
1.500
1.700
1.900
2.100
2.300
2.500
2.700
2.900
3.100
3.300
3.500
3.700
3.900
mm
2.54
7.62
12.70
17.78
22.86
27.94
33.02
38.10
43.18
48.26
53.34
58.42
63.50
68.58
73.66
78.74
83.82
88.90
93.98
99.06
in
0.300
0.500
0.700
0.900
1.100
1.300
1.500
1.700
1.900
2.100
2.300
2.500
2.700
2.900
3.100
3.300
3.500
3.700
3.900
4.100
mm
7.62
12.70
17.78
22.86
27.94
33.02
38.10
43.18
48.26
53.34
58.42
63.50
68.58
73.66
78.74
83.82
88.90
93.98
99.06
104.14
in
0.460
0.660
0.860
1.060
1.260
1.460
1.660
1.860
2.060
2.260
2.460
2.660
2.860
3.060
3.260
3.460
3.660
3.860
4.060
4.260
mm
11.68
16.76
21.84
26.92
32.00
37.08
42.16
47.24
52.32
57.40
62.48
67.56
72.64
77.72
82.80
87.88
92.96
98.04
103.12
108.20
in
0.250
0.450
0.650
0.850
1.050
1.250
1.450
1.650
1.850
2.050
2.250
2.450
2.650
2.850
3.050
3.250
3.450
3.650
3.850
4.050
mm
6.35
11.43
16.51
21.59
26.67
31.75
36.83
41.91
46.99
52.07
57.15
62.23
67.31
72.39
77.47
82.55
87.63
92.71
97.79
102.87
in
0.340
0.540
0.740
0.940
1.140
1.340
1.540
1.740
1.940
2.140
2.340
2.540
2.740
2.940
3.140
3.340
3.540
3.740
3.940
4.140
mm
8.64
13.72
18.80
23.88
28.96
34.04
39.12
44.20
49.28
54.36
59.44
64.52
69.60
74.68
79.76
84.84
89.92
95.00
100.08
105.16
42/84*
4.100
104.14
4.300
109.22
4.460
113.28
4.250
107.95
4.340
110.24
44/88*
4.300
109.22
4.500
114.30
4.660
118.36
4.450
113.03
4.540
115.32
46/92*
4.500
114.30
4.700
119.38
4.860
123.44
4.650
118.11
4.740
120.40
48/96*
4.700
119.38
4.900
124.46
5.060
128.52
4.850
123.19
4.940
125.48
50/100
4.900
124.46
5.100
129.54
5.260
133.60
5.050
128.27
5.140
130.56
02/04*
04/08*
06/12*
08/16*
10/20*
12/24*
14/28
16/32*
18/36*
20/40*
22/44*
24/48*
26/52*
28/56*
30/60*
32/64*
34/68*
36/72*
38/76*
*Consult factory for availability.
59
很抱歉,暂时无法提供与“GCC12DCSN-S527”相匹配的价格&库存,您可以联系我们找货
