21038811805
21038811805
    HARTING(浩亭)
21038811805 数据手册
Product data sheet 21 03 881 1805 har-speed M12Crimp SlimDesign x-coded har-speed M12Crimp SlimDesign x-coded Part number 21 03 881 1805 Specification har-speed M12Crimp SlimDesign xcoded HARTING eCatalogue https://b2b.harting.com/21038811805 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series Circular connectors M12 Identification Slim Design Element Cable connector Specification Straight Version Termination method Crimp termination Gender Male Locking type Screw locking Shielding Shielded Number of contacts 8 Coding X-coding Details Please order crimp contacts separately. Details For Ethernet applications up to 10 Gbit only Technical characteristics Conductor cross-section 0.08 ... 0.25 mm² Conductor cross-section AWG 28 ... AWG 23 Wire outer diameter ≤1.4 mm Rated current 0.5 A Rated voltage 48 V Rated impulse voltage 0.8 kV Page 1 / 3 | Creation date 2020-06-07 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 881 1805 har-speed M12Crimp SlimDesign x-coded Technical characteristics Pollution degree 3 Insulation resistance >108 Ω Contact resistance ≤10 mΩ Tightening torque 0.6 Nm Wrench size (knurled screw / knurled nut) 15 Ambient temperature -40 ... +85 °C Mating cycles ≥500 Degree of protection acc. to IEC 60529 IP65 / IP67 when mated Cable diameter 5.7 ... 8.8 mm Transmission characteristics Cat. 6A Class EA up to 500 MHz Overvoltage category III Isolation group I (600 ≤ CTI) Material properties Material (insert) Liquid crystal polymer (LCP) Material (hood/housing) Zinc die-cast RoHS compliant ELV status compliant China RoHS e REACH Annex XVII substances No REACH ANNEX XIV substances No REACH SVHC substances No Specifications and approvals Specifications IEC 61076-2-109 UL / CSA UL 2238 CYJV2.E302521 CSA-C22.2 No. 182.3 CYJV8.E302521 PROFINET Yes Commercial data Packaging size 1 Net weight 36 g Country of origin Romania European customs tariff number 85366990 Page 2 / 3 | Creation date 2020-06-07 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 881 1805 har-speed M12Crimp SlimDesign x-coded Commercial data eCl@ss 27440102 Circular connector (for field assembly) Page 3 / 3 | Creation date 2020-06-07 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
21038811805 价格&库存
很抱歉,暂时无法提供与“21038811805”相匹配的价格&库存,您可以联系我们找货
  • 1+444.15441
  • 5+424.16189
  • 10+406.11522
  • 25+390.08561
  • 50+374.13905
  • 100+360.13835
库存:78
21038811805
  • 1+303.45922
  • 5+294.34711
  • 10+285.52659
  • 25+279.96560
  • 50+274.30047
库存:2
21038811805
  • 1+386.955201+49.28370
  • 10+348.7052010+44.41210
  • 25+326.9446025+41.64060
  • 50+311.3181050+39.65040
  • 100+296.37960100+37.74780
  • 250+277.94260250+35.39960
库存:685
