UTL1102G1W3S
UTL1102G1W3S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONNHSGRCPT6POSINLINESKT
UTL1102G1W3S 数据手册
A B C D E F G H C.2; Validé NOTES MATERIALS HOUSING SEE TABLE 8 PERFORMANCES CHARACTERISTICS MECHANICAL TEMPERATURE CLASS DURABILITY SEALING IN MATED CONDITIONS WIRING FACE SEALING IN UNMATED CONDITIONS POLLUTION DEGREE CORROSION SALT SPRAY FLAMMABILITY OUTDOOR SUITABILITY (UV RESIST) SCOOP PROOF MATING FACE 7 ELECTRICAL TOUCH PROOF 31,5±0,6 FOR INFORMATION 32 MAXI 14±0,4 POWER AND GROUND LINES: NOMINAL CURRENT 20±0,3 8 IEC61984/UL1977 IEC61984 IEC60529 DIN40050 IEC60529 IEC61984 UL94 UL746C -40°C TO 105°C 500 MATE / UNMATE CYCLES IP68 1BAR DURING 1WEEK IP69K IP67 WITH CAPS 4 MIN 1000H MATERIAL RATING: 5VA MATERIAL RATING: (f1) IEC60529 IP2X UL1977 16A WITH AWG14 WIRE / 13A WITH AWG16 WIRE 16A WITH 2.5MM² WIRE / 13A WITH 1.5MM² WIRE AT 60°C 7 NOMINAL CURRENT IEC61984 NOMINAL VOLTAGE NOMINAL VOLTAGE UL1977 IEC61984 IEC61984 600V 250VAC 4KV 4 FOR CLASS II 500VAC 6KV 4 FOR CLASS I IEC61984 IEC61984 48V AC 5A 6 SIGNAL CONTAC (a,b,c) LINES: NOMINAL VOLTAGE NOMINAL CURRENT 6 ROHS COMPLIANT 28,6±0,3 1. COUNTERPART REFERENCE UTL PLUG 2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT 3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16 AND #20, R*M* OR S*M* TYPES 4. CONTACTS TO BE ORDERED SEPARETELY. 5. WARNING: PHASE CONTACTS AND SIGNAL CONTACT ARE FEMALE VERSION AND GROUND CONTACT IS MALE VERSION 6. UNIT IN MM 5 5 HOUSING' S MATERIAL UTL1102G1W3S PA GF REINFORCED BLACK COLOR UTL1102G1W3S03 PA GF REINFORCED LIGHT GREY COLOR 4 P/N 4 3 3 HOUSING x3 #20 FEMALE SIGNAL CONTACTS P/N : SEE TABLE x2 #16 FEMALE POWER CONTACTS 2 x1 #16 GROUND MALE CONTACT C 06/03/2015 ISS DATE Designed by: TITLE Scale 1/1 __ 23869 _ Clearances dimensions modification Latest modification - by: RAGAINE M. COUTY L. Date:18/07/2013 CUSTOMER DRAWING FEMALE FREE HANGING LAYOUT 6 CONTACTS SIZE 10 UTL CONNECTOR General linear Tolerances: 0,2 1 WWW.SOURIAU.COM FORMAT A2 H G F E D C 2 MOD N NPRDS / PROJECT UTL This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° UTL1-0052A-C01 B CLASSIFICATION: NOT EXPORT CONTROLLED SHEET 1/1 A 1
UTL1102G1W3S 价格&库存
很抱歉,暂时无法提供与“UTL1102G1W3S”相匹配的价格&库存,您可以联系我们找货
UTL1102G1W3S
  • 1+239.423461+29.74968
库存:8
