EM501504
EM501504
    EATON(伊顿)
    TERM BLOCK PLUG 4POS 90DEG 5MM
EM501504 数据手册
EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single Row EM5015 Series EuroMag Terminal Blocks Pluggable Block (Mates with EM5025 Series); 5.00 Centers EM501508 Dimensions - in (mm) 0.197 (5.00) Poles L (mm) 2* 3* 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 0.37 (9.3) 0.53 (13.5) L Compliance References L (mm) Edge Connectors, One-Sided Boards 0.10 (2.5) TEST POINT Poles 0.43 (11.0) To convert to inches, divide by 25.4 *Mold-to-Length WIRE ENTRY WIRE ENTRY Mating orientations Part Numbering System En Mn 5n 0n 1n 5 nn n Series # of Poles EuroMag Series EM501504 Plug & Header SPECIFICATIONS Rating: 15A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #16-24 AWG Housing Material: Blue UL 94V0 Thermoplastic Contact Material: Tin-Plated Brass Screw Size: M2x6 Chromatized Steel Operating Temperature: 120°C (221°F) max., -40°C (-40°F) min. Torque Rating: 3.0 lb-in. Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Spring and Screw Agency Information: File E62622; CE Certified Mating Header: EM5025 pg. 104 02 to 24 For additional product information, visit www.eaton.com/connectors 103
EM501504 价格&库存
很抱歉,暂时无法提供与“EM501504”相匹配的价格&库存,您可以联系我们找货
EM501504
  • 1+23.623761+2.95479
  • 10+16.9094710+2.11499
  • 25+14.7465825+1.84446
  • 50+13.3710150+1.67241
  • 100+12.21850100+1.52826
  • 300+10.80313300+1.35123
  • 500+10.29395500+1.28754
  • 1000+9.728341000+1.21680
  • 5000+8.843455000+1.10612
库存:100
