EuroMag Series PCB Mount Pluggable Terminal Blocks
Terminal Blocks:
Single Row
EM2565 Series
EuroMag Terminal Blocks
Pluggable Block (Mates with EM2575
Series); 5.08 Centers
Dimensions - in (mm)
HORIZONTAL
0.197
(5.00)
0.200
(5.08)
0.10
(2.54)
0.39
(10.0)
Position
Position
L (mm)
10.16
15.24
20.32
25.40
30.48
35.56
40.64
45.72
50.80
55.88
60.96
66.04
14
15
16
17
18
19
22
23
24
71.12
76.20
81.28
86.36
91.44
96.52
101.60
106.68
111.76
116.84
121.92
0.13
(3.3)
L
0.57
(14.5)
Compliance
References
02
03
04
05
06
07
08
09
10
11
12
13
L (mm)
0.39
(10.0)
0.11
(2.8)
0.08
(2.1)
VERTICAL
To convert to inches, divide by 25.4
L
0.47
(12.0)
0.47
(12.0)
WIRE
ENTRY
0.11
(2.8)
0.13
(3.3)
0.13
(3.3)
WIRE
ENTRY
1.02
(26.0)
0.09
(2.4)
0.33
(8.3)
RIGHT
LEFT
1.0
(2.54)
0.200
(5.08)
0.200
(5.08)
Part Numbering System
# of Positions
Orientation
n
Wire Entry
(Vertical Orientation Only)
02 to 24
H - horizontal
V - vertical
L - left
R - right
En
Mn
2n
5n
6n
5 nn
n
Series
Edge Connectors,
One-Sided Boards
0.72
(18.3)
EuroMag Series
EM256503H
Plug & Header
SPECIFICATIONS
Rating: 16A, 300V
Center Spacing: 0.20” (5.08mm)
Consult factory for 0.40” (10.16mm)
Wire Range: #12-24 AWG
Housing Material: UL rated 94V0 Thermoplastic
Contact Material: Brass Tin-Plated
Screw Size: M3.0 Zinc-Plated Steel
Operating Temperature: 105°C (221°F) max., -40°C
(-40°F) min.
Torque Rating: 7 lb-in.
Construction: Mold-to-Length
Agency Information:
File E62622; CE Certified
n
Mating Header: EM2575 pg. 92
For additional product information, visit www.eaton.com/connectors
89
很抱歉,暂时无法提供与“EM256503H”相匹配的价格&库存,您可以联系我们找货
