0918526900258U
0918526900258U
    HARTING(浩亭)
    SEK PCRAIN RELIEF CLAMP FE 26P B
0918526900258U 数据手册
SEK IEC 60 603-13 Number of contacts 6--64 Strain relief clamp/Locking lever No. of contacts Strain relief clamp 6 10 14 16 20 24 26 30 34 40 50 60 64 with bulk packaging 3) Packaging unit 5,000 pieces 4) Packaging unit 3,000 pieces 6 10 14 16 20 26 30 34 40 Part number Drawing 09 18 506 9002 09 18 510 9002 09 18 514 9002 09 18 516 9002 09 18 520 9002 09 18 524 9002 09 18 526 9002 09 18 530 9002 09 18 534 9002 09 18 540 9002 09 18 550 9002 09 18 560 9002 09 18 564 9002 No. of contacts 6 10 14 16 20 24 26 30 34 40 50 60 64 6 09 18 506 9002 58U3) 09 18 510 9002 58U3) 10 09 18 514 9002 58U3) 14 09 18 516 9002 58U3) 16 09 18 520 9002 58U3) 20 09 18 526 9002 58U3) 26 09 18 530 9002 58U3) 30 09 18 534 9002 58U4) 34 09 18 540 9002 58U4) 40 Locking lever for female connector A 12.2 17.3 22.4 24.9 30.0 35.18 37.6 42.7 47.8 55.4 68.1 80.8 85.9 12.2 17.3 22.4 24.9 30.0 37.6 42.7 47.8 55.4 Strain relief clamp Only in conjunction with low-profile male header and strain relief  ackaging unit P 100 pieces 6) Packaging unit 5,000 pieces Dimensions in mm SEK Identification 09 18 000 99051)5) 09 18 000 9905 58U1)6) 5) Female connector Low-profile male header When the security of latching is required and space is a ­premium, these locking levers can be fitted onto the strain relief of the H ­ ARTING female connector. This can then be used in c­ onjunction with male low-profile headers (see pages 08.14 and 08.15). Coding system with loss of contact Code pin Removal tool for male contacts 1) 2)  rder 2 per female connector O Part number comprises 6 code pins 09 18 000 99012) 09 99 000 0133 To avoid cross-plugging adjacent connectors a coding system is required. A code pin is inserted into the appropriate cavity in the female connector. The corresponding male contact is removed by a special removal tool. 08 23
0918526900258U 价格&库存
很抱歉,暂时无法提供与“0918526900258U”相匹配的价格&库存,您可以联系我们找货
