2.5mm Pitch Connector for Discrete Wire Connection
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF1 Series
■Features
1. Board Mounting Height (Crimping Type)
10mm 2.5mm pitch connector achieves the low profile.
2. Insulation Displacement Area Protected by Protector (ID Type)
The connector is structured to protect the insulation displacement connection area by the protector. Therefore, the connector
has a strong tensile strength against the cable and prevents dusts.
3. Easy Connection by Easy Tool (ID Type)
No expensive insulation displacement machine is needed. The connection can be established only by mating the cable into the protector
and fastening it with the ID tool.
4. Intermediate Connection Possible (ID Type)
For intermediate connection, the connector allows signal extraction during cabling.
[Intermediate Connection]
■Applications
FA equipment, measurement equipment
B176
DF1 Series●2.5mm Pitch Connector for Discrete Wire Connection
■Product Specifications
Current rating
Rating
Cable Size
(Note1)
Voltage rating
Operating Temperature Range
-30 to +85ç (Note2)
AWG 26 : 2A
Operating Moisture Range
-40 to 80%
AWG 28 : 1A
Storage Temperature Range
-10 to +60ç (Note3)
Storage Moisture Range
-40 to 70% (Note3)
250V AC
Item
AWG 24 : 3A
Specification
Condition
1. Insulation Resistance
1000M ohms Min
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
30m ohms Max
100mA
4. Insertor/Extraction Force
MIN0.56N (57gf), MAX4.4N(450gf)
Measure by the square steel pin with 0.635±0.002mm
5. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
6. Moisture Resistance
Contact resistance: 30m ohms Max Insulation resistance: 1000M ohms Min 96 hours at temperature of 40ç and humidity of 90% to 95%
7. Temperature Cycle
Contact resistance: 30m ohms max.Insulation resistance: 1000M ohms min.
8. Durability (Mating/un-mating) Contact resistance: 30m ohms max.
(-85ç: 30 minutes ➝ 5~35ç: 10 minutes) 5 cycles
Tin plating: 30 cycles
No deformation of components affecting performance.
9. Resistance to Soldering heat
(-55ç: 30 minutes ➝ 5~35ç: 10 minutes➝
Flow: 250ç for 10 seconds
Manual soldering: 300ç for 3 seconds
Note 1. The rated current will be changed according to cable sizes for use. For the header only, the rating is 3A.
Note 2: Includes temperature rise caused by current flow.
Note 3: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a
specific part number shown.
■Material
Product
Part
Crimping Socket
Crimping Contact
ID Socket
Pin Header
Material
Finish
Remarks
Insulator
Polyamide
Light Brown
UL94V-0
Contact
Phosphor copper
Tin plated
Insulator
Polyamide
Light Brown
UL94V-0
Contact
Phosphor copper
Tin plated
Insulator
Polyamide
Light Brown
UL94V-0
Contact
Phosphor copper
Tin plated
Note:Hirose's tin-plated products takes measures against whisker.
■Ordering Information
●Connector
DF1
q Series Name
- * S - 2.5 C
q
w
e
r
t
t Contact Type
: DF1
w Number of Contact : 2 to 16, 20
C
e Connector Type
R24
: AWG24 ID socket
S: Socket
R26
: AWG26 ID socket
R28
: AWG28 ID socket
DSA
: Straight through hole
P: Pin Header
r Contact Pitch
: 2.5mm
DS
●Protector
DF1
q Number of Contact : 2 to 16, 20
- * A 1.05
q
w
e
●Contact
DF1
w Connector Type
A: Discrete wire
q Applicable Cable Size
- 2428SCF
q
w
2428 : AWG 24 to 28
: Crimping socket
: Right angle through hole
e Cable Clamp Size
1.05: UL1007 AWG26, 28
1.33: UL1007 AWG24
w Packaging Type
SCF : Socket contact, reel packaging / Tin plated
SC : Socket contact, bag packaging / Tin plated
B177
■ID Socket (Open End Type)
●Applicable Cable
Part Number
Applicable Cable
Jacket Diameter
DF1-*S-2.5R24(05) UL1007 AWG24(11 pieces/0.16mm) 1.35 to 1.45mm
DF1-*S-2.5R26(05) UL1007 AWG26( 7 pieces/0.16mm) 1.25 to 1.35mm
Note:This convex portion is located (2 contacts: the center at one point)(3 to 6
contacts: as shown in the illustration)(more than 7 contacts: one center at
one point added to the above illustration).
DF1-*S-2.5R28(05) UL1007 AWG28( 7 pieces/0.127mm) 1.15 to 1.25mm
(Tin plated annealing copper wire)
●AWG24 Cable Socket Size (Triangle Mark: Green)
Part Number
DF1-2S-2.5R24(05)
DF1-3S-2.5R24(05)
DF1-4S-2.5R24(05)
DF1-5S-2.5R24(05)
DF1-6S-2.5R24(05)
DF1-7S-2.5R24(05)
DF1-8S-2.5R24(05)
DF1-9S-2.5R24(05)
Number of Contacts
CL No.
541-0039-2-05
2
541-0040-1-05
3
541-0041-4-05
4
541-0042-7-05
5
541-0043-0-05
6
541-0044-2-05
7
541-0045-5-05
8
541-0046-8-05
9
A
8
10.5
13
15.5
18
20.5
23
25.5
B
2.5
5
7.5
10
12.5
15
17.5
RoHS
Yes
Part Number
DF1-10S-2.5R24(05)
DF1-11S-2.5R24(05)
DF1-12S-2.5R24(05)
DF1-13S-2.5R24(05)
DF1-14S-2.5R24(05)
DF1-15S-2.5R24(05)
DF1-16S-2.5R24(05)
DF1-20S-2.5R24(05)
Number of Contacts
CL No.
A
28
541-0047-0-05
10
30.5
541-0048-3-05
11
33
541-0049-6-05
12
541-0050-5-05
35.5
13
38
541-0051-8-05
14
40.5
541-0052-0-05
15
43
541-0053-3-05
16
53
541-0057-4-05
B
22.5
25
27.5
30
32.5
35
37.5
47.5
Part Number
DF1-10S-2.5R26(05)
DF1-11S-2.5R26(05)
DF1-12S-2.5R26(05)
DF1-13S-2.5R26(05)
DF1-14S-2.5R26(05)
DF1-15S-2.5R26(05)
DF1-16S-2.5R26(05)
DF1-20S-2.5R26(05)
Number of Contacts
CL No.
A
28
541-0066-5-05
10
30.5
541-0067-8-05
11
33
541-0068-0-05
12
541-0069-3-05
35.5
13
38
541-0070-2-05
14
40.5
541-0071-5-05
15
43
541-0072-8-05
16
53
541-0076-9-05
B
22.5
25
27.5
30
32.5
35
37.5
47.5
Part Number
DF1-10S-2.5R28(05)
DF1-11S-2.5R28(05)
DF1-12S-2.5R28(05)
DF1-13S-2.5R28(05)
DF1-14S-2.5R28(05)
DF1-15S-2.5R28(05)
DF1-16S-2.5R28(05)
DF1-20S-2.5R28(05)
Number of Contacts
CL No.
A
28
541-0123-7-05
10
30.5
541-0124-0-05
11
33
541-0125-2-05
12
35.5
541-0126-5-05
13
38
541-0127-8-05
14
40.5
541-0128-0-05
15
43
541-0129-3-05
16
53
531-0133-0-05
B
22.5
25
27.5
30
32.5
35
37.5
47.5
●AWG26 Cable Socket Size (Triangle Mark: Light Blue)
Part Number
DF1-2S-2.5R26(05)
DF1-3S-2.5R26(05)
DF1-4S-2.5R26(05)
DF1-5S-2.5R26(05)
DF1-6S-2.5R26(05)
DF1-7S-2.5R26(05)
DF1-8S-2.5R26(05)
DF1-9S-2.5R26(05)
Number of Contacts
CL No.
541-0058-7-05
2
541-0059-0-05
3
541-0060-9-05
4
541-0061-1-05
5
541-0062-4-05
6
541-0063-7-05
7
541-0064-0-05
8
541-0065-2-05
9
A
8
10.5
13
15.5
18
20.5
23
25.5
B
2.5
5
7.5
10
12.5
15
17.5
RoHS
Yes
●AWG28 Cable Socket Size (Triangle Mark: Red)
Part Number
DF1-2S-2.5R28(05)
DF1-3S-2.5R28(05)
DF1-4S-2.5R28(05)
DF1-5S-2.5R28(05)
DF1-6S-2.5R28(05)
DF1-7S-2.5R28(05)
DF1-8S-2.5R28(05)
DF1-9S-2.5R28(05)
Number of Contacts
CL No.
541-0115-9-05
2
541-0116-1-05
3
541-0117-4-05
4
541-0118-7-05
5
541-0119-0-05
6
541-0120-9-05
7
541-0121-1-05
8
541-0122-4-05
9
A
8
10.5
13
15.5
18
20.5
23
25.5
B
2.5
5
7.5
10
12.5
15
17.5
RoHS
Yes
Note:A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag.
B178
Unit: mm
RoHS
Yes
Unit: mm
RoHS
Yes
Unit: mm
RoHS
Yes
■Protector
Note 1.Product contact No. mark, however 2 and 3 contacts are not indicated.
Note 2.Round hole to distinguish the protector A1.05 and 1.33 (DF1-*A1.05 only)
Select the protector after inspecting the cable jacket diameter for use.
Protector Type
Applicable Jacket Diameter
Recommended Cable
DF1-*A1.33
Ø1.35 to Ø1.45
UL1007 AWG24
DF1-*A1.05
Ø1.1 to Ø1.35
UL1007 AWG26 28
*indicates contact No.
●AWG24 Cable Protector Size
Number of Contacts
Part Number
CL No.
DF1- 2A1.33 541-0077-1
2
DF1- 3A1.33 541-0078-4
3
DF1- 4A1.33 541-0079-7
4
DF1- 5A1.33 541-0080-6
5
DF1- 6A1.33 541-0081-9
6
DF1- 7A1.33 541-0082-1
7
DF1- 8A1.33 541-0083-4
8
DF1- 9A1.33 541-0084-7
9
DF1-10A1.33 541-0085-0
10
DF1-11A1.33 541-0086-2
11
DF1-12A1.33 541-0087-5
12
DF1-13A1.33 541-0088-8
13
DF1-14A1.33 541-0089-0
14
DF1-15A1.33 541-0090-0
15
DF1-16A1.33 541-0091-2
16
DF1-20A1.33 541-0095-3
A
10
12.5
15
17.5
25
27.5
30
32.5
35
37.5
40
42.5
45
55
by the
Unit: mm ●AWG26, 28 Cable Protector Size
Number of Contacts
B
C RoHS
Part Number
CL No.
1.1
2.5
DF1- 2A1.05 541-0096-6
2
1.1
5
DF1- 3A1.05 541-0097-9
3
1.1
7.5
DF1- 4A1.05 541-0098-1
4
1.1
10
DF1- 5A1.05 541-0099-4
5
12.5 1.1
DF1- 6A1.05 541-0100-1
6
1.1
15
DF1- 7A1.05 541-0101-4
7
17.5 1.1
DF1- 8A1.05 541-0102-7
8
1.1
DF1- 9A1.05 541-0103-0
9
Yes
22.5 1.1
DF1-10A1.05 541-0104-2
10
1.1
25
DF1-11A1.05 541-0105-5
11
27.5 1.1
DF1-12A1.05 541-0106-8
12
1.1
30
DF1-13A1.05 541-0107-0
13
32.5 1.1
DF1-14A1.05 541-0108-3
14
1.1
35
DF1-15A1.05 541-0109-6
15
37.5 1.1
DF1-16A1.05 541-0110-5
16
47.5 1.1
DF1-20A1.05 541-0114-6
bag unit (100 pcs.). If needed, please order the product per
A
10
12.5
15
17.5
25
27.5
30
32.5
35
37.5
40
42.5
45
55
bag.
B
2.5
5
7.5
10
12.5
15
17.5
25
27.5
30
32.5
35
37.5
47.5
Unit: mm
C RoHS
0.7
0.7
0.7
0.7
0.7
0.7
0.7
0.7
Yes
0.7
0.7
0.7
0.7
0.7
0.7
0.7
0.7
B179
■Crimping Socket
Note1:This convex portion is located (2 contacts: the center at one point)(3 to 6 contacts: as shown in
the illustration)(more than 7 contacts: one center at one point added to the above illustration).
Note 2.The terminal number indicates all contact numbers.
Part Number
DF1- 2S-2.5C
DF1- 3S-2.5C
DF1- 4S-2.5C
DF1- 5S-2.5C
DF1- 6S-2.5C
DF1- 7S-2.5C
DF1- 8S-2.5C
DF1- 9S-2.5C
DF1-10S-2.5C
Note:A packaging
Number of Contacts
CL No.
541-0136-9
2
541-0137-1
3
541-0138-4
4
541-0139-7
5
541-0140-6
6
541-0141-9
7
541-0142-1
8
541-0143-4
9
541-0144-7
10
Number of Contacts
A
B
RoHS
Part Number
CL No.
A
2.5
8
541-0145-0
30.5
DF1-11S-2.5C
11
5
10.5
541-0146-2
33
DF1-12S-2.5C
12
541-0147-5
7.5
13
33.5
DF1-13S-2.5C
13
10
15.5
541-0148-8
38
DF1-14S-2.5C
14
Yes
12.5
18
541-0149-0
40.5
DF1-15S-2.5C
15
15
20.5
541-0150-0
43
DF1-16S-2.5C
16
17.5
23
541-0152-5
48
DF1-18S-2.5C
18
541-0154-0
53
DF1-20S-2.5C
28
bag unit (100 pcs.). If needed, please order the product per bag.
B
25
27.5
30
32.5
35
37.5
42.5
47.5
Unit: mm
RoHS
Yes
■Crimping Contact for Socket
Part Number
DF1-2428SCF
DF1-2428SC
1.85
CL No.
541-0134-3
541-0135-6
Packaging Type Number of Contacts
Finish
RoHS
Reel
10000
Tin plating Yes
Bag
100
●Applicable Cable (Tin Plated Annealing Copper Wire)
2.5
5.9
2.2
2.2
1.9
0.9 0.6 1.5
Photo: Contact Inserted.
Conductor Size (wire construction)
Jacket Diameter
AWG24 (11 cores/0.16mm)
AWG26 ( 7 cores/0.16mm)
Ø0.9 to Ø1.5mm
AWG28 (07 cores/1.24mm)
Note:If other cables are used instead of the applicable cable, contact Hirose sales
department.
●Recommended Cable
1.5
3
1.5
UL1061, UL1007
Ø 1.5
6.5
●Strip Length
1.9 to 2.4mm
BApplicable Crimping Tool
Type
Part Number
CL No.
Applicable Contact
Applicator
AP105-DF1-2428S
901-4538-8
DF1-2428SCF
Press Main Unit
CM-105
901-0005-4
--------------Manual Crimping Tool DF1-T2428S
550-0102-8
DF1-2428SC
Extraction Tool
Flat-bladed screwdriver, 0.75 mm max, blade width.
Note 1: If a trouble has occurred due to tools which are not designated by Hirose, Hirose
won't guarantee any product.
Note 2: Refer to tecknical specification for work method of extraction tool.
B180
■Pin Header Right Angle Type
●Board Through-hole Diameter : ø1.1++00.1
Number of Contacts A
Part Number
CL No.
B
C RoHS
Part Number
7.5 3.8 2.5
DF1- 2P-2.5DS(05) 541-0020-4-05
2
DF1-11P-2.5DS(05)
5
10 6.3
DF1- 3P-2.5DS(05) 541-0021-7-05
3
DF1-12P-2.5DS(05)
12.5 8.8 7.5
DF1- 4P-2.5DS(05) 541-0022-0-05
4
DF1-13P-2.5DS(05)
15 11.3 10
DF1- 5P-2.5DS(05) 541-0023-2-05
5
DF1-14P-2.5DS(05)
17.5 13.8 12.5 Yes DF1-15P-2.5DS(05)
DF1- 6P-2.5DS(05) 541-0024-5-05
6
20 16.3 15
DF1- 7P-2.5DS(05) 541-0025-8-05
7
DF1-16P-2.5DS(05)
22.5 18.8 17.5
DF1- 8P-2.5DS(05) 541-0026-0-05
8
DF1-18P-2.5DS(05)
25 21.3 20
DF1- 9P-2.5DS(05) 541-0027-3-05
9
DF1-20P-2.5DS(05)
27.5 23.8 22.5
DF1-10P-2.5DS(05) 541-0028-6-05
10
Note 1.A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please
Note 2.The socket applicable to the 18 contact connector is only crimping type.
Number of Contacts
CL No.
541-0029-9-05
11
541-0030-8-05
12
541-0031-0-05
13
541-0032-3-05
14
541-0033-6-05
15
541-0034-9-05
16
541-0036-4-05
18
541-0038-0-05
A
30
32.5
35
37.5
40
42.5
47.5
52.5
B
26.3
28.8
31.3
33.8
36.3
38.8
43.8
48.8
Unit: mm
C RoHS
25
27.5
30
32.5
Yes
35
37.5
42.5
47.5
B
26.3
28.8
31.3
33.8
36.3
38.8
43.8
48.8
Unit: mm
C RoHS
25
27.5
30
32.5
Yes
35
37.5
42.5
47.5
■Pin Header Straight Type
Part Number
CL No.
B
C RoHS
Part Number
CL No.
7.5 3.8 2.5
30
DF1- 2P-2.5DSA(05) 541-0001-0-05
2
DF1-11P-2.5DSA(05) 541-0010-0-05
11
5
10 6.3
32.5
DF1- 3P-2.5DSA(05) 541-0002-2-05
3
DF1-12P-2.5DSA(05) 541-0011-3-05
12
12.5 8.8 7.5
35
DF1- 4P-2.5DSA(05) 541-0003-5-05
4
DF1-13P-2.5DSA(05) 541-0012-6-05
13
15 11.3 10
37.5
DF1- 5P-2.5DSA(05) 541-0004-8-05
5
DF1-14P-2.5DSA(05) 541-0013-9-05
14
17.5 13.8 12.5 Yes DF1-15P-2.5DSA(05) 541-0014-1-05
40
DF1- 6P-2.5DSA(05) 541-0005-0-05
6
15
20 16.3 15
42.5
DF1- 7P-2.5DSA(05) 541-0006-3-05
7
DF1-16P-2.5DSA(05) 541-0015-4-05
16
22.5 18.8 17.5
47.5
DF1- 8P-2.5DSA(05) 541-0007-6-05
8
DF1-18P-2.5DSA(05) 541-0017-0-05
18
25 21.3 20
52.5
DF1- 9P-2.5DSA(05) 541-0008-9-05
9
DF1-20P-2.5DSA(05) 541-0019-5-05
DF1-10P-2.5DSA(05) 541-0009-1-05
10
Note 1.A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the product per bag.
Note 2.The socket applicable to the 18 contacts connector is only crimping type.
B181
BDF1 Connection Press
Part Number
CL No.
DF1 Connection Press HP513
550-0134-4
Height
Width
Depth
Weight
200mm 260mm 250mm
3.7kg
Note:The intermediate connection can be established by removing the
cable cuttingblade of this press machine.
Note:Select a protector after inspecting a cable Jacket diameter for use.
Protector Type
Applicable Jacket Diameter Recommended Cable
DF1-*A1.33
Ø1.35 to Ø1.45
UL1007 AWG24
DF1-*A1.05
Ø1.1 to Ø1.35
UL1007 AWG26, 28
* indicates contact No.
B182
BDF1 Cable Crimper
Part Number
CL No.
DF1 Cable Crimper
550-0130-3
DF1 Cable Crimper
Used to install the cable in the protector.
BPrecautions
1. Recommended Soldering Condition
2. Cleaning Condition
Refer to Nylon Connector Use Hand book.
3. Connection Condition
[Crimping]
[ID]
●For the insulation displacement tool, set a set of connector per insulation displacement. If more
than 2 connectors have been set, they interrupt each other, which will cause an insulation
displacement failure.
●After the insulation displacement, make sure that the locks on both protector sides are
completely activated.
4. Precation
Slight variations in color of the plastic compounds do not affect form, fit or function of the connector.
5. Precation
很抱歉,暂时无法提供与“DF1-10A1.33”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+1.7324910+0.22567
