DF21-20P-0.6SD-GND(05)
    HRS(广濑)
    CONN PLUG 20POS
DF21-20P-0.6SD-GND(05) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 0.6mm Pitch Board-to-Fine-Coaxial Cable Connectors DF21 Series (7) (4.55) Nov.1.2016 Copyright 2018 Dec.1.2018 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF21-*P-0.6SD(05) +DF21-*P-0.6SD-GND(05) DF21-*S-0.6V(56) ■Features 1.High Interconnection Reliability Effective contact mating length of 1.55 mm, innovative bellow style contact design, built-in interlocking feature of mated connectors assures high electrical and mechanical reliability, providing needed rigidity to resist excessive twisting. Superior reliability of the termination of the fine coaxial cable is accomplished with batch soldering. 2. Shielded design Metal shell encloses the connector and makes contact with all external conductors of the fine coaxial cable permitting reliable ground connection to the board side of mated assemblies. 3. Reliable mating/unmating The connectors are self-align during mating. Optional pull-out tab permits connection and disconnection in narrow spaces. Polarized configuration prevents incorrect mating. 4. Board placement with Automatic Equipment. The upper surface provides flat area for placement of embossed tape packaged connectors with vacuum nozzles of automatic equipment. ■Applications Notebook computers, liquid crystal displays (LCD), video and audio devices, medical instruments, portable devices and any other device requiring reliable connection and termination with fine pitch coaxial cable. Receptacle Flat surface for placement with Automatic Equipment Metal Hold-down B305 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the Connectors products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF21 Series●0.6mm Pitch Board-to-Fine-Coaxial Cable ■Product Specifications Operating temperature range Current rating Ratings AWG #40: 0.3 A AWG #36: 0.5 A Wire size Voltage rating 50 V AC Nov.1.2016 Copyright 2018 Dec.1.2018 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item 20% to 80% Storage temperature range -10ç to 60ç (Note 2) Storage humidity range 40% to 70% (Note 2) Specifications Condition 1. Insulation resistance 2. Withstanding voltage 3. Contact resistance 500M ohms min. No flashover or insulation breakdown 100m ohms max. Measured at 100 V DC Conduction of 150 V AC applied for 1 minute Measured at 100 mA 4. Vibration No electrical discontinuity of 1μs or more. Frequency of 10 to 55 Hz, single amplitude of 0.75 mm, in 3 directions, 2 hours 5. Humidity Contact resistance of 100m ohms max., insulation resistance of 50 M ohms min. Temperature of 40±2ç, humidity of 90% to 95%, left standing for 96 hours 6. Temperature cycle Contact resistance of 100m ohms max., insulation resistance of 50 M ohms min. (-55ç : 30minutes /5 to 35ç : 2 to 3minutes /85ç : 30minutes /5 to 35ç: 2 to 3minutes ) for 5 cycles 7. Durability Contact resistance of 100m ohms max. 30 cycles (mating/unmating) 8. Resistance to Reflow heat No melting of the resin parts that will affect performance Reflow: at the recommended temperature profile, Solder: at a soldering iron temperature of 300ç for 3 seconds 9. Resistance to Soldering heat No deformation of the insulator parts affecting performance. Solder bond: Within 5 seconds at 270ç max., Within 30 seconds at 200ç min. Hand soldering: Soldering iron temperature 300°C, 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials Item Part Insulator LCP Black UL94V-0 Receptacles Contacts Phosphor bronze Gold plating ---------- Metal fittings Phosphor bronze Tin copper plating ---------- Insulator LCP Black UL94V-0 Contacts Phosphor bronze Gold plating ---------- Metal shell Phosphor bronze Tin plating ---------- Metal shell Stainless steel Tin copper plating ---------- Plugs Metal shell Material Finish ■Ordering information ●Receptacles/Plug DF 21 - * P - 0.6 SD - GND 1 2 1 Series name : DF21 2 Number of contacts : 20, 30 3 3 Connector type S : Single-row receptacle P : Single-row plug 4 Contact pitch 4 5 6 5 Termination section V : Straight SMT SD : Fine coaxial cable 6 Plug mounting parts GND : Metal shell-required : 0.6 mm Note: The metal shell is an absolutely necessary part at the time of wiring. B306 -35ç to 85ç (Note 1) Operating humidity range Remarks The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on theDF21 Hirose website RoHS search atPitch www.hirose-connectors.com, or contact your Hirose sales representative. Series●0.6mm Board-to-Fine-Coaxial Cable Connectors ■Receptacles 3.8 3.2 0.2 A B 0.2 3 ●Embossed Carrier Tape Dimensions Ø1 .5 +1 .5 0 4±0.1 1.75±0.1 2±0.1 12±0.1 t=0.4±0.1 2±0.5 (Ø80) 0.2 0.8 Ø330±2 Ø13± E±0.3 D±0.1 C±0.1 Product name label Ø21± (E+0.4) +20 (E+6.4)MAX 3.8 Unreeling direction [Specifications number] - * *, (* *) (56) : Embossed tape packaging (1,000 pieces per reel) Unit: mm Product No. CL No. Number of Contacts A B C DF21-20S-0.6V(56) 687-0001-5-56 20 15.2 11.4 11.5 DF21-30S-0.6V(56) 687-0003-0-56 30 21.2 17.4 14.2 D 28.4 E F 24 12.6 32 18.6 RoHS YES Note : One reel contains 1,000 pieces package unit. Please order by the package unit. ●Recommended PCB mounting pattern B±0.03 0.35±0.02 1.6 +0.10 F±0.05 2.6±0.05 1.3 +0.10 P=0.6±0.03 2.3±0.05 Nov.1.2016 Copyright 2018 Dec.1.2018 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.4 P=0.6 P=0.6 B307 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the Connectors products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF21 Series●0.6mm Pitch Board-to-Fine-Coaxial Cable ■Plugs A B 4.45 Unit: mm Product No. CL No. Number of Contacts A B C DF21-20P-0.6SD(05) 687-1500-0-05 20 22.5 11.4 15 DF21-30P-0.6SD(05) 687-1502-6-05 30 28.5 17.4 21 YES ●Recommended Fine Coaxial Cable Preparation C±0.5 B±0.15 Pitch maintaining tape Inner conductor (Solder coating required) 0.4max 4.1MAX 2.75MIN 1.1 0 -0.3 P=0.6±0.1 Ground bar Insulator Fine coaxial cable 1: 2: 2: 3: 00.0 0.55 -0.05 1.1MIN Outer shield (for individual conductor) Note Note Note Note B308 RoHS Note 1 : One package unit contains 100 pieces. Please order by the package unit. Note 2: The metal shell is an absolutely necessary part at the time of wiring. 1.0 +0.10 -0.05 Nov.1.2016 Copyright 2018 Dec.1.2018 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.8 P=0.6 C±0.3 Jacket The pitch maintaining tape can be left in place during the termination process. Use high quality tape. When using 2-conductor coaxial cable, some contact positions will not be usable. Contact nearest Hirose sales office for recommendation on specific application. Contact Hirose for Termination Procedures. The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on theDF21 Hirose website RoHS search atPitch www.hirose-connectors.com, or contact your Hirose sales representative. Series●0.6mm Board-to-Fine-Coaxial Cable Connectors ■Metal shell-Required for assembly of the Plug Nov.1.2016 Copyright 2018 Dec.1.2018 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.75 A t=0.2 7 Unit: mm Product No. CL No. Number of Contacts A DF21-20P-0.6SD-GND(05) 687-2500-6-05 20 17.7 DF21-30P-0.6SD-GND(05) 687-2502-1-05 30 23.7 RoHS YES Note 1: One package unit contains 100 pieces. Please order by the package unit. Note 2: The metal shell is an absolutely necessary part at the time of wiring. B309 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the Connectors products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF21 Series●0.6mm Pitch Board-to-Fine-Coaxial Cable BUsage Recommendations 1. Recommended Temperature Profile Temperture(ç) 250 IR re-flow Preheating: 150 to160ç Soldering: 250ç 60 to 120 sec 220ç min. 20 to 40 sec 250ç max. 10 sec max. 220ç 200 Nov.1.2016 Copyright 2018 Dec.1.2018 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 150 60 sec max. 150ç 90 to 120 sec. 100 50 normal temperture 0 50 100 150 200 250 300 Time(S) Note 1: Up to 2 cycles of reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals (for surface mounted plug assembly). 1. Receptacle Recommended Soldering temperature: 340ç ±10°C, soldering time: within 5 sec. Manual Soldering Conditions 2. Recommended Screen Thickness 0.15mm 3. Board Warping Maximum of 0.03 mm at the connector center section, with both ends of the connector as reference points. 4. Cleaning Conditions Refer to "Nylon Connector Use Handbook." 5. Plug Recommended Soldering Conditions 6. Handling and use precautions 260ç ±5ç within 5 sec, 200ç min. within 25 sec. ■DO NOT mate/un-mate non-terminated plugs with non-mounted receptacles. This may lead to damage or deformation of the contacts. ■DO NOT touch the exposed contacts of the receptacle with bare fingers. This may leave non-conductive film, cause corrosion or electrostatic discharge, affecting performance of the connectors or sensitive electronic components. ■DO NOT apply flux to the contact terminals when hand soldering the receptacle to the board. Wicking of the flux into the electrical contact areas may lead to connection failures. B310 Powered by TCPDF (www.tcpdf.org)
DF21-20P-0.6SD-GND(05) 价格&库存
很抱歉,暂时无法提供与“DF21-20P-0.6SD-GND(05)”相匹配的价格&库存,您可以联系我们找货
