PQ50S-48P-PCM
PQ50S-48P-PCM
    HRS(广濑)
    CONNHDR
PQ50S-48P-PCM 数据手册
PQ50/PQ50S/PQ50W Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Power Supply/Signal Connectors for Industrial Equipment Sep. 2022 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Overview The PQ Series is an interface connector designed to handle high power/ signal connections in industrial equipment. Available in a wateproof or non- waterproof type, they are capable of handling up to 12. 5A/ pin ( PQ50S/ PQ50W) or 19A/ pin ( PQ50) . Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PQ50/PQ50S-36pos. Type PQ50S-48pos. Type PQ50W Series Variations Features [ Non- Waterproof Type] PQ50/ PQ50S Series 1. Side locking spring design delivers a clear tactile click. The left and right buttons disengage the mated lock. ( Side locking system) The easy mating operation delivers a clear tactile click. Side locking design emits a tactile click and produces a secure lock 2. Strengthened Cable Clamps Cable clamp strength is 98N or more. ( Actual value is 400N or more) The design prevents the mated connector and clamp from detaching against excessive forces. 3. Different cover options. A robust, enhanced, shielded die- cast shell is available on the PQ50- 20pos. / PQ50S36pos. or a engineered, light weight plated plastic resin shell for the PQ50S- 48pos. The die cast shell delivers an enhanced EMI shield on the PQ50- 20pos. / PQ50S- 36pos. and the plated plastic resin of the PQ50S- 48pos. cover case and panel shell ensure ESD and EMI performance. 2 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment 4. Coding key system provides flexibility with multiple options. The coding key system prevents incorrect mating and has multiple variations available. 5. Rear mounted panel shell is available. Panel Shell Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. After attaching the panel shell to the chassis, it is possible to install or remove the crimp housing. M3 Screw Housing Chassis Panel Female Contact It is possible to insert the terminated housing from the rear. 6. Reliable ground connection design. The crimp contacts can be mounted directly onto the panel shell with screws which enhances the grounding connections. JIS C2805 (R type, N type) or equivalent Easy and Reliable Ground Connection 7. Supports NFPA79 compliant cables ( with 600V capability) . ( PQ50 Series) Due to restrictions on the AWM cables by NFPA79 revision, the requirements of listed cables has increased for wires used in industrial machines in the U. S. A. This product complies with the restrictions and requirements of NFPA79. 3 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment [ Waterproof Type] PQ50W Series 1. Water Resistant ( IP65) Rated at IP65 when in the mated condition. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Special locking design. Special lever and cam design delivers easier operation and assists with the insertion and extraction of this connector. Unique Lever Lock Design 3. Rear mounted unit offers easy operations. Male and Female plastic crimp case can be installed from both the panel side metal shell and plug side. Panel Side Panel Side : Female Contact Plug Side : Male Contact Supports Rear Mounting of Unit 4. Metal plated cover with engineering plastic resin adds strength and EMI protection. This robust connector uses a metal plated material with specially engineered plastic for the cover and panel shell to ensure high ESD and EMI performance. 4 Plug Side Panel Side : Male Contact Plug Side : Female Contact PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment 5. Independent ground contact design. Secure grounding is accomplished by use of the plated plastic cover and the independent ground contacts. Independent Ground Contacts Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Independent ground contact design. 6. Coding Key System Provides Flexibility with Multiple Options The coding key system prevents incorrect mating and has multiple variations available. 5 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment [ Contact Variations] 1. Available Contact Options Two styles are available; one with 19A/ pin contacts or one with 12. 5A/ pin contacts. 2. Lance Protection Design 【19A/ pin Type】 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The wall on the side of the contact prevents lance deformation and entanglement between contacts. Female Contact Lance Male Contact Lance Protection Guard 【12.5A/ pin Type】 Lance Female Contact Male Contact Lance Protection Guard Lance protection design 3. Sequential Contacts of Different Length are Available [ 19A/pin Type ] Two types of different contact length are available for the male contact. Sequence Contact (Long) Standard Contact 1.2mm [ 12.5A/pin Type ] Sequence Contact (Long) 1.2mm Standard Contact Sequential Contacts with Differing Lengths 4. Highly Reliable Contact Design [ 19A/pin Type ] 3 Point Contact [ 12.5A/pin Type ] 2 Point Contact Multi- point female contact with spring design provides high contact reliability. Spring Deflection Spring Deflection Multiple contact points and flexible spring design 5. Can Use Contacts Between Multiple Series The contacts for PQ50WA and PQ50WT are inter ー compatible. The crimping equipment and parts can also be used interchangeably. 6 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Product Specifications [Non-waterproof Type] PQ50 Series Rated Current Rated Voltage wi th UL1015, 16 AWG (Note 1) Operating Temperature (Note 2) -40 to +105℃ 19A Storage Temperature -55 to +85℃ 600V AC/DC Note 1 : Depends on cable current capacity. Note 2 : Includes temperature rise due to current flow. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions Contact Resistance 10m Ω Max. (Excluding conductor resistance of the cable.) Measured at 100mA Insulation Resistance Minimum of 5,000M Ω Measured at 500V DC Withstand Voltage No insulation breakdown Apply 2,200V AC for 1 min. Mating Durability Contact resistance : Increase by 20m Ω or less from the initial value. 500 times Frequency 10 to 55Hz (5 min/cycle). Vibration Resistance No electrical discontinuity of 10μ s or more. No broken, cracked or loosened parts. Shock Resistance With half amplitude 0.75mm, 2 hours each for 3 directions. Acceleration : 490m/s2, Duration : 11ms, Sine Half-wave : 3 times each in 6 axial directions Temperature Cycles Change of contact resistance : 20m Ω or less No broken, cracked or loosened parts. Temperature : -55 → +15 to 35 → +105 → +15 to +35℃ Time : 30 → 2 to 3 → 30 → 2 to 3 min. for 5cycles Moisture Resistance in Steady State Change of contact resistance : 20m Ω Max. Insulation resistance: minimum of 1,000M Ω (after drying). No breakage, cracks or loosened parts. Left in environment of 60℃± 2 and humidity of 90 to 95% for 96 hours. Salt Water Spray No significant corrosion or damage that impairs functioning. 5% concentration of salt water spray for 48 hours.(in mated condition) Note : For test methods not described here, JIS C 5402 is applied. 7 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment [Non-waterproof Type] PQ50S Series Rated Current Rated Voltage wi th UL1007, 18 AWG (Note 1) Operating Temperature (Note 2) -40 to +105℃ 12.5A Storage Temperature -55 to +85℃ 300V AC/DC Note 1 : Depends on cable current capacity. Note 2 : Includes temperature rise due to current flow. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions Contact Resistance 5m Ω Max. (Excluding conductor resistance of the cable.) Measured at 100mA Insulation Resistance Minimum of 5,000M Ω Measured at 500V DC Withstand Voltage No insulation breakdown Apply 2,200V AC for 1 min. Mating Durability Contact resistance : Increase by 10m Ω or less from the initial value. 500 times Vibration Resistance No electrical discontinuity of 10μ s or more. No broken, cracked or loosened parts. Shock Resistance Frequency 10 to 55Hz (5 min/cycle) With half amplitude 0.75mm, 2 hours each for 3 directions. Acceleration : 490m/s2, Duration : 11ms, Sine Half-wave : 3 times each in 6 axial directions Temperature Cycles Change of contact resistance : 10m Ω or less No broken, cracked or loosened parts. Temperature : -55 → +15 to 35 → +105 → +15 to +35℃ Time : 30 → 2 to 3 → 30 → 2 to 3 min. for 5cycles Moisture Resistance in Steady State Change of contact resistance : 10m Ω or less Insulation resistance : Minimum of 1,000M Ω (after drying). No broken, cracked or loosened parts. Left in environment of 60℃± 2 and humidity of 90 to 95% for 96 hours. Salt Water Spray No significant corrosion or damage that impairs functioning. 5% concentration of salt water spray for 48 hours. (in mated condition) Note : For test methods not described here, JIS C 5402 is applied. 8 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment [Wateproof Type] PQ50W Series Rated Current Rated Voltage wi th UL1007, 18 AWG (Note 1) Operating Temperature (Note 2) -40 to +105℃ 12.5A Storage Temperature -55 to +85℃ 300V AC/DC Note 1 : Depends on cable current capacity. (With 12.5A/pin type contacts) Note 2 : Includes temperature rise due to current flow. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions Contact Resistance 5m Ω max (Excluding conductor resistance of the cable.) Measured at 100mA Insulation Resistance Minimum of 5,000M Ω Measured at 500V DC Withstand Voltage No insulation breakdown Apply 2,200V AC for 1 min.. Mating Durability Contact resistance : Increase by 10m Ω or less from the initial value. 500 times Vibration Resistance No electrical discontinuity of 10μ s or more. No broken, cracked or loosened parts. Shock Resistance Frequency 10 to 55Hz (5 min/cycle) With half amplitude 0.75mm, 2 hours each for 3 directions. Acceleration : 490m/s2, Duration : 11ms, Sine Half-wave : 3 times each in 6 axial directions Temperature Cycles Change of contact resistance : 10m Ω or less No broken, cracked or loosened parts. Temperature : -55 → +15 to 35 → +105 → +15 to +35℃ Time : 30 → 2 to 3 → 30 → 2 to 3 min. for 5cycles Moisture Resistance in Steady State Change of contact resistance : 10m Ω or less Insulation resistance : 1,000M Ω or more (after drying) No broken, cracked or loosened parts. Left in environment of 60℃± 2 and humidity of 90 to 95% for 96 hours. Salt Water Spray No significant corrosion or damage that impairs functioning. 5% concentration of salt water spray for 48 hours. (in mated condition) Water Resistance IP65 Note : For test methods not described here, JIS C 5402 is applied. 9 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Materials / Finish ● PQ50 Series, PQ50S-36pos. Type Item Receptacle Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug Parts Materials Crimp Case PBT Resin Black Panel Shell Zinc Die Cast Nickel Plating Crimp Case PBT Resin Black Crimp Case Shell Stainless Steel Cover Case Zinc Die Cast M4 Pan Head Machine Screw Steel Clamp Metal Steel Crimp Case PBT Resin In-line Plug Shell In-line Plug M4 Pan Head Machine Screw Steel Clamp Metal Steel Right Angle Plug UL94V-0 UL94V-0 Nickel Plating - Black UL94V-0 Nickel Plating - Type Item Plug Remarks Zinc Die Cast In-line Cover Case ● PQ50S-48pos. Receptacle Finish Parts Materials Finish Crimp Case PBT Resin Black Panel Shell Heat-resistant Engineering Plastic Resin M4 Insert Nut Brass Crimp Case PBT Resin Crimp Case Shell Stainless Steel Cover Case Heat-resistant Engineering Plastic Resin M4 Pan Head Machine Screw Steel Clamp Metal Steel M4 Insert Nut Brass Crimp Case PBT Resin Crimp Case Shell Stainless Steel Cover Case Heat-resistant Engineering Plastic Resin M4 Pan Head Machine Screw Steel Cable Clamp PBT Resin Black M4 Insert Nut Brass Nickel Plating Nickel Plating Black Remarks UL94V-0 UL94V-0 UL94V-0 Nickel Plating - Black UL94V-0 - Nickel Plating UL94V-0 - 10 UL94V-0 - PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment ● PQ50W Series Item Parts Crimp case Receptacle Materials Crimp Case PBT Resin Panel Shell Heat-resistant Engineering Plastic Resin Ground Contact Stainless Steel O-ring for Mating NBR Lock Lever PA Resin Rubber Packing NBR Plug Shell Heat-resistant Engineering Plastic Resin Black Ground Contact Stainless Steel Nickel Plating Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M2 Tapping Screw Gasket Clamp Metal (Body) Cable Clamp UL94V-0 UL94V-0 Trivalent Chromate - Nickel Plating Black Steel UL94V-0 Nickel Plating (PQ50/PQ50S/PQ50W) Part No. PQ50-15PCFA PQ50A-15PCFA PQ50-15SCFA PQ50-1618PCFA PQ50A-1618PCFA PQ50-1618SCFA PQ50-2022PCFA PQ50A-2022PCFA PQ50-2022SCFA PQ50S-1822PCFA PQ50SA-1822PCFA PQ50S-1822SCFA PQ50S-2428PCFA PQ50SA-2428PCFA PQ50S-2428SCFA Black Heat-resistant Engineering Plastic Resin M3 Pan Head Machine Screw UL94V-0 - Red Brass Remarks UL94V-0 Nickel Plating NBR M4 Insert Nut ● Contacts Black Steel Cover Case Plug Finish Parts Materials Finish Male Contact Female Contact Male Contact Female Contact Male Contact Copper Alloy Female Contact Male Contact Female Contact Male Contact Female Contact 11 Gold Plating (Contact Area) + Tin Plating (Barrel Area) - PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Crimp Housing PQ 50 W S - 25 P - UNIT Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❶ Series Name PQ ❷ Termination Style Crimping ❸ Connector Specifications ❹ Contact Size ❻ ❼ ❺ Shell Size 20 : 20pos. unit 25 : 25pos. unit 48 : 48pos. unit W : Waterproof Type None : Non-waterproof Type ❻ Contact Gender P : Male Contact S : Female Contact S : Small Contact (12.5A/pin) Type None : Standard Contact (19A/pin) Type   ❼ Body UNIT : Rear mount multiple unit (PQ50W) None : Rear mount multiple unit (PQ50, PQ50S) ❺ Applicable Cable Type 15 : 14 to 15 AWG 1618 : 16 to 18 AWG 1822 : 18 to 22 AWG 2022 : 20 to 22 AWG 2428 : 24 to 28 AWG ■ Crimp Contact PQ 50 S A - 1822 PC F A ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❶ Series Name PQ ❷ Termination Style Crimping ❸ Contact Size S : Small Contact (12.5A/pin) Type None : Standard Contact (19A/pin) Type ❻ Contact Gender PC : Male Contact SC : Female Contact ❹ Contact Usage A : Sequence Contact (Long Contact) None : Standard Contact ❼ Contact Shapes F : Reel Contact None : Loose Contact ❽ Contact Plating Type A : Gold Plating (Contact Area) 12 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment ■ Clamp Metal, Cable Clamp PQ W - CM (17.5) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❶ Series Name PQ ❷ Connector Specifications W : Waterproof Type None : Non-waterproof Type ❸ Clamp Name CM : Clamp Metal, Cable Clamp CML : Cable Clamp for Right Angle ❹ Applicable Cable Diameter (15.0) : For applicable cable diameter φ 15.0 (17.5) : For applicable cable diameter φ 17.5 (22.0) : For applicable cable diameter φ 22.0 ❺ Contact Gender P : Male Contact S : Female Contact ■ PQ50/PQ50S Series PQ 50 S - 48 P - PC MA ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Series Name PQ ❷ Termination Style Crimping ❸ Contact Size S : Small Contact (12.5A/pin) Type None : Standard Contact (19A/pin) Type ❻ Case Type PC : Plug Cover Case JC : In-line Plug Cover Case FL : Panel Shell DS : In-line Plug Shell PCL : Right Angle Plug Cover Case ❹ Shell Size 20 : 20pos. Shell Type 48 : 48pos. Shell Type ❼ Case Material MA : Heat-resistant Engineering Plastic Resin None : Zinc Die Cast ■ PQ50W Series PQ 50 W - 50 - PCA ❶ ❷ ❸ ❹ ❺ ❶ Series Name PQ ❹ Shell Size 50 : 50pos. Shell Type ❷ Termination Style Crimping ❺ Case Type ❸ Connector Specifications Waterproof Type PCA : Plug Cover Case FLA : Panel Shell 13 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Functional Diagram Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● PQ50 Series, PQ50S-36pos. Type ①Panel Mount Receptacle (Female Contact) ● PQ50S-48pos. ②Cable Plug (Male Contact) ③In-line Cable Plug (Female Contact) Type ②Cable Plug (Male Contact)  Straight ①Panel Mount Receptacle (Female Contact) ● PQ50W ③Cable Plug (Male Contact) Right Angle Series ①Panel Mount Receptacle ②Cable Plug 14 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Panel Mount Receptacle 27.8 25.6 13 1.7 8.6 18.6 27.0 28.4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (P=4.6) 27.1 18.4 9.2 (P=6.2) 6.2 PQ50 Series ● Crimp Case (19A/pin for Female Contact) (39.4) Part No. HRS No. Purchase Unit PQ50-20S CL0236-2014-2-00 50pcs per box PQ50-20S(01) CL0236-2014-2-01 1pc per box 15 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment 19.4 38.6 21.0 3.0 38.4 48.0 31.2 31.2 27.2 (Intersection) 2-M4×0.7 (Through Hole) 46.6 2-M3×0.5 (Through Hole) Panel Mounting Dimensions 22.1±0.3 16.6±0.1 . ax M R2 16.6±0.1 21±0.3 33.2±0.3 33.2±0.3 28.4±0.3 51.5±0.1 x. Ma 51.5±0.1 0.2 4.3± 2-φ 2-M3×0.5 (Through Hole) R2 48.6±0.3 Recommended panel dimensions for attaching panel shell from panel’s back side. 40.6±0.3 MMA aXx . 40.6±0.3 R2 Ma x. Recommended panel dimensions for attaching panel shell from panel’s front side. R2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10.7 43.2 63.0 51.5 48.0 38.6 13.2 (Intersection) 10.5 Shell 21.0 (Intersection) ● Panel Part No. HRS No. R2 R2 M ax M . Purchase Unit PQ50-20S-FL CL0236-2001-0-00 50pcs per box PQ50-20S-FL(01) CL0236-2001-0-01 1pc per box 16 ax . PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Cable Plug 12.8 8.8 18.6 28.6 33.3 (48.8) Part No. HRS No. Purchase Unit PQ50-20P CL0236-2011-4-00 50pcs per box PQ50-20P(01) CL0236-2011-4-01 1pc per box ● Plug Cover Case 2 27.0 (16.0) JIS B 1188 M4×0.7×16 34.2 42.8 M4×0.7×8.1 φ 4. 56.5 64.0 3 M4×0.7×9.0 48.8 33.2 28.0 17.6 11.5 12.5 15.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (P=4.6) 27.0 18.4 9.2 (P=6.2) 6.2 PQ50 Series ● Crimp Case (19A/pin for Male Contact) R1 2. Part No. 5 HRS No. Purchase Unit PQ50-20P-PC CL0236-2000-8-00 100pcs per box PQ50-20P-PC(01) CL0236-2000-8-01 2pcs per box 17 Remarks Use 2pcs per set. 50 sets of plug cover cases. 1 set of plug cover case M4×0.7 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment In-Line Cable Plug PQ50 Series ● In-line Plug Cover Case 2 (16.0) JIS B 1188 M4×0.7×16 38.6 42.8 M4×0.7×8.1 φ 4. 56.5 64.0 M4×0.7×9.0 17.6 11.5 33.2 28.0 12.5 15.1 48.8 R1 2. Part No. HRS No. Purchase Unit PQ50-20S-JC CL0236-2002-3-00 100pcs per box PQ50-20S-JC(01) CL0236-2002-3-01 2pcs per box ● In-line 5 Remarks Use 2pcs per set. 50 sets of In-line plug cover cases. 1 set of In-line plug cover case Plug Shell 40.5 38.6 27.2 Part No. 33.0 31.2 33.1 10.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 HRS No. Purchase Unit PQ50-20S-DS CL0236-2015-5-00 50pcs per box PQ50-20S-DS(01) CL0236-2015-5-01 1pc per box 18 M4×0.7 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Cable Plug (48.8) Part No. PQ50S-36P HRS No. Purchase Unit CL0236-2123-0-00 50pcs per box Note : For the cover case, select PQ50-20P-PC for the PQ50 Series. Panel Mount Receptacle PQ50S-36pos. Type ● Crimp Case (12.5A/pin for Female Contact) 8.6 27.95 25.75 13.15 (P=4.05) (P=3.9) 27.1 (19.5) (20.25) 27 28.4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.8 33.3 8.8 27 19.5 20.25 28.6 P=3.9 4.05 PQ50S-36pos. Type ● Crimp Case (12.5A/pin for Male Contact) (39.4) Part No. PQ50S-36S HRS No. CL0236-2122-0-00 Purchase Unit 50pcs per box Note : For the cover case, select PQ50-20S-FL for the PQ50 Series. 19 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Cable Plug 3.75 1 A 2 3 4 5 6 12.8 8.8 19.25 28.6 HGFEDCBA1 2 3 4 5 6 33.3 B C D E F G H (P=3.85) PQ50S-48P (55.8) Part No. HRS No. Purchase Unit PQ50S-48P CL0236-2023-3-00 60pcs per box PQ50S-48P(01) CL0236-2023-3-01 1pc per box ● Plug Cover Case (16.0) JIS B 1188 M4×0.7×16 50.0 φ M4×0.7 M4×0.7×6.5 4. 64.0 79.0 3 M4×0.7×6.5 56.0 17.6 38.2 28.0 17.6 14.0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (P=3.75) 3.85 34.0 26.25 18.75 11.25 11.55 PQ50S-48pos. Type ● Crimp Case (12.5A/pin for Male Contact) 5 2. R1 Part No. HRS No. Purchase Unit PQ50S-48P-PCMA CL0236-2129-0-00 60pcs per box PQ50S-48P-PCMA(01) CL0236-2129-0-01 1pc per box 20 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment PQ50S-48pos. Type ● Right Angle Plug Cover Case 56 59 (16) JIS B 1188 M4×0.7×16 M4×0.7 (80.5) 10.5 M4×0.7×6.5 75 7. R1 Part No. PQ50S-48P-PCLMA HRS No. Purchase Unit CL0236-2131-0-00 12pcs per box Cable Clamp PQ50S-48pos. Type For Right Angle Plug Cover Case ● Cable Clamp (φ17.5) JIS B 1111 M3×0.5×10 Part No. PQ-CML(17.5) HRS No. CL0236-2079-8-00 (3) (10) 4 6. φ R35 .5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (35.2) 50 20 Purchase Unit 12pcs per bag 21 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Panel Mount Receptacle PQ50S-48pos. Type ● Crimp Cace (12.5A/pin for Female Contact) 34.1 27.95 26.25 P=3.75 11.25 25.75 P=3.85 11.55 18.75 13.15 1.7 G F E D C B A 2 8.6 28.4 1 19.25 27.0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. H 3 4 5 6 PQ50S-48S (46.4) Part No. HRS No. Purchase Unit PQ50S-48S CL0236-2024-6-00 60pcs per box PQ50S-48S(01) CL0236-2024-6-01 1pc per box 22 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment ● Panel Shell 69.7 58.5 56 (Intersection) 7.6 14.8 45.6 21.8 10.7 M4×0.7×6.5 35.1 (Intersection) 49.4 57.6 56 (Intersection) Panel Mounting Dimensions Recommended panel dimensions for attaching panel shell from panel’s back side. x. Recommended panel dimensions for attaching panel shell from panel’s front side. Part No. HRS No. 22.8±0.3 33.2±0.3 2-φ4.3±0.2 R2 Max. 16.6±0.1 Ma 59.6±0.3 47.6±0.3 21.8±0.3 R2 Max. 58.5±0.1 2-M3×0.7 (Through Hole) 33.2±0.3 47.6±0.3 R2 Max. R2 58.5±0.1 16.6±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 31.2 11.3 45.6 36.3±0.3 R2 Max. R2 Max. Purchase Unit PQ50S-48S-FLMA CL0236-2130-0-00 60pcs per box PQ50S-48S-FLMA(01) CL0236-2130-0-01 1pc per box 23 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Clamp Metal PQ50/PQ50S Series ● Clamp Metal for φ15.0mm Cable Type 37.16 JIS B 1188 M4×0.7×12 (12.0) 2-4.4 10.0 15 Part No. HRS No. Purchase Unit PQ-CM(15.0) CL0236-2005-1-00 60pcs per bag PQ-CM(15.0)(01) CL0236-2005-1-01 1pc per box ● Clamp Metal for φ22.0mm Cable Type 37.16 2-4.4 M4×0.7 1.5 45.4 27.0 (12.0) JIS B 1188 M4×0.7×12 22 Part No. HRS No. 10.0 11.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.5 1.6 45.4 23.5 M4×0.7 Purchase Unit PQ-CM(22.0) CL0236-2013-0-00 50pcs per bag PQ-CM(22.0)(01) CL0236-2013-0-01 1pc per box 24 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Cable Plug PQ50W Series ● Crimp Case (12.5A/pin for Male Contact) Part No. PQ50WS-25P-UNIT ● Crimp No.A1 No.E1 No.A5 No.E5 23.9 7.4 14.8 24.9 16.85 20.6 HRS No. Purchase Unit CL0236-2021-8-00 50pcs per box Case (12.5A/pin for Female Contact) 19.5 15 7.5 Part No. PQ50WS-25S-UNIT HRS No. CL0236-2022-0-00 25 No.E1 No.A1 No.E5 No.A5 23.9 16.85 20.6 7.4 14.8 24.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 19.5 15 7.5 Purchase Unit 50pcs per box PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Panel Mount Receptacle 34.9 35.8 PQ50W Series ● Panel Shell (36.3) PQ50W 44.3 65.8 Panel Mounting Dimensions Panel dimensions for attaching panel shell from panel’s front side. 58.8±0.1 50.0±0.1 27.4±0.1 MaxR2.5 23.4±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (5.0) (28.0) (102.0) 4-M3 (Through Hole) Part No. PQ50W-50-FLA HRS No. CL0236-2132-0-00 Purchase Unit 20pcs per box 26 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Cable Plug PQ50W Series ● Cover Case (2.45) 55.5 Part No. PQ50W-50-PCA HRS No. 31 35.9 Purchase Unit CL0236-2133-0-00 10pcs per box Cable Clamp PQ50W Series ● Cable Clamp (φ17.5, φ15.0) 34 35.5 27 28 (3) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 65.5 80.5 31.5 Part No. HRS No. PQW-CM(17.5) CL0236-2019-6-00 PQW-CM(15.0) CL0236-2104-0-00 Purchase Unit 25pcs per tray 27 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Crimp Contact ● Male Contact (19A/pin Type) PQ50A-##PC#A Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.2 3.0 Part No. HRS No. Purchase Unit 24.35 23.15 PQ50-##PC#A 0.9 3.8 2.2 0.9 3.0 3.8 Applicable Cables PQ50-15PCFA (Note) CL0236-2016-8-00 14 to 15 AWG insulator outer diameter Max. φ 3.3mm PQ50A-15PCFA (Note) CL0236-2073-1-00 14 to 15 AWG insulator outer diameter Max. φ 3.3mm PQ50-1618PCFA CL0236-2006-4-00 PQ50A-1618PCFA CL0236-2007-7-00 PQ50-2022PCFA CL0236-2031-1-00 20 to 22 AWG insulator outer diameter Max. φ 2.7mm PQ50A-2022PCFA CL0236-2032-4-00 20 to 22 AWG insulator outer diameter Max. φ 2.7mm PQ50-15PCA CL0236-2037-8-00 14 to 15 AWG insulator outer diameter Max. φ 3.3mm PQ50A-15PCA CL0236-2073-1-00 14 to 15 AWG insulator outer diameter Max. φ 3.3mm PQ50-1618PCA CL0236-2038-0-00 PQ50A-1618PCA CL0236-2040-2-00 PQ50-2022PCA CL0236-2039-3-00 20 to 22 AWG insulator outer diameter Max. φ 2.7mm PQ50A-2022PCA CL0236-2041-5-00 20 to 22 AWG insulator outer diameter Max. φ 2.7mm 3,500pcs per reel 100pcs per bag Note: Please see ATAI-E2926 for details on UL1015, 14 AWG cable crimping. 28 16 to 18 AWG insulator outer diameter Max. φ 3.3mm 16 to 18 AWG insulator outer diameter Max. φ 3.3mm 16 to 18 AWG insulator outer diameter Max. φ 3.3mm 16 to 18 AWG insulator outer diameter Max. φ 3.3mm PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Contact (19A/pin) Type 18.9 ● Female 2.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.0 Part No. HRS No. Purchase Unit 3.9 Applicable Cables PQ50-15SCFA (Note) CL0236-2017-0-00 14 to 15 AWG insulator outer diameter Max. φ 3.3mm PQ50-1618SCFA CL0236-2008-0-00 PQ50-2022SCFA CL0236-2010-1-00 20 to 22 AWG insulator outer diameter Max. φ 2.7mm PQ50-15SCA CL0236-2043-0-00 14 to 15 AWG insulator outer diameter Max. φ 3.3mm PQ50-1618SCA CL0236-2044-3-00 PQ50-2022SCA CL0236-2045-6-00 3,500pcs per reel 100pcs per bag 16 to 18 AWG insulator outer diameter Max. φ 3.3mm 16 to 18 AWG insulator outer diameter Max. φ 3.3mm 20 to 22 AWG insulator outer diameter Max. φ 2.7mm Note : Please see ATAI-E3038 for details on UL1015, 14 AWG cable crimping. 29 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment ● Male Contact (12.5A/pin Type) PQ50S-####PC#A PQ50SA-####PC#A Applicable Cable No. Part No. HRS No. 24.4 1.35 0.7 2.15 2.25 Purchase Unit 1.35 2.15 0.7 2.25 Applicable Cables PQ50S-1618PCFA CL0236-2094-0-00 16 to 18 AWG insulator outer diameter Max. φ 2.25mm PQ50S-1822PCFA CL0236-2025-9-00 18 to 22 AWG insulator outer diameter Max. φ 2.25mm PQ50SA-1822PCFA CL0236-2029-0-00 PQ50S-2428PCFA CL0236-2027-4-00 24 to 28 AWG insulator outer diameter Max. φ 1.8mm PQ50SA-2428PCFA CL0236-2030-9-00 24 to 28 AWG insulator outer diameter Max. φ 1.8mm PQ50S-1822PCA CL0236-2046-9-00 18 to 22 AWG insulator outer diameter Max. φ 2.25mm PQ50SA-1822PCA CL0236-2048-4-00 PQ50S-2428PCA CL0236-2047-1-00 PQ50SA-2428PCA CL0236-2049-7-00 100pcs per bag 18 to 22 AWG insulator outer diameter Max. φ 2.25mm 18 to 22 AWG insulator outer diameter Max. φ 2.25mm 24 to 28 AWG insulator outer diameter Max. φ 1.8mm 24 to 28 AWG insulator outer diameter Max. φ 1.8mm Contact (12.5A/pin Type) 2.15 Part No. HRS No. PQ50S-1618SCFA CL0236-2095-0-00 PQ50S-1822SCFA CL0236-2026-1-00 PQ50S-2428SCFA CL0236-2028-7-00 PQ50S-1822SCA CL0236-2050-6-00 PQ50S-2428SCA CL0236-2051-9-00 Purchase Unit Applicable Cable No. 1822S ● Female 6,000pcs per reel 17.8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 23.2 Applicable Cable No. 2.15 2.25 Applicable Cables 16 to 18 AWG insulator outer diameter Max. φ 2.25mm 6,000pcs per reel 18 to 22 AWG insulator outer diameter Max. φ 2.25mm 24 to 28 AWG insulator outer diameter Max. φ 1.8mm 100pcs per bag 30 18 to 22 AWG insulator outer diameter Max. φ 2.25mm 24 to 28 AWG insulator outer diameter Max. φ 1.8mm PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Coding Key System ● For 19A/pin Type Crimp Case 3 2.9 5.95 27.7 24.8 HRS No. PQ50-SC-KY ● For Purchase Unit CL0236-2009-2-00 100pcs per bag 12.5A/pin Type Crimp Case 2.23 27.8 3.05 1.8 23.7 Part No. PQ50S-SC-KY HRS No. Purchase Unit CL0236-2033-7-00 100pcs per bag Extraction Tool ● 19A/pin Type for Crimp Case φ7.0 80.0 PQ50/RE-MD Part No. PQ50/RE-MD ● HRS No. Purchase Unit CL0902-2201-0-00 1pc per box 12.5A/pin Type for Crimp Case 75.0 φ10.0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. PQ50S/RE-MD Part No. PQ50S/RE-MD HRS No. CL0902-2202-2-00 Purchase Unit 1pc per box 31 PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment Pin Push Inspection Tool ● 12.5A/pin Type for Crimp Case 80.0 φ12.0 6.3 Part No. HRS No. PQ50S/IN-MD Purchase Unit CL0902-2538-0-00 1pc per box Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note : Used to confirm whether the contact is securely mated to the housing when connecting. Contact Crimping Tool For details, refer to the crimping tool list in the PQ series product selection guide ( ETAD- E3254- 00) . Automatic Crimping Machine/Applicator for Automatic Crimping Machine Please contact a Hirose sales representative. Manual Crimping Tool Please purchase a compatible frame and tooth profile unit according to the cable you are using. Applicable Frame Switch wire crimper and insulation crimper die according to the wire size being used. Part No. HT702 HRS No. Remarks CL0250-1001-1-00 Frame only, tooth profile unit sold separately About Guidelines ・Refer to the PQ series design and handling manual ( ETAD- E3230- 00) for product handling and precautions for equipment design. ・Please refer to the PQ series product selection guide ( ETAD- E3254- 00) if you are having trouble selecting a product. 32 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PQ50/PQ50S/PQ50W Series/Power Supply/Signal Connectors for Industrial Equipment While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 8/ 2022. Contents are subject to change without notice for the purpose of improvements. 33
PQ50S-48P-PCM
物料型号:HRS HLEOSRIO CO., LTD. 推出了PQ50/PQ50S/PQ50W系列,这些是为工业设备设计的电源/信号连接器。
器件简介:PQ系列接口连接器适用于处理工业设备中的高功率/信号连接。它们有防水和非防水类型,能够处理每个引脚高达12.5A(PQ50S/PQ50W)或19A(PQ50)的电流。
引脚分配:文档中提到了36位、48位等不同配置的连接器类型。
参数特性: - 额定电流:PQ50系列为19A/引脚,PQ50S/PQ50W系列为12.5A/引脚。 - 额定电压:PQ50系列为600V AC/DC,PQ50S/PQ50W系列为300V AC/DC。 - 工作温度范围:-40至+105°C。 - 还提供了接触电阻、绝缘电阻、耐电压、插拔耐久性等详细电气性能参数。
功能详解: - 防水型(PQ50W系列)具有IP65等级的防护能力。 - 特殊的锁定设计和易于操作的后置安装单元。 - 金属镀层的工程塑料外壳增加了强度和电磁干扰(EMI)保护。
应用信息:PQ系列连接器支持NFPA79合规电缆(PQ50系列具有600V的承载能力),适用于美国工业机器中使用的电线。
封装信息:文档提供了详细的材料和表面处理信息,例如PBT树脂、锌压铸、镍电镀等。
PQ50S-48P-PCM 价格&库存
很抱歉,暂时无法提供与“PQ50S-48P-PCM”相匹配的价格&库存,您可以联系我们找货
