DF56C-26S-GUIDE
DF56C-26S-GUIDE
    HRS(广濑)
    CONNGUIDEFORDF56SERIES
DF56C-26S-GUIDE 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. 0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors DF56 Series High contact reliability 1.25±0.1 (stacking height) (0.21) Effective mating length Figure. 1 Enhanced shielding ■Features 1.Small mated height and board occupied space Small pitch (0.3mm) and mated height (1.25mm) allows use in space-restricted areas. It’s a small connector with mated height of 1.25mm (1.35mm MAX) and depth of 2.6mm. 2.Compatibility with minor diameter hinges AWG44 x 40 are compatible with hinge diameters of Ø2.8mm, and minor diameter hinges can be passed through internal equipment. 3.Reliable electrical and mechanical connection Multi-point ground contacts Figure. 2 Distinct tactile click Despite its small mated height, unique contact configuration assures highly reliable connection, with effective mating length of 0.21mm.(fig.1) 4. Durable plug construction Formed metal shells on the top and side surfaces form a strong and rigid assembly. 5.Enhanced shielding and ground connections Metal shells on the plug and receptacle connect to each other with a reliable multi-point ground contacts, assuring reliable ground connection and EMC protection. (fig 2.) 4-point lock : 2 points at each end Figure. 3 6.Reliable lock Fully mated condition is assured with reliable locks at 4 locations, confirming it with a distinct tactile click. (fig 3.) 7. Solder wicking prevention Nickel barriers prevent solder wicking in the critical contact areas. ■Connectors for conductivity tests We have a line-up of plug and receptacle connectors for inspection, usable for electrical testing. 2010.9 1 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Specifications Wire size AWG #42 0.2A Current rating Wire size AWG #44 0.15A (Note3) Wire size AWG #46 0.10A Ratings Voltage rating 30 Vrms AC 30V AC Item Operating temperature range: Operating humidity range: -35 to +85°C (Note 1) RH 20% to 80% Storage temperature range: Storage humidity range: -10 to +60°C (Note 2) RH 40% to 70% Specification Conditions 1. Insulation resistance 50 Mø min. 100 V DC 2. Withstanding voltage No flashover or insulation breakdown 100 Vrms AC / 1 minute 3. Contact resistance Signal:80mø max,Ground 80mø max 100 mA (DC or 1,000Hz) 4. Vibration No electrical discontinuity of 1 μs or longer 5. Humidity NContact resistance (change from initial value) 50 mø max. 96 hours at of 40 ±2°C, and humidity of 90 to 95% Insulation resistance: 25 Mø min. Contact resistance (change from initial value) -55°C → 5 to 35°C → 85°C → 5 to 35°C 50 mø max. Time: 30 min. → 2 to 3 min. → 30 min. → 2 to 3 min. Insulation resistance: 25 Mø min. 5 cycles 6. Temperature cycle 7. Durability 8. Resistance to soldering heat Frequency: 10 to 55 Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 axis Contact resistance (change from initial value) 20 cycles 50 mø max. Reflow: At the recommended temperature profile No deformation of affecting performance Manual soldering: 350°C for 3 seconds Note1: Includes temperature rise caused by current flow. Note2: The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage, shipment or during transportation after board mounting. Note3: With only the connector portion at an elevated temperature level, the rated current value is set. Note4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials Product Part Insulator LCP Color:Black UL94V-0 Receptacle Contacts Phosphor bronze Gold plated --------- Metal fittings Phosphor bronze Tin plated --------- Insulator LCP Color:Black --------- Plug Shell 2 Material Finish Remarks Contacts Phosphor bronze Gold plated UL94V-0 Metal cover Stainless Tin plated --------- Metal cover Stainless Tin plated --------- The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Ordering information lConnector DF 56 J − * S − 0.3 V (**) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ DF 56 J − * P − SHL ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series name : DF ❻ Contact pitch:0.3mm ❷ Series No. : 56 ❼ Termination type V : Straight SMT SD:Fine coaxial cable plug ❸ Connector style Receptacle/Shell J : Connector for conductivity tests Blank : Standard ❹ Nomber of positions Standard:20,30,40,50 Connector for conductivity tests : 20.30.40.50 ❺ Connector type S : Receptacle P : Plug ❽ Packaging (51):Embossed tape packaging ❾ Installation item (separate) SHL : Metal cover ■Combinations [Standard use] DF56-*S-0.3V(**) + DF56-*P-ASSY DF56-*P-0.3SD(**) DF56-*P-SHL Note : The product specification of the above combination is shown on page 2. [Receptacle conductivity test] DF56-*S-0.3V(**) + DF56J-*P-ASSY(Note) DF56-*P-0.3SD(**) DF56J-*P-SHL Note : This harness item is only usable for the receptacle test. For the product specification of the above combination, please contact our sales department. [Plug for conductivity test] DF56J-*S-0.3V(**)(Note) + DF56-*P-ASSY DF56-*P-0.3SD(**) DF56-*P-SHL Note : This harness item is only usable for the plugs and receptacles test. For the product specification of the above combination, please contact our sales department. * : ASSY means a harness item. 3 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Receptacles (SMT) ●20pos/40pos A±0.1 B±0.1 C±0.1 P=0.6±0.05 t=0.1±0.015 Contact No.1 1.8±0.05 0.8±0.05 1.25±0.1 2.6±0.1 Contact No.n Contact No.2 Vacuum pick-up area 1.2±0.05 (0.82) (D) E±0.1 F±0.1 Contact No.n-1 ●30pos/50pos A±0.1 B±0.1 C±0.1 P=0.6±0.05 t=0.1±0.015 1.8±0.05 0.8±0.05 Contact No.n-1 1.25±0.1 2.6±0.1 Contact No.2 Contact No.1 P=0.6±0.05 1.2±0.05 (0.82) (D) E±0.1 Vacuum pick-up area Contact No.n F±0.1 [Specifications number] - * *, (* *) (51) : Embossed tape packaging (5,000 pieces per reel) The position of contact No.1 is different depending on No. of positions.  Unit : mm Part Number 4 CL No. Number of contacts A B C D E F DF56-20S-0.3V(**) Under planning 20 10.90 8.90 6.60 (5.00) 6.00 9.40 DF56-30S-0.3V(**) Under planning 30 13.90 11.90 9.00 (5.00) 9.60 12.40 DF56-40S-0.3V(**) 662-5600-0-** 40 16.90 14.90 12.60 (5.00) 12.00 15.40 DF56-50S-0.3V(**) 662-5606-7-** 50 19.90 17.90 15.00 (5.00) 15.60 18.40 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Recommended PCB mounting pattern ●20pos/40pos B±0.02 (G)Pattern prohibition area 0.7±0.02 C±0.02 1±0.02 0.7±0.02 0.22±0.02 GND pad 0.22±0.02 P=0.3±0.02 (1.55) Pattern prohibition area 0.7±0.02 0.825±0.02 0.775±0.02 (0.925) 0.7±0.02 GND pad Contact pad 0.775±0.02 Contact No.1 1.2±0.02 2.89±0.02 1.85±0.02 (0.925) 1.2±0.02 0.7±0.02 E±0.02 F±0.02 ●30pos/50pos B±0.02 (G)Pattern prohibition area 0.7±0.02 GND pad Contact pad GND pad 0.7±0.02 P=0.3±0.02 0.22±0.02 0.775±0.02 (0.925) (1.55) Pattern prohibition area 0.7±0.02 0.775±0.02 1±0.02 0.825±0.02 0.22±0.02 1.2±0.02 1.85±0.02 2.89±0.02 (0.925) 1.2±0.02 0.7±0.02 C±0.02 0.7±0.02 E±0.02 F±0.02 ContactNo.1 [Specifications number] - * *, (* *) (51) : Embossed tape packaging (5,000 pieces per reel)  Unit : mm CL No. Number of contacts A B C D E F G DF56-20S-0.3V(**) Part Number Under planning 20 10.90 8.90 6.60 (5.00) 6.00 9.40 7.12 DF56-30S-0.3V(**) Under planning 30 13.90 11.90 9.00 (5.00) 9.60 12.40 10.12 DF56-40S-0.3V(**) 662-5600-0-** 40 16.90 14.90 12.60 (5.00) 12.00 15.40 13.12 DF56-50S-0.3V(**) 662-5606-7-** 50 19.90 17.90 15.00 (5.00) 15.60 18.40 16.12 Note 1: Tape and reel packaging (5,000 pieces/reel). Order by number of reels. 5 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Plugs P=0.3±0.05 1.68±0.1 A±0.1 B±0.1 P=1.2±0.05 1.09±0.1 Cav No. C±0.1 Contact No.1 Contact No.* [Specifications number] - * *, (* *) (51) : Embossed tape packaging (10,000 pieces per reel)  Unit : mm Part Number CL No. Number of contacts A B C D DF56-20P-0.3SD(**) Under planning 20 11.3 6.6 7.56 7.4 DF56-30P-0.3SD(**) Under planning 30 14.3 9.6 10.56 10.4 DF56-40P-0.3SD(**) 662-5601-3-** 40 17.3 12.6 13.56 13.4 DF56-50P-0.3SD(**) 662-5607-0-** 50 20.3 15.6 16.56 16.4 Note 1: Tape and reel packaging (10,000 pieces/reel). Order by number of reels. Note 2: The metal cover(DF56-*P-SHL) is required for fine coaxial cable termination. ■Recommended Fine Coaxial Cable Preparation E(FREE) 0.19MAX (Insulator) 1.2±0.07 E 0.4±0.05 P=0.3±0.07 0.6±0.05 B±0.15 0.95±0.05 D±0.1 Inner conductor (Pre-soldering required) 0.05±0.05 Outer shield (for individual conductor) 0.05mmMAX 0.3MAX Note 1: Contact Hirose for Termination Procedures. 6 0.39±0.02(Ground bar) The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Metal cover 0.54±0.05 B±0.1 C±0.1 1.73±0.1 2-1±0.05 2-0.32±0.05 0.97±0.1 0.3±0.05 0.3±0.05 1.28±0.05 A±0.1 0.45±0.05 Number of contacts indicator  Unit : mm Part Number CL No. Number of contacts A B C DF56-20P-SHL Under planning 20 10.0 π 8.04 DF56-30P-SHL Under planning 30 13.0 π 11.04 DF56-40P-SHL 662-5602-6 40 16.0 6.9 14.04 DF56-50P-SHL 662-5608-2 50 19.0 7.5 17.04 Note 1: Tape and reel packaging (10,000 pieces/reel). Order by number of reels. Note 2: *dimensions will be set separately during development. 7 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Packaging Specification + 0 0 .1 2±0.1 4±0.1 1.75±0.1 ●Embossed Carrier Tape Dimensions-----Receptacles (1.85) C±0.3 +0. 1 0 75 Unreeling direction R0. 0.2±0.05 B±0.1 A±0.1 Ø1 .5 8±0.1 Ø13 Part number label ±0 .2 ●Reel Dimensions (Ø79) Ø382MAX Ø1.5 0. 1± 0.5 Ø2 2± 8 D +2 0 E MAX  Unit : mm CL No. Number of contacts A B C D E DF56-20S-0.3V(51) Part Number Under planning 20 11.5 ----- 24.0 24.4 30.4 DF56-30S-0.3V(51) Under planning 30 11.5 ----- 24.0 24.4 30.4 DF56-40S-0.3V(51) 662-5600-0-51 40 14.2 28.4 32.0 32.4 38.4 DF56-50S-0.3V(51) 662-5606-7-51 50 14.2 28.4 32.0 32.4 38.4 Embossed tape will have perforated feed holes on single side(20pos. and 30pos.) 8 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Packaging Specification 1.75±0.1 ●Embossed Carrier Tape Dimensions----Plugs 1 0. + 0 5 1. 4±0.1 (1.65) C±0.3 0 75 +0.1 R0. 0.2±0.05 B±0.1 A±0.1 Ø Ø13 Part number label ±0 .2 ●Reel Dimensions (Ø79) Ø382MAX Ø1.5 1 Ø2 .8 0.5 ±0 2± D +2 0 E MAX  Unit : mm CL No. Number of contacts A B C D E DF56-20P-0.3SD(51) Part Number Under planning 20 14.2 28.4 32.0 32.4 38.4 DF56-30P-0.3SD(51) Under planning 30 14.2 28.4 32.0 32.4 38.4 DF56-40P-0.3SD(51) 662-5601-3-** 40 14.2 28.4 32.0 32.4 38.4 DF56-50P-0.3SD(51) 662-5607-0-** 50 14.2 28.4 32.0 32.4 38.4 9 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Extraction tool For details about the extraction tool, please contact your Hirose sales representative. ■Usage Recommendations 1.Recommended temperature profile Temperature (ç) 250℃ 250 220℃ 200 60sec max 180℃ 150 150℃ 90∼120sec 100 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Solder composition, 96.5%Sn/3.0%Ag/0.5%Cu Note 1: U  p to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.R ecommended manual soldering 3.Recommended screen thickness and open area ratio (Pattern area ratio) 4.Board warpage Manual soldering: 350ç for 3 seconds Do NOT use flux compound when manual soldering. Standard thickness 0.1mm Open area ratios : Lead terminal 60% : Ground terminal 100% Maximum of 0.02 mm at the connector center, with both ends of the connector as reference points. 5.Cleaning conditions 10 Refer to "Nylon Connector Use Handbook". The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF56 Series●0.3 mm Pitch, Vertical mating, Board-to-Fine Coaxial Cable Connectors ■Precautions Precautions ■Mating Mate the plug with receptacle by pressing straight against the entire plug surface. Do NOT mate the plug while holding by the teminated cable. ■Un-mating Use a dedicated extraction tool to un-mate the plug. Insert the tool under either end of the plug and pull straight up as illustrated. ■Do not mate / un-mate the connectors when receptacle is not mounted on the board. ■In the manual soldering process, don't carry out the flux coating which will cause a flux blister on the connector. ■Excessive scoop insertion or extraction may result in damage. 11 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: DF56C-26S-GUIDE
DF56C-26S-GUIDE 价格&库存
很抱歉,暂时无法提供与“DF56C-26S-GUIDE”相匹配的价格&库存,您可以联系我们找货
