ECC18DTMI-S371
ECC18DTMI-S371
    SULLINS
    CONNISAFEMALE36POS0.100GOLD
ECC18DTMI-S371 数据手册
Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height, [ISA] Dip Solder/Wire Wrap/Right Angle Sullins Female Card Edge SPECIFICATIONS • • • • • • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board PBT or PA9T insulator Molded-in key available 3 Amps current rating for one contact energized 30 milli Ohms maximum at rate current UL Flammability Rating: 94V-0 READOUT POLARIZING KEY PLC-K1 .038” [0.97] .285” [7.24] .100” [2.54] DUAL (D) HALF LOADED (H) KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) TERMINATION TYPE HAIRPIN BELLOWS LOOP BELLOWS L .275” [6.98] L K .200” [5.08] HAIRPIN BELLOWS (CS,CM,CW,CT) L K .200” [5.08] K LOOP BELLOWS (TK,RS,RM) .150” [3.81] RIGHT ANGLE, DIP SOLDER (CA,CB,CC,TA,TB,TM) -S605 MODIFICATION POST CROSS SECTION K POST LENGTH L .025”ʺ [0.64] FITS MIN. HOLE SIZE DIP SOLDER .025ʺ [0.64] ROUND .190ʺ [4.83] .033ʺ [0.84] DIP SOLDER .025ʺ [0.64] SQUARE .190ʺ [4.83] .040ʺ [1.02] RM WIRE WRAP .025ʺ [0.64] SQUARE .560ʺ [14.20] .040ʺ [1.02] TA RIGHT ANGLE .025ʺ [0.64] SQUARE .100ʺ [2.54] .043ʺ [1.09] CB TB RIGHT ANGLE .025ʺ [0.64] SQUARE .180ʺ [4.57] .043ʺ [1.09] CC TM RIGHT ANGLE .025ʺ [0.64] SQUARE .250ʺ [6.35] .043ʺ [1.09] CW DIP SOLDER .015ʺ X .025ʺ [0.38 X 0.64] .125ʺ [3.18] .035ʺ [0.89] CT DIP SOLDER .015ʺ X .025ʺ [0.38 X 0.64] .170ʺ [4.32] .035ʺ [0.89] CS DIP SOLDER .025ʺ [0.64] SQUARE .160ʺ [4.06] .040ʺ [1.02] HAIRPIN BELLOWS LOOP TERMINATION TYPE TK, CK RS CM CA MOUNTING STYLE Ø.125" [3.18] #4-40 Ø.125” [3.18] .250" [6.35] CLEARANCE HOLE (H) 56 Ø.125” [3.18] .245” [6.22] THREADED INSERT(I) SIDE MOUNTING (S) D = .250” [6.35] W = .430” [10.92] NO MOUNTING EARS (N) FLUSH MOUNTING (D, W) #4-40 T = .250” [6.35] X = .430” [10.92] FLUSH MOUNTING WITH THREADED INSERT(T, X) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height, [ISA] Dip Solder/Wire Wrap/Right Angle PART NUMBER OPTIONS E B C 49 D CW N - S420 All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y = = = = Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte Sullins Female Card Edge MODIFICATION CODE (Consult Factory) ISA WITH RETENTION FEATURE -S524 = 18 Positions -S524 = 31 Positions -S518 = 49 Positions (31/18) ISA WITHOUT RETENTION FEATURE -S371 = 18 Positions -S371 = 31 Positions -S420 = 49 Positions (31/18) Dip Solder or Wire Wrap -S605 = 49 Positions (31/18) Right Angle** MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures CONTACT FINISH - RoHS Compliant MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts S = Side Mounting N = No Mounting D, W = Flush Mounting T, X = Flush Mounting With Threaded Inserts TERMINATION TYPE (Opposite Page) Hairpin Bellows * CS = .025” [0.64 mm] Square Dip Solder CM = .025” [0.64 mm] Square Wire Wrap CA, CB, CC = .025” [0.64 mm] Square Right Angle CW, CT = .015” X .025” [0.38 mm X 0.64 mm] Dip Solder Loop Bellows RS = .025” [0.64 mm] Square Dip Solder TK = .025” [0.64 mm] Round Dip Solder RM = .025” [0.64 mm] Square Wire Wrap TA, TB, TM = .025” [0.64 mm] Square Right Angle * Available in B or C Plating and Phosphor Bronze only Consult Factory for Cantilever Terminations CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS 18, 31 or 49 (31/18) READOUT (Opposite page) D = Dual H = Half Loaded DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. 2.635 [66.93] 2.375 [60.32] 2.060 [52.32] 1.900 [48.26] 1.700 [43.18] .370 [9.40] Ø .043 [1.09] .062[ 1.57] PCB .610 [15.49] MOUNTING STYLE, OPTIONAL EBC18DCWN-S371 3.935 [99.95] 3.675 [93.34] 3.360 [85.34] 3.200 [81.28] 3.000 [76.20] REFER TO TERMINATION TYPE (Opposite Page) RETENTION FEATURE ON MIDDLE TERMINALS FOR PART NUMBERS EBC18DCWN-S524 EBC31DCWN-S524 EBC49DCWN-S518 MOUNTING STYLE, OPTIONAL EBC31DCWN-S371 TOP VIEW: 5.775 [146.68] / SIDE VIEW 5.750 [146.05]** 1.700 [43.18] 3.000 [76.20] .400 [10.16] .200 [5.08] 2.000 [50.80] 3.300 [83.82] MOUNTING STYLE, OPTIONAL 6.040 [153.42] 5.460 [138.68] .297 [7.54] INSERTION DEPTH .100 [2.54] TYP. .060 [1.52] REFER TO TERMINATION TYPE 31 POSITIONS 18 POSITIONS EBC49DCWN-S420 (DIP SOLDER OR WIRE WRAP) EBC49DCAN-S605 (RIGHT ANGLE) ** 5.750 [146.05] ONLY APPLIES IF P/N ENDS WITH -S605 AND HAS SIDE MOUNTING (MTG CODE 'S') www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 57
ECC18DTMI-S371
物料型号:Sullins Female Card Edge,有多种型号选项,例如EBC18DCWN-S371、EBC31DCWN-S371、EBC49DCWN-S420等。
器件简介:Sullins Female Card Edge是一种用于ISA总线系统的连接器,具有0.100英寸(2.54mm)的接触中心和0.610英寸(15.49mm)的绝缘体高度。
引脚分配:提供18、31或49(31/18)个接触位置,具体分配取决于型号。
参数特性:包括0.062英寸±0.008英寸(1.57mm±0.20mm)的PCB容纳尺寸,PBT或PA9T绝缘体,3A电流额定值,最大30毫欧姆的接触电阻,UL阻燃等级94V-0。
功能详解:提供了多种终止类型,如Hairpin Bellows、Loop Bellows、DIP Solder等,以及不同的安装风格和材料选项。
应用信息:适用于DIP焊接、线绕和直角安装。
封装信息:提供了详细的尺寸信息和安装选项,如无安装耳(N)、带螺纹嵌件的齐平安装(T, X)等。
ECC18DTMI-S371 价格&库存
很抱歉,暂时无法提供与“ECC18DTMI-S371”相匹配的价格&库存,您可以联系我们找货
