ECC18DCAT-S189
ECC18DCAT-S189
    SULLINS
    CONNEDGEDUALFMALE36POS0.100
ECC18DCAT-S189 数据手册
8 7 4 5 6 1 2 3 REVISIONS E B FIRST POSITION INDICATOR ECO. NO DESCRIPTION DATE BY A 1094 INITIAL RELEASE 7-19-2006 MNH F D F REV. B 2379 ADDED CB & CC TERMINATION 6/17/2011 SE C 3243 UPDATE DWG FORMAT, REMOVE PCB LAYOUT & UPDATE BOM ON PRODUCTION COPY 8/13/2015 MG A .100 2.54 .075 1.91 SEE NOTE 13 CONTACT MARKINGS: 1 3 5 ... 99 2 4 6 ... 100 E E .125 3.18 2X +.005 +0.13 .370 9.40 - .015 - 0.38 C .030 0.76 A .297 7.54 INSERTION DEPTH .180 4.57 D .250 6.35 .610 15.49 D .030±.010 0.76±0.25 .200 5.08 ODD NUMBER SIDE .060 1.52 A .025 0.64 CA =.100±.025 2.53±0.64 CB =.180 .025 [4.57 0.64] CC =.250 .025[6.35 0.64] C F _ _ C _ _ DCAH-S189 _ _ C _ _ DCBH-S189 _ _ C _ _ DCCH-S189 C SECTION A-A D 2X .125 3.18 FOR 'S' MNTG A .275 6.99 B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING .100 2.54 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 700 VAC 8. CURRENT RATING: 3 AMPS 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 16. MODIFICATION: RIGHT ANGLE BEND WITH .200" ROW SPACING 8 7 6 5 B .200 5.08 .043 1.09 MIN PCB LAYOUT RECOMMENDED Pb RoHS COMPLIANT 4 CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 06/17/11 SE TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _ C _ _ DCA(CB,CC) _-S189 CAGE CODE 54453 SCALE: 3:1 3 A EDGECARD, .100 CC HP 2 DWG. NO. C10789 SHEET 1 OF 3 1 REV C FILE NAME: C10789, _ _C_ _DCA(CB, CC)_-S189 8 7 4 5 6 1 2 3 2X #4-40 THREADED INSERTS D F F C 2X D .125 3.18 .245 6.22 E E _ _ C _ _ DCAN-S189 _ _ C _ _ DCBN-S189 _ _ C _ _ DCCN-S189 2X 2X #4-40 THREADED INSERTS D .125 3.18 _ _ C _ _ DCAI-S189 _ _ C _ _ DCBI-S189 _ _ C _ _ DCCI-S189 _ _ C _ _ DCAS-S189 _ _ C _ _ DCBS-S189 _ _ C _ _ DCCS-S189 2X #4-40 THREADED INSERTS D D D D .430 10.92 .250 6.35 .250 6.35 C C _ _ C _ _ DCAT-S189 _ _ C _ _ DCBT-S189 _ _ C _ _ DCCT-S189 _ _ C _ _ DCAD-S189 _ _ C _ _ DCBD-S189 _ _ C _ _ DCCD-S189 2X _ _ C _ _ DCAX-S189 _ _ C _ _ DCBX-S189 _ _ C _ _ DCCX-S189 D .125 3.18 B B CUSTOMER COPY .430 10.92 Pb A _ _ C _ _ DCAW-S189 _ _ C _ _ DCBW-S189 _ _ C _ _ DCCW-S189 8 7 RoHS COMPLIANT 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 06/17/11 SE TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _ C _ _ DCA(CB,CC) _-S189 CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD, .100 CC HP 2 DWG. NO. C10789 SHEET 2 OF 3 1 REV C FILE NAME: C10789, _ _C_ _DCA(CB, CC)_-S189 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 06/17/11 SE TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _ C _ _ DCA(CB,CC) _-S189 CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD, .100 CC HP 2 DWG. NO. C10789 SHEET 3 OF 3 1 REV C FILE NAME: C10789, _ _C_ _DCA(CB, CC)_-S189
ECC18DCAT-S189 价格&库存
很抱歉,暂时无法提供与“ECC18DCAT-S189”相匹配的价格&库存,您可以联系我们找货
