ECC15DPNS
ECC15DPNS
    SULLINS
    CONNEDGEDUALFMALE30POS0.100
ECC15DPNS 数据手册
Female Card Edge .100” [2.54 mm] Contact Centers, .560” [14.22 mm] Profile, .400” [10.16 mm] Wide Body, Double Point Contact, Dip Solder/Wire Wrap/Right Angle/Card Extender SPECIFICATIONS • • • • • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board PPS, PBT or PA9T insulator 3 Amps current rating for one contact energized 30 milli Ohms maximum at rated current UL Flammability Rating: 94V-0 TERMINATION TYPE Female Card Edge POINT OF CONTACT POINT OF CONTACT POINT OF CONTACT L POINT OF CONTACT L POINT OF CONTACT POINT OF CONTACT .150” [3.81] .200” [5.08] ACCOMMODATES .062” [1.57] PCB CARD EXTENDER (PN, PR) RIGHT ANGLE (PB, PG, PE, PJ, PU) DIP SOLDER/WIRE WRAP (PD, PF, PS, PM) TERMINATION TERMINATION TYPE PD DIP SOLDER PS PF * POST LENGTH L ±.025”ʺ [0.64] L FITS MIN. HOLE SIZE STANDOFF .160ʺ [4.06] .043ʺ [1.09] YES DIP SOLDER .190ʺ [4.83] .043ʺ [1.09] YES DIP SOLDER .270ʺ [6.86] .043ʺ [1.09] YES PM WIRE WRAP .560ʺ [14.22] .043ʺ [1.09] YES PB RIGHT ANGLE .100ʺ [2.54] .043ʺ [1.09] NO PG RIGHT ANGLE .140ʺ [3.56] .043ʺ [1.09] NO PE RIGHT ANGLE .180ʺ [4.57] .043ʺ [1.09] NO PU RIGHT ANGLE .250ʺ [6.35] .043ʺ [1.09] NO PJ RIGHT ANGLE .500ʺ [12.70] .043ʺ [1.09] NO PR CARD EXTENDER .225ʺ [5.73] N/A NO PN CARD EXTENDER .595ʺ [15.12] N/A NO * OTHER POST LENGTHS AVAILABLE, CONTACT FACTORY. MOUNTING STYLE (Standoffs included on straight terminations only.) 64 Ø.125” [3.18] #4-40 .250” [6.35] .250” [6.35] CLEARANCE HOLE (H) THREADED INSERT ( I) Ø.125” [3.18] .255” [6.48] SIDE MOUNTING (S) NO MOUNTING EARS (N) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .560” [14.22 mm] Profile, .400” [10.16 mm] Wide Body, Double Point Contact, Dip Solder/Wire Wrap/Right Angle/Card Extender PART NUMBER OPTIONS E B C 10 D PD H - Sxxx MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures CONTACT FINISH - RoHS Compliant MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts S = Side Mounting N = No Mounting All platings are Lead Free and have .000050” Nickel underplate Contact Surface B = .000010” Gold C = .000030” Gold TERMINATION TYPE (Opposite Page) PD, PF, PS = .025” [0.64 mm] Square Dip Solder PM = .025” [0.64 mm] Square Wire Wrap PB, PG, PE, PJ, PU = .025” [0.64 mm] Square Right Angle PN, PR = .025” [0.64 mm] Square Card Extender Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS See Chart Below READOUT (Opposite Page) D = Dual Female Card Edge DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .425 [10.80] INSERTION DEPTH E D B A .400 [10.16] C .180 [4.57] .560 [14.22] .250 [6.35] .050 [1.27] .100 [2.54] .025 [0.64] SQ. F REFER TO TERMINATION TYPE Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. INCHES MILLIMETERS POSITIONS/ CONTACTS A±.008 B±.008 C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 06/12 07/14* 08/16 10/20 12/24* 13/26* 15/30 17/34* 18/36* 20/40 22/44* 24/48* 25/50* 28/56* 30/60 31/62* 35/70* 36/72* 40/80 43/86 44/88 49/98* 50/100 55/110* 60/120* 61/122* 65/130* 70/140* 0.500 0.600 0.700 0.900 1.100 1.200 1.400 1.600 1.700 1.900 2.100 2.300 2.400 2.700 2.900 3.000 3.400 3.500 3.900 4.200 4.300 4.800 4.900 5.400 5.900 6.000 6.400 6.900 0.700 0.800 0.900 1.100 1.300 1.400 1.600 1.800 1.900 2.100 2.300 2.500 2.600 2.900 3.100 3.200 3.600 3.700 4.100 4.400 4.500 5.000 5.100 5.600 6.100 6.200 6.600 7.100 0.860 0.960 1.060 1.260 1.460 1.560 1.760 1.960 2.060 2.260 2.460 2.660 2.760 3.060 3.260 3.360 3.760 3.860 4.260 4.560 4.660 5.160 5.260 5.760 6.260 6.360 6.760 7.260 1.175 1.275 1.375 1.575 1.775 1.875 2.075 2.275 2.375 2.575 2.775 2.975 3.075 3.375 3.575 3.675 4.075 4.175 4.575 4.875 4.975 5.475 5.575 6.075 6.575 6.675 7.075 7.575 1.435 1.535 1.635 1.835 2.035 2.135 2.335 2.535 2.635 2.835 3.035 3.235 3.335 3.635 3.835 3.935 4.335 4.435 4.835 5.135 5.235 5.735 5.835 6.335 6.835 6.935 7.335 7.835 0.740 0.840 0.940 1.140 1.340 1.440 1.640 1.840 1.940 2.140 2.340 2.540 2.640 2.940 3.140 3.240 3.640 3.740 4.140 4.440 4.540 5.040 5.140 5.640 6.140 6.240 6.640 7.140 12.70 15.24 17.78 22.86 27.94 30.48 35.56 40.64 43.18 48.26 53.34 58.42 60.96 68.58 73.66 76.20 86.36 88.90 99.06 106.68 109.22 121.92 124.46 137.16 149.86 152.40 162.56 175.26 17.78 20.32 22.86 27.94 33.02 35.56 40.64 45.72 48.26 53.34 58.42 63.50 66.04 73.66 78.74 81.28 91.44 93.98 104.14 111.76 114.30 127.00 129.54 142.24 154.94 157.48 167.64 180.34 21.84 24.38 26.92 32.00 37.08 39.62 44.70 49.78 52.32 57.40 62.48 67.56 70.10 77.72 82.80 85.34 95.50 98.04 108.20 115.82 118.36 131.06 133.60 146.30 159.00 161.54 171.70 184.40 29.85 32.39 34.93 40.01 45.09 47.63 52.71 57.79 60.33 65.41 70.49 75.57 78.11 85.73 90.81 93.35 103.51 106.05 116.21 123.83 126.37 139.07 141.61 154.31 167.01 169.55 179.71 192.41 36.45 38.99 41.53 46.61 51.69 54.23 59.31 64.39 66.93 72.01 77.09 82.17 84.71 92.33 97.41 99.95 110.11 112.65 122.81 130.43 132.97 145.67 148.21 160.91 173.61 176.15 186.31 199.01 18.80 21.34 23.88 28.96 34.04 36.58 41.66 46.74 49.28 54.36 59.44 64.52 67.06 74.68 79.76 82.30 92.46 95.00 105.16 112.78 115.32 128.02 130.56 143.26 155.96 158.50 168.66 181.36 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 65
ECC15DPNS
物料型号:Sullins Female Card Edge Connector
器件简介:该连接器具有100英寸[2.54mm]接触中心,560英寸[14.22mm]轮廓,400英寸[10.16mm]宽体,双点接触,支持DIP焊接/线绕/直角/卡扩展器。
引脚分配:文档提供了详细的引脚分配和接触点信息,包括DIP焊接、线绕和直角引脚的尺寸和类型。
参数特性: - 适用于0.062"±0.008"[1.57mm±0.2mm]PCB板 - PPS、PBT或PA9T绝缘体 - 单个接触点的电流额定值为3安培 - 在额定电流下的最大电阻为30毫欧姆 - UL阻燃等级:94V-0
功能详解:文档描述了不同终止类型(如DIP焊接、线绕和直角)的接触点,并提供了每种类型的详细尺寸和规格。
应用信息:连接器适用于多种应用,包括PCB板连接和信号传输。
封装信息:提供了连接器的物理尺寸和安装选项,包括支架安装和无支架安装。
ECC15DPNS 价格&库存
很抱歉,暂时无法提供与“ECC15DPNS”相匹配的价格&库存,您可以联系我们找货
