MPSL-1156-15-DS-1K
MPSL-1156-15-DS-1K
    SULLINS
    CONNEDGEDUALFMALE30POS0.156
MPSL-1156-15-DS-1K 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 1827 10/21/08 ASK B 2405 INITIAL RELEASE UPDATED P/N CODING TO INCLUDE MATERIAL & PLATING OPTIONS AND 'E' MODIFICATION CODE (OBSOLETE DWG# 11772) 7/12/2011 JH F E D B A F CONTACT MARKINGS (LETTERS G, I, O, & Q NOT USED) 2X .125 3.18 THRU SIZE 02 THRU 30: 1 2 3 ... 23 24 25 A B C ... AA BB CC E .075 1.91 SEE NOTE 13 SIZE 28 & 44 1 2 3 ... 23 24 25 A B C ... A B C CONTACT ID F C .265 6.73 INSERTION DEPTH .431 10.95 .245 6.22 D SIZE 36 & 43: A B C .... A B C 1 2 3 .... 23 24 25 .030±.010 0.76±0.25 A E D .025 0.64 .140 3.56 A .156 3.96 MP_ _-_156-_ _-DS-1_ _ _ MP_ _-_156-_ _-DS-1E_ _ _ SECTION A-A D 2X .125 3.18 FOR MOUNTING STYLE '1', '2', '3' OR '1 WITH M MODIFICATION CODE' A C .140 3.56 .156 3.96 PCB LAYOUT RECOMMENDED B A B REF: _ _M_ _DRK_ (-OMIT, S38, S81, S328, S858, S1130, S1281, S1313) CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 7 6 C .051 1.30 MIN NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. DIELECTRIC WITHSTANDING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMP PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 8 .225±.025 5.72±0.64 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 7/13/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, LP PART NUMBER SIZE C MPSL-_156-_ _-DS-_ (E) _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11152 SHEET 1 OF 4 1 REV B FILE NAME: C11152, MP_ _-_156-_ _-DS-_ (E)_ _ _, (_ _M_ _DRK_ -OMIT, S38, S81, S328, S858, S1130, S1281, S1313) 8 7 4 5 6 2X #4-40 THREADED INSERT D 1 2 3 D 2X .116 [2.95] CLEARANCE FOR #4 SCREW (FLOATING BOBBIN) F F .280 7.11 E E MP_ _-_156-_ _-DS-3_ _ _ MP_ _-_156-_ _-DS-3E_ _ _ MP_ _-_156-_ _-DS-2_ _ _ MP_ _-_156-_ _-DS-2E_ _ _ 2X D D D C 2X .125 3.18 D .125 3.18 THRU 2X .135 3.43 MP_ _-_156-_ _-DS-4_ _ _ MP_ _-_156-_ _-DS-4E_ _ _ MP_ _-_156-_ _-DS-8_ _ _ MP_ _-_156-_ _-DS-8E_ _ _ C C 2X .142 3.61 THRU D 2X .125 3.18 THRU D .245 6.22 B B MP_ _-_156-_ _-DS-1_ _ M_ MP_ _-_156-_ _-DS-1E_ _M _ MP_ _-_156-_ _-DS-11_ _ _ MP_ _-_156-_ _-DS-11E_ _ _ CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 7/13/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, LP PART NUMBER SIZE C MPSL-_156-_ _-DS-_ (E) _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11152 SHEET 2 OF 4 1 REV B FILE NAME: C11152, MP_ _-_156-_ _-DS-_ (E)_ _ _, (_ _M_ _DRK_ -OMIT, S38, S81, S328, S858, S1130, S1281, S1313) 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 7/13/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, LP PART NUMBER SIZE C MPSL-_156-_ _-DS-_ (E) _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11152 SHEET 3 OF 4 1 REV B FILE NAME: C11152, MP_ _-_156-_ _-DS-_ (E)_ _ _, (_ _M_ _DRK_ -OMIT, S38, S81, S328, S858, S1130, S1281, S1313) 8 7 4 5 6 1 2 3 F F E E D D C C ** OPTIONAL "E" CODE MEANS .020" LONGER CARD SLOT, NOW STANDARD, SEE DIMENSION 'B' ON PAGE 3. B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 7/13/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, LP PART NUMBER SIZE C MPSL-_156-_ _-DS-_ (E) _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11152 SHEET 4 OF 4 1 REV B FILE NAME: C11152, MP_ _-_156-_ _-DS-_ (E)_ _ _, (_ _M_ _DRK_ -OMIT, S38, S81, S328, S858, S1130, S1281, S1313)
MPSL-1156-15-DS-1K 价格&库存
很抱歉,暂时无法提供与“MPSL-1156-15-DS-1K”相匹配的价格&库存,您可以联系我们找货
