EM241307
EM241307
    EATON(伊顿)
    P=3.5mm
    接线端子 间距:3.50mm 1x7P 自由悬挂
EM241307 数据手册
SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.138” (3.50mm) Wire Range: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Material: Brass, Nickel-Plated Screw Size: M2.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 3.0 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 17.4 20.9 24.4 27.9 31.4 34.9 38.4 41.9 45.4 48.9 52.4 EM241307 Dimensions - mm (in) 15.6 (0.614") L 11.2 (0.441") Plug & Header EM2413 Series EuroMag Terminal Blocks Pluggable Block with Flanges (Mates with EM2201 Series); 3.50 Centers Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Pluggable Terminal Blocks 6.6 (0.60") 2.15 (0.084") 3.5±.1 (0.138") To convert to inches, divide by 25.4 Part Numbering System En Mn 2n 4n 1n 3 nn n Series # of Poles Mating Header: EM2201 pg. 77 02 to 12 For additional product information, visit www.eaton.com/connectors 76
EM241307 价格&库存
很抱歉,暂时无法提供与“EM241307”相匹配的价格&库存,您可以联系我们找货
