8724
8724
    KEYSTONE
    插件,P=3.5mm
    接线端子 间距:3.50mm 插件
8724 数据手册
M55 Sect 3 p59 10-23m 10/24/06 11:46 AM Page 59 PLUGGABLE WITH PIN STRIPS supplied in strips of 24. Simply snap off the desired number of positions required and insert into PC board. The modular terminal block can be plugged into the header strip at anytime. • Space saving low profile design • Easy access horizontal wire entry • Convenient screw head access on top of terminal block • Headers mount easily in pre-drilled or stamped holes • Wire guards help prevent damage to conductors • Accepts #22-16 AWG wire • Because of accumulating tolerances, we recommend a maximum of 24 positions per row • Header strips and terminal blocks sold separately SPECIFICATIONS MATERIAL: ELECTRICAL: MECHANICAL: Contact: Brass, Tin Plate Header Pins: Brass, Tin Plate Housing: Blue PBT, UL Rated 94V-0 Screw: Steel, Zinc Plate & Clear Chromate (captivated) Dielectric Strength: 2500V Insulation Breakdown: 1500V AC/min. Rated voltage: 250V Operating Temp: 22°F to 248°F (-30°C to 120°C) Peak Temp: +393°F (+200°C) HORIZONTAL ENTRY • Use header strip to connect to PCB A .375 [9.5] .051 [1.30] .024 [0.61] .073 [1.9] .473 [12.0] .394 [10.0] .069 [1.75] .268 [6.8] .148 [3.8] .138 [3.5] .138 [3.5] .039 [0.99] 8723 8722 Recommended Mtg. Hole Size: .047(1.19) CAT. NO. 8722 8723 3.5mm SPACING A CURRENT POSITIONS DIM. RATING 2 .276 (7.0) 6 Amps 3 .413 (10.5) Pin Header Strips (24 pins per strip) 8724 CAT. NO. 8724 HORIZONTAL ENTRY • Use header strip to connect to PCB .531 [13.5] A .028 [0.71] .078 [2.0] .502 [12.8] .436 [11.1] .358 [9.1] .197 [5.0] .098 [2.5] .148 [3.8] .197 [5.0] 8726 8725 .051 [1.30] Recommended Mtg. Hole Size: .059 (1.50) CAT. NO. 8725 8726 5mm SPACING A CURRENT POSITIONS DIM. RATING 2 .394 (10.0) 10 Amps 3 .591 (15.0) Pin Header Strips (24 pins per strip) 8727 CAT. NO. 8727 NOTES Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017 MODULAR INTERLOCKING PC TERMINAL BLOCKS These unique modular terminal blocks are convenient and easy to use. They may be interlocked to achieve the required number of positions.The header pins, for both the 6 and 10 Amp models are 59
很抱歉,暂时无法提供与“8724”相匹配的价格&库存,您可以联系我们找货
