EMPSL-3156-24-DP-1K
EMPSL-3156-24-DP-1K
    SULLINS
    CONNEDGEDUALFMALE48POS0.156
EMPSL-3156-24-DP-1K 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 895 INITIAL RELEASE 01/11/2006 HT B 2367 6/07/2011 JH C 2384 6/21/2011 JH D 2433 8/22/2011 JH F UPDATED BOM, 'B' 'C', 'E MAX' & 'F' DIM, CONTACT MARKING & NOTES ADDED PLATING & INSULATOR MATERIAL OPTIONS, REMOVED ROW SPACING DIM UPDATED REF PN FOR S858, S1130, S1281 & S1313 OPTIONS F CONTACT MARKINGS (LETTERS G, I, O, & Q NOT USED) SIZE 02 THRU 25: 1 2 3 ... 23 24... A B C ... AA BB ... SIZE 28 & 44: 1 2 3 ... 23 24 25... A B C ... A B C... E E D B .075 1.91 SEE NOTE 13 2X .125 3.18 THRU D SIZE 36 & 43: A B C ... R ... Y 1 2 3 ... 36 ..43 DETAIL B SCALE 4 : 1 A E D .030±.010 0.76±0.25 F C .265 6.73 INSERTION DEPTH A .431 10.95 C .245 6.22 C .025 0.64 A .086 2.18 .007[0.18] THICK ACCEPTS 3-#26 AWG B A EMP_ _- _ 156 - _ _ - DP - 1_ _ _ NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. DIELECTRIC WITHSTANDING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMPS PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 7 6 5 +0.64 +.025 5.70 .225 - 0.89 - .035 TAIL LENGTH B REF: _ _M_ _DSE_-_ _ _ _ CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 SECTION A-A .156 3.96 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 6/7/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC LP PART NUMBER SIZE C EMP_ _-_ 156-_ _ -DP-_ _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C10666 SHEET 1 OF 3 1 REV D FILE NAME: C10666, EMP_ _- _156-_ _-DP-_ _ _ _ (_ _M_ _DSE_-OMIT, P101, P102, P103, P105, P107, S858, S1130, S1281, S1313) 8 7 4 5 6 1 2 3 F F D D 2X FLOATING BOBBIN .116[2.95] CLEARANCE FOR #4 SCREW 2X #4-40 THREADED INSERT E E EMP_ _ - _ 156 - _ _ - DP - 3_ _ _ EMP_ _ - _ 156 - _ _ - DP - 2_ _ _ D D 2X .125 3.18 THRU D C D C C 2X .125 3.18 THRU 2X .135 3.43 EMP_ _ - _ 156 - _ _ - DP - 4_ _ _ EMP_ _ - _ 156 - _ _ - DP - 8_ _ _ B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 6/7/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC LP PART NUMBER SIZE C EMP_ _-_ 156-_ _ -DP-_ _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C10666 SHEET 2 OF 3 1 REV D FILE NAME: C10666, EMP_ _- _156-_ _-DP-_ _ _ _ (_ _M_ _DSE_-OMIT, P101, P102, P103, P105, P107, S858, S1130, S1281, S1313) 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 6/7/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC LP PART NUMBER SIZE C EMP_ _-_ 156-_ _ -DP-_ _ _ _ CAGE CODE 54453 SCALE: 3:1 2 DWG. NO. C10666 SHEET 3 OF 3 1 REV D FILE NAME: C10666, EMP_ _- _156-_ _-DP-_ _ _ _ (_ _M_ _DSE_-OMIT, P101, P102, P103, P105, P107, S858, S1130, S1281, S1313)
EMPSL-3156-24-DP-1K 价格&库存
很抱歉,暂时无法提供与“EMPSL-3156-24-DP-1K”相匹配的价格&库存,您可以联系我们找货
EMPSL-3156-24-DP-1K
