EBC24DKES-S189
EBC24DKES-S189
    SULLINS
    CONNEDGEDUALFMALE48POS0.100
EBC24DKES-S189 数据手册
Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle/Card Extender Sullins Female Card Edge SPECIFICATIONS • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] mating PCB (For .093” [2.36 mm] or .125” [3.18 mm] mating PCB see following pages) • PBT, PPS or PA9T insulator • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current READOUT • UL Flammability Rating: 94V-0 POLARIZING KEY PLC-K1 .038” [0.97] .285” [7.24] EVEN NUMBER SIDE DUAL (D) .100” [2.54] KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) HALF LOADED (H) TERMINATION TYPE HAIRPIN BELLOWS TERMINATION TYPE CW DIP SOLDER CT CS CM CA CB CC DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE POST LENGTH FITS MIN. L HOLE SIZE .025” [0.64] .015ʺ X .025ʺ[0.38 X 0.64] .125ʺ [3.18] .035ʺ [0.89] POST CROSS SECTION K .015ʺ X .025ʺ[0.38 X 0.64] .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .170ʺ .160ʺ .560ʺ .100ʺ .180ʺ .250ʺ [4.32] [4.06] [14.20] [2.54] [4.57] [6.35] POST LENGTH L .025”ʺ [0.64] .190ʺ [4.83] .190ʺ [4.83] .560ʺ [14.20] .100ʺ [2.54] .180ʺ [4.57] .250ʺ [6.35] .035ʺ .040ʺ .040ʺ .043ʺ .043ʺ .043ʺ [0.89] [1.02] [1.02] [1.09] [1.09] [1.09] L .030” [0.76] .275” [6.98] L K .200” [5.08] ODD NUMBER SIDE (CW, CT, CS, CM) .150” [3.81] K (CA, CB, CC, TA, TB, TM, KA, KE, KU, KJ) HAIRPIN or LOOP CARD EXTENDER LOOP BELLOWS TERMINATION TYPE POST CROSS SECTION K TK,CK RS RM TA TB TM DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE .025ʺ [0.64] ROUND .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE CANTILEVER TERMINATION TYPE KS DIP SOLDER POST CROSS SECTION POST LENGTH L K .025”ʺ [0.64] .025ʺ [0.64] SQUARE .190ʺ [4.83] .040ʺ [1.02] KD DIP SOLDER .025ʺ [0.64] SQUARE .160ʺ [4.06] .043ʺ [1.09] KM WIRE WRAP .025ʺ [0.64] SQUARE .560ʺ [14.20] .040ʺ [1.02] *KA RIGHT ANGLE .025ʺ [0.64] SQUARE .100ʺ [2.54] .043ʺ [1.09] *KE RIGHT ANGLE .025ʺ [0.64] SQUARE .180ʺ [4.57] .043ʺ [1.09] *KU RIGHT ANGLE .025ʺ [0.64] SQUARE .250ʺ [6.35] .043ʺ [1.09] FITS MIN. HOLE SIZE RIGHT ANGLE .025ʺ [0.64] SQUARE .033ʺ .040ʺ .040ʺ .043ʺ .043ʺ .043ʺ [0.84] [1.02] [1.02] [1.09] [1.09] [1.09] LOOP BELLOWS L - .015” [0.38] L K .200” [5.08] (TK, CK, RS, RM) FITS MIN. HOLE SIZE .500ʺ [12.70] .043ʺ [1.09] *KR CARD EXTENDER .025ʺ [0.64] SQUARE .235ʺ [5.97] N/A *KN CARD EXTENDER .025ʺ [0.64] SQUARE .605ʺ [15.37] N/A *KJ RIGHT ANGLE HAIRPIN BELLOWS K ACCOMMODATES .062” [1.57] PCB (CT, CS, CM,TK, CK, RS,RM) Example P/N: EBC10DCSN-S288 (Requires -S288 Modification Code) CANTILEVER CARD EXTENDER CANTILEVER .550” [13.97] L L K .200” [5.08] (KS, KD, KM) K ACCOMMODATES .062” [1.57] PCB (KR, KN) Example P/N: EBC10DKRN (Omit Modification Code) * KA, KE, KU, KJ, KR, KN have no standoffs, unless requested. MOUNTING STYLE Ø.125” [3.18] #4-40 Ø.125” [3.18] .250” [6.35] CLEARANCE HOLE (H) 50 .245” [6.22] THREADED INSERT(I) SIDE MOUNTING (S) Ø.125” [3.18] D = .250” [6.35] W = .430” [10.92] NO MOUNTING EARS (N) FLUSH MOUNTING (D, W) #4-40 T = .250” [6.35] X = .430” [10.92] FLUSH MOUNTING WITH THREADED INSERT(T, X) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle/Card Extender PART NUMBER OPTIONS E B C 70 D CM H - Sxxx All platings are Lead Free and have .000050” Nickel underplate Contact Surface Termination .000010” Gold .000100” Pure Tin, Matte .000030” Gold .000100” Pure Tin, Matte .000010” Gold .000005” Gold .000030” Gold .000005” Gold Contact Surface Overall Plating S = .000010” Gold .000010” Gold M = .000030” Gold .000010” Gold E = .000100” Pure Tin, Matte .000100” Pure Tin, Matte CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS See Chart Below READOUT (Opposite Page) D = Dual H = Half Loaded B C G Y = = = = Sullins Female Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD -S189 = .200” [5.08 mm] Row to Row on Right Angle -S288* = Card Extender Accepts .062” [1.57 mm] PCB * Not Required on KR or KN Terminations MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts S = Side Mounting N = No Mounting D, W = Flush Mounting T, X = Flush Mounting With Threaded Inserts TERMINATION TYPE (Opposite Page) Hairpin Bellows - Available with B or C plating and Phosphor Bronze Only CS = .025” [0.64 mm] Square Dip Solder CM = .025” [0.64 mm] Square Wire Wrap CA, CB, CC = .025” [0.64 mm] Square Right Angle CW, CT = .015” X .025” [0.38 mm X 0.64 mm] Dip Solder Loop Bellows RS = .025” [0.64 mm] Square Dip Solder CK, TK = .025” [0.64 mm] Round Dip Solder RM = .025” [0.64 mm] Square Wire Wrap TA, TB, TM = .025” [0.64 mm] Square Right Angle Cantilever Bellows - Available in Y, B, or C plating Only KS, KD = .025” [0.64 mm] Square Dip Solder KM = .025” [0.64 mm] Square Wire Wrap KA, KE, KU, KJ = .025” [0.64 mm] Square Right Angle KR, KN = .025” [0.64 mm] Square Card Extender MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures CONTACT FINISH - RoHS Compliant DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .297 [7.54] INSERTION DEPTH C REFER TO MOUNTING STYLE .610 [15.49] .250[6.35] A B D E .060[1.52] CONTACT MARKINGS 1 3 5 . . . 137 139 2 4 6 . . . 138 140 .370 [9.40] .180[4.57] .100[2.54] TYP. F 1 3 5 7 9 131 133 135137 139 2 4 6 8 10 132 134 136 138 140 REFER TO TERMINATION TYPE Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. INCHES MILLIMETERS POSITIONS/ CONTACTS A±.008 B±.008 0.500 0.700 06/12 07/14 0.600 0.800 08/16 0.700 0.900 10/20 0.900 1.100 12/24 1.100 1.300 13/26 1.200 1.400 15/30 1.400 1.600 17/34 1.600 1.800 18/36 1.700 1.900 20/40 1.900 2.100 22/44 2.100 2.300 24/48 2.300 2.500 25/50 2.400 2.600 28/56 2.700 2.900 30/60 2.900 3.100 31/62 3.000 3.200 35/70 3.400 3.600 36/72 3.500 3.700 40/80 3.900 4.100 43/86 4.200 4.400 44/88 4.300 4.500 49/98* 4.800 5.000 50/100 4.900 5.100 55/110 5.400 5.600 60/120 5.900 6.100 61/122 6.000 6.200 65/130 6.400 6.600 70/140 6.900 7.100 80/160* 7.900 8.100 90/180* 8.900 9.100 100/200* 9.900 10.100 * Consult factory for availability. C±.015 0.860 0.960 1.060 1.260 1.460 1.560 1.760 1.960 2.060 2.260 2.460 2.660 2.760 3.060 3.260 3.360 3.760 3.860 4.260 4.560 4.660 5.160 5.260 5.760 6.260 6.360 6.760 7.260 8.260 9.260 10.260 D±.010 1.175 1.275 1.375 1.575 1.775 1.875 2.075 2.275 2.375 2.575 2.775 2.975 3.075 3.375 3.575 3.675 4.075 4.175 4.575 4.875 4.975 5.475 5.575 6.075 6.575 6.675 7.075 7.575 8.575 9.575 10.575 E±.020 1.435 1.535 1.635 1.835 2.035 2.135 2.335 2.535 2.635 2.835 3.035 3.235 3.335 3.635 3.835 3.935 4.335 4.435 4.835 5.135 5.235 5.735 5.835 6.335 6.835 6.935 7.335 7.835 8.835 9.835 10.835 F±.015 0.750 0.850 0.950 1.150 1.350 1.450 1.650 1.850 1.950 2.150 2.350 2.550 2.650 2.950 3.150 3.250 3.650 3.750 4.150 4.450 4.550 5.050 5.150 5.650 6.150 6.250 6.650 7.150 8.150 9.150 10.150 A±0.20 12.70 15.24 17.78 22.86 27.94 30.48 35.56 40.64 43.18 48.26 53.34 58.42 60.96 68.58 73.66 76.20 86.36 88.90 99.06 106.68 109.22 121.92 124.46 137.16 149.86 152.40 162.56 175.26 200.66 226.06 251.46 B±0.20 17.78 20.32 22.86 27.94 33.02 35.56 40.64 45.72 48.26 53.34 58.42 63.50 66.04 73.66 78.74 81.28 91.44 93.98 104.14 111.76 114.30 127.00 129.54 142.24 154.94 157.48 167.64 180.34 205.74 231.14 256.54 C±0.38 21.84 24.38 26.92 32.00 37.08 39.62 44.70 49.78 52.32 57.40 62.48 67.56 70.10 77.72 82.80 85.34 95.50 98.04 108.20 115.82 118.36 131.06 133.60 146.30 159.00 161.54 171.70 184.40 209.80 235.20 260.60 D±0.25 29.85 32.39 34.93 40.01 45.09 47.63 52.71 57.79 60.33 65.41 70.49 75.57 78.11 85.73 90.81 93.35 103.51 106.05 116.21 123.83 126.37 139.07 141.61 154.31 167.01 169.55 179.71 192.41 217.81 243.21 268.61 E±0.51 36.45 38.99 41.53 46.61 51.69 54.23 59.31 64.39 66.93 72.01 77.09 82.17 84.71 92.33 97.41 99.95 110.11 112.65 122.81 130.43 132.97 145.67 148.21 160.91 173.61 176.15 186.31 199.01 224.41 249.81 275.21 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com F±0.38 19.05 21.59 24.13 29.21 34.29 36.83 41.91 46.99 49.53 54.61 59.69 64.77 67.31 74.93 80.01 82.55 92.71 95.25 105.41 113.03 115.57 128.27 130.81 143.51 156.21 158.75 168.91 181.61 207.01 232.41 257.81 51
EBC24DKES-S189
物料型号:文档中没有明确指出具体的物料型号,但提到了“Female Card Edge”和一些相关的部件编号,例如“EBC10DCSN-S288”。
器件简介:Sullins Female Card Edge是一种用于电路板边缘连接的器件,具有不同的接触中心距离、绝缘体高度和端接类型。
引脚分配:文档中提供了详细的引脚分配信息,包括不同端接类型的引脚尺寸和位置。
参数特性:文档列出了器件的电气特性,如3安培的电流额定值和最大30毫欧姆的电阻。
功能详解:文档详细描述了器件的功能,包括不同的端接类型,如DIP焊接、线绕和直角端接,以及卡扩展器等。
应用信息:文档中没有直接提供应用信息,但根据器件的描述,可以推断它适用于需要电路板边缘连接的各种电子应用。
封装信息:文档提供了封装的详细尺寸和公差信息,包括插入深度、接触标记和不同位置的尺寸。
EBC24DKES-S189 价格&库存
很抱歉,暂时无法提供与“EBC24DKES-S189”相匹配的价格&库存,您可以联系我们找货
