Female Card Edge
.156” [3.96 mm] Contact Centers, .610” [15.49 mm] Insulator Height,
Dip Solder/Wire Wrap/Right Angle for .093”[2.36 mm] or .125”[3.18 mm] Mating PCB
SPECIFICATIONS
• Accommodates .093” ± .008” [2.36 mm ± 0.20 mm] or
.125” ± .008” [3.18 mm ± 0.20 mm] mating PCB
(Consult factory for .031” ± .006” [0.79 mm ± 0.15 mm] PC boards)
• PBT, PPS or PA9T insulator
• Molded-in key available
• 3 Amps current rating for one contact energized
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
Female Card Edge
READOUT
DUAL (D)
TERMINATION TYPE
L
TERMINATION
TYPE
.030” [0.76]
.150” [3.81]
L
.250” [6.35]
K
LOOP
BELLOWS
(RS, RM)
RIGHT ANGLE
DIP SOLDER
(TA, TB, TM)
POST CROSS
SECTION (K)
POST LENGTH
L ± .025ʺ [0.64]
FITS MIN.
HOLE SIZE
RS
Dip Solder
.025ʺ [0.64] SQUARE
.190ʺ [4.83]
.040ʺ [1.02]
RM
Wire Wrap
.025ʺ [0.64] SQUARE
.560ʺ [14.20]
.040ʺ [1.02]
TA
Right Angle
.025ʺ [0.64] SQUARE
.100ʺ [2.54]
.043ʺ [1.09]
TB
Right Angle
.025ʺ [0.64] SQUARE
.180ʺ [4.57]
.043ʺ [1.09]
TM
Right Angle
.025ʺ [0.64] SQUARE
.250ʺ [6.35]
.043ʺ [1.09]
PCB LAYOUT
COMPONENT SIDE
.156” [3.96] TYP.
Ø .040” [1.02]
.250” [6.35]
2X Ø .125” [3.18]
A
.156” [3.96] TYP.
Ø .043” [1.09]
.150” [3.81]
2X Ø .125” [3.18]
.095” [2.41]
A
D
D
STRAIGHT PIN TERMINATIONS
(RS, RM)
RIGHT ANGLE TERMINATIONS
(TA, TB, TM)
MOUNTING STYLE
#4-40
Ø.125” [3.18]
.250” [6.35]
.250” [6.35]
FLUSH MOUNTING
(D)
76
NO MOUNTING
EARS (N)
FLUSH MOUNTING WITH
THREADED INSERT (T)
Ø.125” [3.18]
.250” [6.35]
FLUSH MOUNTING WITH
SIDE HOLES (Z)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
Dip Solder/Wire Wrap/Right Angle for .093” [2.36 mm] or .125” [3.18 mm] Mating PCB
PART NUMBER OPTIONS
E B M 43 D RM D - S273
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/ Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
MODIFICATION CODE (Consult Factory)
-S273 = FOR .093” ± .008” [2.36 mm ± 0.20 mm]
THICK MATING PCB
-S664 = FOR .125” ± .008” [3.18 mm ± 0.20 mm]
THICK MATING PCB
MOUNTING STYLE (Opposite Page)
N = No Mounting
D = Flush Mounting
T = Flush Mounting With Threaded Inserts
Z = Flush Mounting With Side Holes
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Termination
.000100” Pure Tin, Matte
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
TERMINATION TYPE (Opposite Page)
RS = .025” [0.64 mm] Square Dip Solder
RM = .025” [0.64 mm] Square Wire Wrap
TA, TB, TM = .025” [0.64 mm] Square Right Angle
READOUT (Opposite Page)
D = Dual
Female Card Edge
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
CONTACT CENTERS
M = .156” [3.96 mm]
B
C
G
Y
NUMBER OF CONTACT POSITIONS
See Chart Below
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
.297 [7.54] INSERTION DEPTH
C
REFER TO MOUNTING STYLE
.360
[9.14]
.470 [11.94]
.610
[15.49]
A
B
D
E
.060
[1.52]
REFER TO
TERMINATION TYPE,
SEE OPPOSITE PAGE
.156 [3.96] TYP.
F
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
POSITIONS/
CONTACTS A±.008
INCHES
MILLIMETERS
B±.008
C±.015
D±.010
E±.020
F±.015
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
F±0.38
06/12
0.780
1.102
1.221
1.534
1.784
1.104
19.81
27.99
31.01
38.96
45.31
28.04
08/16*
1.092
1.414
1.533
1.846
2.096
1.416
27.74
35.92
38.94
46.89
53.24
35.97
10/20
1.404
1.726
1.845
2.158
2.408
1.728
35.66
43.84
46.86
54.81
61.16
43.89
12/24
1.716
2.038
2.157
2.470
2.720
2.040
43.59
51.77
54.79
62.74
69.09
51.82
15/30
2.184
2.506
2.625
2.938
3.188
2.508
55.47
63.65
66.68
74.63
80.98
63.70
18/36
2.652
2.974
3.093
3.406
3.656
2.976
67.36
75.54
78.56
86.51
92.86
75.59
20/40
2.964
3.286
3.405
3.718
3.968
3.288
75.29
83.46
86.49
94.44
100.79
83.52
22/44
3.276
3.598
3.717
4.030
4.280
3.600
83.21
91.39
94.41
102.36
108.71
91.44
24/48*
3.588
3.910
4.029
4.342
4.592
3.912
91.14
99.31
102.34
110.29
116.64
99.37
25/50*
3.744
4.066
4.185
4.498
4.748
4.068
95.10
103.28
106.30
114.25
120.60
103.33
28/56*
4.212
4.534
4.653
4.966
5.216
4.536
106.98
115.16
118.19
126.14
132.49
115.21
30/60*
4.524
4.846
4.965
5.278
5.528
4.848
114.91
123.09
126.11
134.06
140.41
123.14
31/62*
4.680
5.002
5.121
5.434
5.684
5.004
118.87
127.05
130.07
138.02
144.37
127.10
32/64
4.836
5.158
5.277
5.590
5.840
5.160
122.83
131.01
134.04
141.99
148.34
131.06
36/72
5.460
5.782
5.901
6.214
6.464
5.784
138.68
146.86
149.89
157.84
164.19
146.91
40/80*
6.084
6.406
6.525
6.838
7.088
6.408
154.53
162.71
165.74
173.69
180.04
162.76
43/86*
6.552
6.874
6.993
7.306
7.556
6.876
166.42
174.60
177.62
185.57
191.92
174.65
* Consult factory for availability.
77
很抱歉,暂时无法提供与“GBM08DRSN-S664”相匹配的价格&库存,您可以联系我们找货
