EBM43DKAN
EBM43DKAN
    SULLINS
    CONNEDGEDUALFMALE86POS0.156
EBM43DKAN 数据手册
Female Card Edge .156” [3.96 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle/Card Extender Sullins Female Card Edge SPECIFICATIONS • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board (See following pages for .093” ± .008” [2.36 mm ± 0.20 mm] and .125”± .008” [3.18 mm ± 0.20 mm] mating PCB) • PBT, PPS or PA9T insulator • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current READOUT • UL Flammability Rating: 94V-0 POLARIZING KEY PLC-K1 .038” [0.97] .285” [7.24] NUMBER SIDE .100” [2.54] DUAL (D) KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) HALF LOADED (H) TERMINATION TYPE POST CROSS SECTION K PPOST LENGTH L .025”ʺ [0.64] .015ʺ X .025ʺ [0.38 X 0.64] .015ʺ X .025ʺ [0.38 X 0.64] .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .125ʺ [3.18] .170ʺ [4.32] .160ʺ [4.06] .560ʺ [14.20] .035ʺ .035ʺ .040ʺ .040ʺ .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .025ʺ [0.64] SQUARE .100ʺ [2.54] .180ʺ [4.57] .250ʺ [6.35] .043ʺ [1.09] .043ʺ [1.09] .043ʺ [1.09] HAIRPIN TERMINATION BELLOWS TYPE CW CT CS CM CA CB CC DIP SOLDER DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE LOOP TERMINATION BELLOWS TYPE POST LENGTH L .025”ʺ [0.64] FITS MIN. HOLE SIZE .025ʺ [0.64] ROUND .190ʺ [4.83] .033ʺ [0.84] .025ʺ [0.64] SQUARE .190ʺ [4.83] .040ʺ [1.02] .025ʺ [0.64] SQUARE .560ʺ [14.20] .040ʺ [1.02] .025ʺ [0.64] SQUARE .100ʺ [2.54] .043ʺ [1.09] .025ʺ [0.64] SQUARE .180ʺ [4.57] .043ʺ [1.09] .025ʺ [0.64] SQUARE .250ʺ [6.35] .043ʺ [1.09] POST CROSS SECTION POST LENGTH L K .025”ʺ [0.64] CANTILEVER TERMINATION TYPE KS KD KM *KA *KE *KU *KJ DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE .025ʺ [0.64] SQUARE .190ʺ [4.83] .040ʺ [1.02] .025ʺ [0.64] SQUARE .160ʺ [4.06] .043ʺ [1.09] .025ʺ [0.64] SQUARE .560ʺ [14.20] .040ʺ [1.02] .025ʺ [0.64] SQUARE .100ʺ [2.54] .043ʺ [1.09] .025ʺ [0.64] SQUARE .180ʺ [4.57] .043ʺ [1.09] .025ʺ [0.64] SQUARE .250ʺ [6.35] .043ʺ [1.09] .025ʺ [0.64] SQUARE .500ʺ [12.70] .043ʺ [1.09] *KR CARD EXTENDER .025ʺ [0.64] SQUARE .235ʺ [5.97] N/A *KN CARD EXTENDER .025ʺ [0.64] SQUARE .605ʺ [15.37] N/A RIGHT ANGLE HAIRPIN BELLOWS [0.89] [0.89] [1.02] [1.02] POST CROSS SECTION K DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE TK,CK RS RM TA TB TM FITS MIN. HOLE SIZE L .275” [6.98] L K .200” [5.08] (CW, CT, CS, CM) LETTER SIDE (SIZES 6 THRU 43) ODD NUMBER SIDE K .150” [3.81] (47 AND 50) (CA, CB, CC, TA, TB, TM, KA, KE, KU, KJ) LOOP BELLOWS L L - .015” [0.38] K .200” [5.08] (TK, CK, RS, RM) FITS MIN. HOLE SIZE HAIRPIN or LOOP CARD EXTENDER CANTILEVER K ACCOMMODATES .062” [1.57] PCB (CT, CS, CM,TK, CK, RS,RM) Example P/N: EBM10DCSN-S288 (Requires -S288 Modification Code) CANTILEVER CARD EXTENDER .550” [13.97] L K .200” [5.08] (KS, KD, KM) L K ACCOMMODATES .062” [1.57] PCB (KR, KN) Example P/N: EBM10DKRN (-S288 Not required) * KA, KE, KJ, KR, KN have no standoffs, unless requested. MOUNTING STYLE Ø.125” [3.18] #4-40 Ø.125” [3.18] .250” [6.35] .245” [6.22] CLEARANCE HOLE (H) 74 Ø.125” [3.18] THREADED INSERT(I) SIDE MOUNTING (S) D = .250” [6.35] W = .430” [10.92] NO MOUNTING EARS (N) FLUSH MOUNTING (D, W) #4-40 T = .250” [6.35] X = .430” [10.92] FLUSH MOUNTING WITH THREADED INSERT(T, X) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .156” [3.96 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle/Card Extender PART NUMBER OPTIONS E B M 43 D CM H - Sxxx MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts S = Side Mounting N = No Mounting D, W = Flush Mounting T, X = Flush Mounting With Threaded Inserts TERMINATION TYPE (Opposite Page) Hairpin Bellows Available with B or C plating and Phosphor Bronze Only CS = .025” [0.64 mm] Square Dip Solder CM = .025” [0.64 mm] Square Wire Wrap CA, CB, CC = .025” [0.64 mm] Square Right Angle CW, CT = .015” X .025” [0.38 mm X 0.64 mm] Dip Solder Loop Bellows RS = .025” [0.64 mm] Square Dip Solder CK, TK = .025” [0.64 mm] Round Dip Solder RM = .025” [0.64 mm] Square Wire Wrap TA, TB, TM = .025” [0.64 mm] Square Right Angle Cantilever Bellows - Available in Y, B, or C Contact Finish Only KS, KD = .025” [0.64 mm] Square Dip Solder KM = .025” [0.64 mm] Square Wire Wrap KA, KE, KU, KJ = .025” [0.64 mm] Square Right Angle KR, KN = .025” [0.64 mm] Square Card Extender CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y = = = = Sullins Female Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD -S189 = .200” [5.08 mm] Row Spacing on Right Angle -S288* = Card Extender Accepts .062” [1.57 mm] PCB * Not Required on KR or KN Terminations MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/ Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte CONTACT CENTERS M = .156” [3.96 mm] NUMBER OF CONTACT POSITIONS See Chart Below READOUT (Opposite Page) D = Dual H = Half Loaded DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. REFER TO MOUNTING STYLE .297 [7.54] INSERTION DEPTH C .250 [6.35] .180 [4.57] .370 [9.40] A 1 A B D E .060 [1.52] .610 [15.49] .156 [3.96] TYP. REFER TO TERMINATION TYPE F B 2 C 3 _ X_ Y_ W 41 42 43 CONTACT MARKINGS (LETTERS G, I, O & Q NOT USED) SIZES 06 THRU 25, 28, 30 & 31: 1 2 . . . 23 24 . . . 29 30 AB ... A B ... H J SIZES 36 THRU 43: A B ... A B ... X Y 1 2 . . . 23 24 . . . 42 43 SIZES 47 & 50: 1 3 . . . 97 99 2 4 . . . 98 100 Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS INCHES A±.008 B±.008 06/12 0.780 1.102 08/16 1.092 1.414 10/20 1.404 1.726 12/24 1.716 2.038 15/30 2.184 2.506 18/36 2.652 2.974 20/40* 2.964 3.286 22/44 3.276 3.598 24/48 3.588 3.910 25/50 3.744 4.066 28/56 4.212 4.534 30/60 4.524 4.846 31/62 4.680 5.002 36/72 5.460 5.782 40/80 6.084 6.406 43/86 6.552 6.874 47/94 7.176 7.498 50/100 7.644 7.966 * Consult factory for availability. MILLIMETERS C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 1.221 1.533 1.845 2.157 2.625 3.093 3.405 3.717 4.029 4.185 4.653 4.965 5.121 5.901 6.525 6.993 7.617 8.085 1.534 1.846 2.158 2.470 2.938 3.406 3.718 4.030 4.342 4.498 4.966 5.278 5.434 6.214 6.838 7.306 7.930 8.398 1.784 2.096 2.408 2.720 3.188 3.656 3.968 4.280 4.592 4.748 5.216 5.528 5.684 6.464 7.088 7.556 8.180 8.648 1.030 1.342 1.654 1.966 2.434 2.902 3.214 3.526 3.838 3.994 4.462 4.774 4.930 5.710 6.334 6.802 7.426 7.894 19.81 27.74 35.66 43.59 55.47 67.36 75.29 83.21 91.14 95.10 106.98 114.91 118.87 138.68 154.53 166.42 182.27 194.16 27.99 35.92 43.84 51.77 63.65 75.54 83.46 91.39 99.31 103.28 115.16 123.09 127.05 146.86 162.71 174.60 190.45 202.34 31.01 38.94 46.86 54.79 66.68 78.56 86.49 94.41 102.34 106.30 118.19 126.11 130.07 149.89 165.74 177.62 193.47 205.36 38.96 46.89 54.81 62.74 74.63 86.51 94.44 102.36 110.29 114.25 126.14 134.06 138.02 157.84 173.69 185.57 201.42 213.31 45.31 53.24 61.16 69.09 80.98 92.86 100.79 108.71 116.64 120.60 132.49 140.41 144.37 164.19 180.04 191.92 207.77 219.66 26.16 34.09 42.01 49.94 61.82 73.71 81.64 89.56 97.49 101.45 113.33 121.26 125.22 145.03 160.88 172.77 188.62 200.51 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 75
EBM43DKAN
1. 物料型号:文档中提到了多种型号,例如EBM10DCSN-S288,以及不同的配置代码,如-S288用于卡扩展件。
2. 器件简介:文档描述了Sullins Female Card Edge连接器,具有.156” [3.96 mm]接触中心和.610” [15.49 mm]绝缘体高度。它们适用于DIP焊接、线圈缠绕、直角和卡扩展件。
3. 引脚分配:文档提供了详细的引脚分配表,包括不同配置的引脚,例如Hairpin Bellows、Loop Bellows和Cantilever等。
4. 参数特性:文档列出了连接器的规格,包括能够适配不同厚度的PCB板、使用PBT、PPS或PA9T作为绝缘体材料、具有3安培的电流额定值以及在额定电流下最大30毫欧姆的电阻。
5. 功能详解:文档详细描述了不同部件的功能,如极化键PLC-K1的UL阻燃等级94V-0,以及不同接触表面的镀层,如金和纯锡。
6. 应用信息:文档提供了关于如何使用这些连接器的详细信息,包括不同的安装风格和接触完成类型。
7. 封装信息:文档包含了连接器的尺寸和安装深度等信息。
EBM43DKAN 价格&库存
很抱歉,暂时无法提供与“EBM43DKAN”相匹配的价格&库存,您可以联系我们找货
