ED951/5
ED951/5
    OST
    P=5mm
    接线端子 间距:5.00mm 1x5P 自由悬挂
ED951/5 数据手册
ED950/X (5.0 mm) EDZ950/X (5.08 mm) ED951/X (5.0 mm) EDZ951/X (5.08 mm) 2-24 poles, Spacing 5.0 mm or 5.08 mm insert required no. of poles x 2-10 poles, Spacing 5.0 mm or 5.08 mm insert required no. of poles x How to order see page 5 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize 250 V 12 A (T60) 2.5 mm 2 4 kV/3 0.5 Nm/M3 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 2.5 mm 2 2.5 mm 2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 2.5 mm 2 2.5 mm 2 Dimensions Spacing Stripped Length 5.0 mm (5.08 mm) 6.0 mm Dimensions Spacing Stripped Length 5.0 mm (5.08 mm) 6.0 mm Materials Insulating Material Flammability Class Temperature Range Terminal Block Contact PA UL94 V-0 -30 C/+105 C CuZn CuSn Materials Insulating Material Flammability Class Temperature Range Terminal Block Contact PA UL94 V-0 -30 C/+105 C CuZn CuSn Color Green 36 How to order see page 5 300 V 15 A AWG 22-12 300 V 15 A AWG 22-12 250 V 12 A (T60) 2.5 mm 2 4 kV/3 0.5 Nm/M3 Color Green ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 36
ED951/5 价格&库存
很抱歉,暂时无法提供与“ED951/5”相匹配的价格&库存,您可以联系我们找货
ED951/5
  • 50+32.7481250+4.23685
