8
7
4
5
6
1
2
3
REVISIONS
E
REV.
ECO. NO
B
2617
C
2511
DESCRIPTION
DATE
ADD 03-POSITION & RJ TERMINATION OPTIONS, UPDATE DIM 'F' 6/13/2012
TOLERANCE & DWG FORMAT
ADDED S38, S81 & S328 OPTIONS
2/6/2013
BY
JH
KV
F
D
F
B
A
.075[1.90]
SEE NOTE 13
E
2X
.125 3.18
THRU
E
F
C
.030 0.76
A
D
.265 6.73
INSERTION
DEPTH
.431 10.95
D
.245 6.22
.025 0.64
FITS
.043 MIN HOLE
C
.032 0.81
_ _ C _ _ DRXH
_ _ C _ _ DRJH
RX= .200 5.08
RJ= .250[6.13]
.100 2.54
A
RX= .185±.025 4.70±0.64
RJ = .165 .025[4.19 0.64]
TAIL LENGTH
C
SECTION A - A
CONTACT IDs:
B 1 2 3 ... 60 B
A 1 2 3 ... 60 A
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
CONTACT ID
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
SCALE 6:1
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
16. MODIFICATION: SEE PART NUMBER CODING
8
7
6
5
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
6/14/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
_ _ C _ _ DRX (RJ) _(-S38, S81, S328)
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
CONNECTOR, .100 CC LP
2
DWG. NO.
C10881
SHEET 1 OF 3
1
REV
C
FILE NAME: C10881, _ _C_ _DRX (RJ)_-(OMIT, S38, S81, S328)
8
7
4
5
6
2x
1
2
3
.125 3.18
F
F
C
D
2X
.125 3.18 THRU
.135 3.43
E
_ _ C _ _ DRXN
_ _ C _ _ DRJN
E
_ _ C _ _ DRXS
_ _ C _ _ DRJS
2X FLOATING BOBBIN
.116 [2.95] CLEARANCE
FOR # 4 SCREW
2X #4-40
THREADED INSERTS
D
D
.280 7.11
.245 6.22
C
C
_ _ C _ _ DRXI
_ _ C _ _ DRJI
A
_ _ C _ _ DRXF
_ _ C _ _ DRJF
2X .065 1.65
B
B
L±.015[0.38]
(L= DIM 'A' + .130[3.30])
CUSTOMER COPY
A
Pb
_ _ C _ _ DRXB
_ _ C _ _ DRJB
RoHS COMPLIANT
8
7
6
5
4
6/14/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C10881
SHEET 2 OF 3
1
REV
C
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
6/14/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C10881
SHEET 3 OF 3
1
REV
C
很抱歉,暂时无法提供与“ECC18DRJH”相匹配的价格&库存,您可以联系我们找货
