MPSL-1100-20-DW-4K
MPSL-1100-20-DW-4K
    SULLINS
    CONNEDGEDUALFMALE40POS0.100
MPSL-1100-20-DW-4K 数据手册
8 7 4 5 6 REV. ECO. NO A 871 B 2491 E .020[ 0.51] F 1 2 3 REVISIONS DESCRIPTION INITIAL RELEASE UPDATED PN CODING TO INCLUDE MTL, COLOR & PLATING OPTIONS, NOTE & DWG FORMAT, INSERTION FORCE TO 8 OZ MAX, ADD CONTACT GAP DIM, TAIL TOLERANCE D .010[ 0.25] B .008[ .20] A .008[ .20] DATE BY 12/29/2005 HT 11/8/2011 JH F .370 9.40 E .075 1.91 SEE NOTE 13 .125 3.18 2X C±.015[ .38] A +.005 +0.13 .370 9.40 - .015 - 0.38 E .030±.010 0.76±0.25 .180 4.57 .250 6.35 .610 15.49 .297 7.54 INSERTION DEPTH D .560±.025 14.22±0.64 TAIL LENGTH .060 1.52 .025 0.64 .100 2.54 A .200 5.08 ROW SPACING F .015[ .38] SECTION A-A MPSL - _100 - _ _ - DW - 5_ _ _ C D CONTACT MARKINGS 1 3 5 ... 137 139 2 4 6 ... 138 140 D A 2X C .125 3.18 .200 5.08 .040 1.02 MIN .100 2.54 PCB LAYOUT RECOMMENDED B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. DIELECTRIC WITHSTANDING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMP PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB B REF: _ _C_ _DRM _ (- S38, S81, S328) CUSTOMER COPY Pb RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 11/8/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C MP_ _ - _100 - _ _ - DW - _ _ _ _ CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD, .100 CC 2 DWG. NO. C10649 SHEET 1 OF 3 1 REV B FILE NAME: C10649, MP_ _-_100-_ _-DW-_ _ _ _ 8 7 4 5 6 1 2 3 D F 2X F .125 3.18 2X #4-40 THREADED INSERT .250 6.35 E E .060 1.52 MPSL - _100 - _ _ - DW - 1_ _ _ MPSL - _100 - _ _ - DW - 2_ _ _ C D D 2X #4-40 THREADED INSERT C C MPSL - _100 - _ _ - DW - 4_ _ _ B 2X MPSL - _100 - _ _ - DW - 6_ _ _ D±.010[ 0.25] .125 3.18 .245 6.22 CUSTOMER COPY Pb A MPSL - _100 - _ _ - DW - 8_ _ _ RoHS COMPLIANT 8 B 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 11/8/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C MP_ _ - _100 - _ _ - DW - _ _ _ _ CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD, .100 CC 2 DWG. NO. C10649 SHEET 2 OF 3 1 REV B FILE NAME: C10649, MP_ _-_100-_ _-DW-_ _ _ _ 8 7 4 5 6 1 2 3 F F E E D D C C B B A CUSTOMER COPY 8 7 6 5 Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 11/8/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C MP_ _ - _100 - _ _ - DW - _ _ _ _ CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD, .100 CC 2 DWG. NO. C10649 SHEET 3 OF 3 1 REV B FILE NAME: C10649, MP_ _-_100-_ _-DW-_ _ _ _
MPSL-1100-20-DW-4K 价格&库存
很抱歉,暂时无法提供与“MPSL-1100-20-DW-4K”相匹配的价格&库存,您可以联系我们找货
