RL1220S-R15-F
RL1220S-R15-F
    SUSUMU
    贴片电阻 0805 150MΩ ±1% 330W 0~+200ppm/℃
RL1220S-R15-F 数据手册
Low resistance chip resistors (short-side terminal) ■RL series Features ・ Innovative structure that takes consideration of heat dissipation suppress the surface temperature enabling the small sizes reducing the influence of heat on surrounding components. Applications ・ PC power sources, inverters, automotive electronics, adopters, industrial machines *1 RL series Current sensing surface mount resistors * 1:Except for RL0510, RL1632 and RL3264 ◆Part numbering system RL 1220 S - 1R0 - F RL 1632 S - R047 - F - T5 Resistance tolerance Packing quantity , :T1 (1,000pcs) T5 (5,000pcs) Nominal resistance Value 1R0=1.0Ω Series code Resistance tolerance Nominal resistance Value 4digit Temperature coefficient of resistance Temperature coefficient of resistance Series code Size : RL0510, RL0816, RL1220 Size : RL1632 ◆Electrical Specification Type Power ratings Temperature coefficient of resistance Resistance range(Ω) Resistance tolerance (ppm/°C) 1/8W RL0510 1/6W 1/4W 0 ∼ +350(T) 0 ∼ +200(S) 1/5W 1/4W RL1220 RL1632 1/2W 57 ー 100m≦R≦6.8 10,000pcs ー -55℃ 7.5≦R≦68 0 ∼ +200(S) 43m≦91m 0 ∼ +350(T) 10m≦91m √(P・R) E-24 ~ 125℃ 5,000pcs 100m≦R≦10 0 ∼ +200(S) 11≦R≦100 510m≦R≦4.7 0 ∼ +200(S) 0 ∼ +500(T) *1 ー 100m≦R≦4.7 20m≦R<100m 0 ∼ +200(S) 0 ∼ +350(T) Packaging quantity ±5% (J) 50m≦R<100m 0 ∼ +350(T) 0 ∼ +100(R) Resistance Operating value series temperature 5.1≦R≦47 0 ∼ +100(R) 1/3W ±2% (G) 0 ∼ +200(S) 0 ∼ +100(R) RL0816 ±1% (F) Maximum voltage *1 56m≦R≦470m 33m≦R≦51m ー ー 27m≦R≦30m 18m≦R≦24m ー 10m≦R≦16m RL series with resistance tolerance 0.5% is also available. Please contact our sales office. ー T1 T5 ◆Dimensions L Size Type RL0510 W RL0816 a RL1220 t (inch) R≦0.2Ω R>0.2Ω R≦0.082Ω R>0.091Ω R≦0.068Ω R>0.075Ω RL1632 0402 L W a 1.00±0.05 0.50±0.05 0.15±0.10 b t 0.25±0.10 0.35+0.15/−0.10 0.15±0.10 0.35±0.10 0.25±0.20 0.45+0.15/−0.10 0.20±0.15 0.45±0.10 0603 1.60±0.20 0.80±0.20 0.20±0.15 0805 2.00±0.20 1.25±0.20 0.40±0.20 0.40±0.20 1206 3.20±0.20 1.60±0.20 ー 1.00±0.15 0.50±0.20 0.40±0.10 0.50±0.15 b (unit:mm) 100 50 0 −55 50 0 70 100 RL series Ratio to rated power (%) Current sensing surface mount resistors ◆Derating Curve 125 155 Ambient temperature (℃) ◆Resistance to power pulse Maximum pulse power limit(W) 200 RL7520W-R10 RL7520-R10 150 100 Test procedure RL3264-R050 Voltage pulse is applied to the test samples mounted on the test board. RL1632-R050 After each pulse, resistance drift is measured. Pulse 50 voltage is increased until the drift exceeds +/-0.5%. RL1220-R10 0 0.001 0.01 The power at that voltage is defined as the maximum 0.1 1 10 pulse power. Pulse duration(seconds) 58
RL1220S-R15-F
物料型号:RL系列,包括RL0510、RL0816、RL1220、RL1632等尺寸。
器件简介:这些电阻器具有创新的结构,考虑了散热,降低了表面温度,减小了尺寸,减少了对周围组件的热影响。
引脚分配:文档中未明确提供引脚分配信息。
参数特性:包括电阻值、公差、温度系数、最大电压、电阻值系列、工作温度范围、包装数量等。
功能详解:文档描述了电阻器的电流检测功能,包括对功率脉冲的耐受性测试程序。
应用信息:适用于PC电源、逆变器、汽车电子、适配器、工业机械等领域。
封装信息:提供了不同尺寸的详细尺寸数据,单位为毫米。
RL1220S-R15-F 价格&库存
很抱歉,暂时无法提供与“RL1220S-R15-F”相匹配的价格&库存,您可以联系我们找货
RL1220S-R15-F
  • 5000+0.366085000+0.04760
  • 15000+0.3412315000+0.04437
库存:91598
RL1220S-R15-F
  • 1+0.970971+0.12626
  • 10+0.5473710+0.07118
  • 50+0.4818650+0.06266
  • 100+0.45529100+0.05920
  • 500+0.39989500+0.05200
库存:91598
