Female Card Edge
.150” [3.81 mm] Contact Centers, .550” [13.97 mm] Insulator Height,
Dip Solder/Wire Wrap
Sullins Female Card Edge
SPECIFICATIONS
Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
PBT, PPS or PA9T insulator
Molded-in key available
3 Amps current rating for one contact energized
30 milli Ohms maximum at rated current
UL Flammability Rating: 94V-0
READOUT
POLARIZING KEY
PLC-K1
.285”
[7.24]
EVEN
NUMBER
SIDE
.150” [3.81]
DUAL (D)
.038”
[0.97]
.100” [2.54]
KEY IN BETWEEN CONTACTS
(ORDER SEPARATELY)
HALF LOADED (H)
TERMINATION TYPE
.620” [15.75]
.025” [0.64]
SQUARE POST,
FITS Ø.040” [1.02]
MINIMUM
WIRE WRAP (MC)
.220” [5.59]
.025” [0.64]
SQUARE POST,
FITS Ø.040” [1.02]
MINIMUM
DIP SOLDER (SC)
MOUNTING STYLE
Ø.125”
[3.18]
#4-40
.250”
[6.35]
CLEARANCE
HOLE (H)
68
THREADED
INSERT (I)
NO MOUNTING
EARS (N)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B J 26 D MC H - Sxxx
MOUNTING STYLE (Opposite Page)
H = Clearance Holes
I = Threaded Inserts
N = No Mounting
CONTACT FINISH - RoHS Compliant
TERMINATION TYPE (Opposite Page)
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
B = .000010” Gold
C = .000030” Gold
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
Hairpin Bellows
Termination
.000100” Pure Tin, Matte
MC = .025” [0.64 mm] Square Wire Wrap
SC = .025” [0.64 mm] Square Dip Solder
CONTACT CENTERS
J = .150” [3.81 mm]
NUMBER OF CONTACT POSITIONS
See Chart Below
READOUT (Opposite Page)
D = Dual
H = Half Loaded
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
REFER TO MOUNTING STYLE
A
B
D
E
.297 [7.54] INSERTION DEPTH
C
.250 [6.35]
.325 [8.26]
.180 [4.57]
.550 [13.97]
REFER TO TERMINATION TYPE
.150 [3.81] TYP.
.150 [3.81]
F
1
3
5
47
49 51
2
4
6
48
50
52
CONTACT MARKINGS
1 3 5 . . . 47 49 51
2 4 6 . . . 48 50 52
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
POSITIONS/
CONTACTS
INCHES
MILLIMETERS
A±.008
B±.008
C±.015
D±.010
E±.020
F±.015
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
F±0.38
12/24
1.650
1.950
2.090
2.400
2.650
1.900
41.91
49.53
53.09
60.96
67.31
48.26
18/36*
2.550
2.850
2.990
3.300
3.550
2.800
64.77
72.39
75.95
83.82
90.17
71.12
22/44*
3.150
3.450
3.590
3.900
4.150
3.400
80.01
87.63
91.19
99.06
105.41
86.36
26/52
3.750
4.050
4.190
4.500
4.750
4.000
95.25
102.87
106.43
114.30
120.65
101.60
28/56*
4.050
4.350
4.490
4.800
5.050
4.300
102.87
110.49
114.05
121.92
128.27
109.22
* Consult factory for availability.
69
很抱歉,暂时无法提供与“ECJ26DMCH”相匹配的价格&库存,您可以联系我们找货
