CSR / CSRN Series
Stackpole Electronics, Inc.
Thick Film Current Sensing Resistor
Resistive Product Solutions
Features:
0201 to 1225 sizes available
Power ratings to 3W
Low inductance - < 2nH typically
Non-standard resistance values available
0815, 2010 and 2512 sizes available with narrow terminations (CSRN)
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications - CSR
Type/Code
Power Rating (W)
@ 70°C
Dielectric
Withstanding
Voltage (V)
CSR0201
0.05
200
CSR0402
CSR0603
CSR0805
CSR1206
0.125
0.125
0.25
0.5
200
200
200
200
CSR1210
0.5
200
CSR2010
CSR2512
1
2
200
200
CSR0830
2
200
CSR1225
3
TCR (ppm/ºC)
Ohmic Range (Ω) and Tolerance
1%
± 1000
± 600
± 300
± 200
± 300
± 200
± 100 (1)
± 600
± 400
± 300
± 200
± 100 (1)
± 200
± 300
± 200
± 150
± 300
± 200
± 150
± 100
200
2%, 5%
0.1 - 0.147
0.15 - 0.499
0.511 - 1
0.0511 - 1
0.02 - 1
0.02 - 1
0.01 - 1
0.01 - 0.02
0.0205 - 0.0511
0.0523 - 0.0976
0.1 - 1
0.01 - 1
0.01 - 1
0.001 - 0.004
0.0051 - 0.01
0.0102 - 0.348
0.003 - 0.0049
0.0051 - 0.02
0.0205 - 0.0301
0.0332 - 7.87
(1) Contact Stackpole for TCR below 50 mohm
Electrical Specifications – CSRN (Narrow Termination)
Type/Code
Power Rating (W)
@ 70°C
CSRN2010
1
Dielectric
Withstanding
Voltage (V)
200
CSRN0815
1
200
CSRN2512(*)
(*) AEC-Q200 Qualified
2
200
TCR (ppm/ºC)
± 250
± 300
± 150
± 200
1%, 2%, 5%
0.01 - 1
0.01 - 0.0196
0.02 - 0.499
0.01 - 1
Electrical Specifications – CSR-HP
Type/Code
CSR0603…-HP
Power Rating (W)
@ 70°C
Dielectric
Withstanding
Voltage (V)
TCR (ppm/ºC)
200
± 400
± 300
± 200
0.2
Rev Date: 10/28/2022
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
1%, 2%, 5%
0.051 - 0.1
0.102 - 0.499
0.51 - 1
www.seielect.com
marketing@seielect.com
CSR / CSRN Series
Electrical Specifications – CSR-HP (cont.)
Dielectric
Withstanding
Voltage (V)
Power Rating (W)
@ 70°C
Type/Code
CSR1210…-HP
0.75
TCR (ppm/ºC)
200
± 600
± 400
± 300
1%, 2%, 5%
0.01 - 0.02
0.0205 - 0.0499
0.051 - 0.091
± 200
0.1 - 1
Please refer to the High-Power Resistor Application Note (page 8) for more information on designing and implementing high power
resistor types.
Mechanical Specifications - CSR
Type/Code
Weight (g)
(1000 pieces)
L
Body Length
0.024 ± 0.001
0.60 ± 0.03
W
Body Width
0.012 ± 0.001
0.30 ± 0.03
T
Body Height
0.009 ± 0.002
0.23 ± 0.05
D1
Top Termination
0.005 ± 0.002
0.12 ± 0.05
CSR0201
0.18
CSR0402
D2
Unit
Bottom Termination
0.006 ± 0.002
inches
0.15 ± 0.05
mm
0.7
0.039 ± 0.002
1.00 ± 0.05
0.020 ± 0.002
0.50 ± 0.05
0.013 ± 0.004
0.32 ± 0.10
0.010 ± 0.004
0.25 ± 0.10
0.008 ± 0.004
0.20 ± 0.10
inches
mm
CSR0603
1.99
0.063 ± 0.004
1.60 ± 0.10
0.031 ± 0.004
0.80 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
inches
mm
CSR0805
5.3
0.079 ± 0.006
2.00 ± 0.15
0.049 ± 0.006
1.25 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.010
0.40 ± 0.25
inches
mm
CSR1206
8.82
0.120 ± 0.006
3.05 ± 0.15
0.061 ± 0.006
1.55 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.020 ± 0.012
0.50 ± 0.30
0.016 ± 0.010
0.40 ± 0.25
inches
mm
CSR1210
15.5
0.122 ± 0.004
3.10 ± 0.10
0.102 ± 0.006
2.60 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.010
0.50 ± 0.25
inches
mm
CSR2010
27.03
0.197 ± 0.008
5.00 ± 0.20
0.100 ± 0.008
2.54 ± 0.20
0.020 ± 0.006
0.50 ± 0.15
0.068 ± 0.006
1.72 ± 0.15
0.067 ± 0.006
1.70 ± 0.15
inches
mm
CSR2512
53.08
0.252 ± 0.008
6.40 ± 0.20
0.126 ± 0.008
3.20 ± 0.20
0.020 ± 0.006
0.50 ± 0.15
0.024 ± 0.012
0.60 ± 0.30
0.079 ± 0.010
2.00 ± 0.25
inches
mm
CSR0830
35.71
0.079 ± 0.008
2.00 ± 0.20
0.295 ± 0.012
7.50 ± 0.30
0.024 ± 0.004
0.60 ± 0.10
0.016 ± 0.008
0.40 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
inches
mm
Type/Code
Weight (g)
(1000 pieces)
CSRN0815
19.96
CSRN2010
CSRN2512
Mechanical Specifications – CSRN (Narrow Termination)
L
Body Length
0.079 ± 0.008
2.00 ± 0.20
W
Body Width
0.148 ± 0.008
3.75 ± 0.20
T
Body Height
0.024 ± 0.004
0.60 ± 0.10
D1
Top Termination
0.016 ± 0.008
0.40 ± 0.20
27.03
0.197 ± 0.008
5.00 ± 0.20
0.096 ± 0.006
2.45 ± 0.15
0.024 ± 0.006
0.60 ± 0.15
0.024 ± 0.012
0.60 ± 0.30
0.020 ± 0.010
0.50 ± 0.25
inches
mm
53.08
0.250 ± 0.008
6.35 ± 0.20
0.124 ± 0.006
3.15 ± 0.15
0.024 ± 0.004
0.60 ± 0.10
0.024 ± 0.012
0.60 ± 0.30
0.022 ± 0.010
0.55 ± 0.25
inches
mm
2
D2
Unit
Bottom Termination
0.016 ± 0.008
inches
0.40 ± 0.20
mm
www.seielect.com
CSR / CSRN Series
Mechanical Specifications – CSR1225
Type/Code
Weight (g)
(1000 pieces)
L
W
T
D1
D2
F
Unit
64.88
0.126 ± 0.006
3.20 ± 0.15
0.254 ± 0.006
6.45 ± 0.15
0.035 ± 0.006
0.90 ± 0.15
0.024 ± 0.012
0.60 ± 0.30
0.031 ± 0.010
0.80 ± 0.25
0.090 ± 0.005
2.29 ± 0.13
inches
mm
CSR1225
Performance Characteristics
Test Method
Test Specification
Typical
Test Condition
High Temperature
Exposure
Test
MIL-STD-202 Method 108
1% Tol: (± 1% + 0.05Ω)
2%, 5% Tol: (± 1.5% + 0.1Ω)
≤ 0.5%
1000 hours at T = 155°C. Unpowered. Measurement
at 24 ± 4 hours after test conclusion.
Short Time
Overload
JIS-C-5201-1 4.13
IEC 60115-1 4.13
± (0.5% + 0.05Ω)
≤ 0.25%
± (1% + 0.05Ω)
For high power rating
≤ 0.5%
RCV (rated current) * 2.5 for 5 seconds.
1000 Cycles (-55°C to +125°C) Measurement at 24 ±
4 hours after test conclusion. 30 minuntes maximum
≤ 0.5%
dwell time at each temperature extreme. 1 minute
maximum transition time.
1000 hours 85°C / 85% RH. Note: Specified
≤ 0.5% conditions: 10% of operating power. Measurement at
Temperature
Cycling
JESD22 Method JA-104
1% Tol: (± 0.5% + 0.05Ω)
Biased Humidity
MIL-STD-202 Method 103
1% Tol: (± 1% + 0.1Ω)
2%, 5% Tol: (± 2% + 0.1Ω)
Operational Life
2%, 5% Tol: (±2% + 0.1Ω)
≤ 0.5%
External Visual
MIL-STD 883 Method 2009
Pass
Physical
Dimensions
JESD22 Method JB-100
Pass
MIL-STD 202 Method 215
Marking unsmeared
Pass
MIL-STD 202 Method 213
1% Tol: (± 0.25% + 0.05Ω)
2%, 5% Tol: (± 1% + 0.05Ω)
≤ 0.5%
Resistance to
Solvents
Mechanical
Shock
Vibration
MIL-STD 202 Method 204
2%, 5% Tol: (±1% + 0.05Ω)
Resistance to
Soldering Heat
MIL-STD 202 Method 210
1% Tol: (± 0.5% +0.05Ω)
ESD
AEC-Q200-002
Solderability
J-STD-002
> 95% Coverage
3
Condition D Steady State TA = 125°C at rated power.
Measurement at 24 ± 4 hours after test conclusion.
Electrical test not required. Inspect device
construction, marking and workmanship.
Verify physical dimensions to the applicable device
detail specification. Note: User(s) and supplier
specification, electrical test not required.
Note: Aqueous wash chemical - OKEM Clean or
equivalent. Do not use banned solvents.
Figure 1 of Method 213. Condition C.
5g's for 20 minuntes, 12 cycles each of 3 orientations.
Note: Use 8" X 5" PCB 0.031" thick 7 secure points on
≤ 0.5%
one long side and 2 secure points at corners of
opposite sides. Parts mounted within 2" from any
secure point. Test from 10 - 2000Hz.
Condition B no pre-heat of samples. Note: Single
≤ 0.5%
wave solder - Procedure 2 for SMD.
With the electrometer in direct contact with the
discharge tip, verify the voltage setting at levels of ±
Pass
500V, ± 1kV, ± 2kV, ± 4kV, ± 8kV. The electrometer
reading shall be within ± 10% for voltages from 500V
to ≤ 8kV.
Electrical test not required. Magnification 50 times.
Conditions: SMD:
Pass a) Method B, 4 hours @ 155°C dry heat @ 235°C.
b) Method B @ 215°C category 3.
c) Method D category 3 at 260°C.
www.seielect.com
CSR / CSRN Series
Performance Characteristics (cont.)
Test
Test Method
Electrical
Characterization
User Spec
Flammability
UL-94
Board Flex
AEC-Q200-005
Terminal Strength
(SMD)
Flame
Retardance
Voltage Proof
Test Specification
Typical
Pass
No ignition of tissue or scorching
Pass
of pine board.
≤ 0.5%
AEC-Q200-006
No breakage
Pass
AEC-Q200-001
No flame
Pass
JIS-C-5201-1 4.7
IEC-60115-1 4.7
No breakdown or flashover
Pass
Test Condition
Parametrically test per lot and sample size
requirements, summary to show Min, Max, Mean and
Standard Deviation at room as well as Min and Max
operating temperatures.
V - 0 or V - 1 are acceptable. Electrical test not
required.
60 second minimum holding time.
1.42 times Max. Operating Voltage for 1 minute.
0201: 50V; 0402: 100V; 0603: 150V; 0805: 300V
1206, 1210, 2010, 2512, 0830, 1225, 0815: 400V
Operating temperature range is -55ºC to +155ºC
Power Derating Curve:
Recommended Pad Layouts - CSR
Type/Code
CSR0201
CSR0402
CSR0603
CSR0805
CSR1206
CSR1210
a
0.010
0.25
0.020
0.50
0.031
0.80
0.039
1.00
0.079
2.00
0.079
2.00
b
0.012
0.30
0.020
0.50
0.039
1.00
0.039
1.00
0.045
1.15
0.045
1.15
4
0.016
0.40
0.024
0.60
0.035
0.90
0.053
1.35
0.067
1.70
0.098
2.50
c
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CSR / CSRN Series
Recommended Pad Layouts – CSR (cont.)
Type/Code
CSR0830
CSR2010
CSR2512
CSR1225
a
0.039
1.00
0.142
3.60
0.193
4.90
0.047
1.20
b
0.071
1.80
0.055
1.40
0.063
1.60
0.079
2.00
0.299
7.60
0.098
2.50
0.126
3.20
0.276
7.00
c
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
Unit
inches
mm
inches
mm
inches
mm
inches
mm
0.154
3.90
0.098
2.50
0.126
3.20
c
0.008
0.20
0.008
0.20
0.008
0.20
Unit
inches
mm
inches
mm
inches
mm
Recommended Pad Layouts - CSRN
Type/Code
CSRN0815
CSRN2010
CSRN2512
a
0.039
1.00
0.142
3.60
0.193
4.90
b
0.071
1.80
0.055
1.40
0.063
1.60
Soldering Conditions
Profile Feature
Preheat
Min. Temperature (Tsmin)
Max. Temperture (Tsmax)
Prehating time (ts) from (Tsmin to Tsmax)
Ramp-up Rate (TL to TP)
Pb-Free Assembly
150°C
200°C
60-120 seconds
3°C/second max.
Liquidous Temperature (TL)
217°C
Time (tL) maintained above TL
60-150 seconds
Min. Peak Temperature (Tp min)
235°C
Max. Peak Temperature (Tp max)
260°C
Time (tp) within 5°C of the specified classification temperature (Tc)
Ramp-down rate (TP to TL)
30 seconds max.
6°C/second max.
Time 25°C to peak temperature
8 minutes max.
5
www.seielect.com
CSR / CSRN Series
Reel Specifications
Size
C
B
A
W
T
0201
0402
0603
0805
0.374 ± 0.004
9.50 ± 0.10
0.453 ± 0.039
11.50 ± 1.00
0.531 ± 0.039
13.50 ± 1.00
0.610 ± 0.039
15.50 ± 1.00
0.689 ± 0.039
17.50 ± 1.00
0.768 ± 0.039
19.50 ± 1.00
1206
1210
7.008 ± 0.039
178.00 ± 1.00
2.362 ± 0.039
60.00 ± 1.00
0.531 ± 0.028
13.50 ± 0.70
2010
2512
1225
0815
0830
6
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CSR / CSRN Series
Packaging Specifications – Paper Tape
Size
0201
0402
0603
0805
1206
1210
A
0.015
0.38
0.026
0.65
0.043
1.10
0.063
1.60
0.075
1.90
0.114
2.90
Size
B
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
P0
0201
0.027
0.68
0.045
1.15
0.075
1.90
0.094
2.40
0.138
3.50
0.138
3.50
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
P1
E
0.315 ± 0.004
8.00 ± 0.10
0.069 ± 0.002
1.75 ± 0.05
0.315 ± 0.008
8.00 ± 0.20
0.069 ± 0.004
1.75 ± 0.10
P2
D0
0.079 ± 0.004
2.00 ± 0.10
0.079 ± 0.002
2.00 ± 0.05
0402
W
0.157 ± 0.004
4.00 ± 0.10
0.157 ± 0.002
4.00 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
Unit
0.138 ± 0.002
3.50 ± 0.05
T
0.017
0.42
0.018
0.45
0.028
0.70
0603
0805
F
0.008
0.20
0.004
0.10
0.004
0.10
0.059 + 0.004/-0
1.50 + 0.10/-0
0.033 ± 0.004
0.85 ± 0.10
1206
1210
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Packaging Specifications – Embossed Plastic Tape
Size
2010
2512
1225
0815
0830
A
0.110
2.80
0.133
3.38
0.133
3.38
0.098
2.50
0.098
2.50
B
0.004
0.10
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.217
5.50
0.263
6.68
0.263
6.68
0.175
4.45
0.327
8.30
W
0.004
0.10
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.472 ± 0.012
12.00 ± 0.30
0.630 ± 0.012
16.00 ± 0.30
7
E
0.069 ± 0.004
1.75 ± 0.10
F
0.217
5.50
0.217
5.50
0.217
5.50
0.217
5.50
0.307
7.80
Unit
0.002
0.05
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CSR / CSRN Series
Packaging Specifications – Embossed Plastic Tape (cont.)
Size
P0
2010
0.157 ± 0.002
4.00 ± 0.05
2512
1225
0815
0830
0.157 ± 0.004
4.00 ± 0.10
P1
P2
0.157 ± 0.004
4.00 ± 0.10
0.079 ± 0.002
2.00 ± 0.05
0.157 ± 0.002
4.00 ± 0.05
T
Unit
0.059 + 0.004/-0
1.50 + 0.10, -0
D0
0.039 ± 0.008
1.00 ± 0.20
0.061 + 0.002/-0
1.55 + 0.05, -0
0.057 ± 0.008
1.45 ± 0.20
0.061 + 0.004/-0
1.55 + 0.10, -0
0.047 ± 0.008
1.20 ± 0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
High Power Chip Resistors and Thermal Management
Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power
ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these
resistors at the higher power ratings in their designs.
The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient
temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and
UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than
105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR1206 100 milliohms
at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes
would have less heat rise and therefore would be easier to implement for any given customer.
The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under
105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for
this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder
pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks,
among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit,
resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and
leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments
can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods
over another.
Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount
of solder used. This is especially notable for resistance values ≤ 50 mΩ. This should be taken into account when designing.
8
www.seielect.com
CSR / CSRN Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CSR
CSRN
Description
Lead-Free
Lead-Free
Effective Date
Mfg. Effective Date
Code
(Std Product Series)
(YY/WW)
Package /
Termination
Type
Standard Series
RoHS Compliant
Lead-Free Termination
Composition
SMD
YES
100% Matte Sn over Ni
May-04
04/18
SMD
YES
May-04
04/18
Surface Mount Chip Resistor
Surface Mount Chip Resistor, Narrow
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
C
S
R
1
2
F
T
1
L
H
P
Product Series
Code Description
CSR
Standard
Narrow
CSRN
Terminations
Size
Code W
0201 0.05
0402 0.13
0603 0.13
0805 0.25
1206 0.5
1210 0.5
2010 1
2512 2
0815 1
0830 2
1225 3
Tolerance
Code Tol
F
1%
G
2%
J
5%
Code Description
7" Reel
Paper Tape
T
7" Reel
Plastic Tape
7" Reel
Paper Tape
K
7" Reel
Plastic Tape
Packaging
Size
Quantity
0201, 0402
10000
0603, 0805, 1206, 1210
5000
2010, 2512
4000
0815, 0830, 1225
2000
0402
1000
2010, 2512
0815, 0830, 1225
9
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
"L" used as multiplier of
-3
10 for any value
under 0.1 ohm
Special (*)
Code Description
blank Standard
-HP High Power
(*) Only available
for 0603 and 1210
sizes
0.051 ohm = 51L0
0.35 ohm = R350
1 ohm = 1R00
www.seielect.com
