REVISION CH
PATENT NUMBERS
5713755 / 5961339
TMM-1XX-XX-XX-X-SM-XX-X
NO. OF POSITIONS PER ROW
-02 THRU -40
(NO. OF POSITIONS x .07874)+.000/-.010
[NO. OF POSITIONS x 2.000]+.00/-.25
DO NOT
SCALE FROM
THIS PRINT
{(NO. OF POS x .07874) - .07874}±.005
([NO. OF POS x [2.000] - [2.000])
01
OPTION
-P: PICK & PLACE PAD
(AVAILABLE ON POSITIONS
-03 THRU -40)(SEE SHEET 2, FIG 2)
*-M: METAL PICK & PLACE PAD
(SEE SHEET 2, FIG 2)(4 POS. MIN)
-A: ALIGNMENT PIN
(SEE SHEET 2, FIG 3)
(5 POS. PER ROW MINIMUM)
(NOT AVAILABLE ON SINGLE
BODY SPECIFICATION)
-TR: TAPE & REEL (AVAILABLE ON
POS -03 THRU 36, POS 37 THRU
-40 AVAILABLE TO EXISTING
CUSTOMERS ONLY)
(SEE SHEET 3) (SEE NOTE 11)
-FR: FULL REEL QTY. TAPE & REEL
(AVAILABLE ON POS -03 THRU 36,
POS 37 THRU -40 AVAILABLE TO
EXISTING CUSTOMERS ONLY)
(SEE NOTE 12)
TERMINAL SPEC
-01: USE T-1S13-07-X-2
-04: USE T-1S13-04-X-2
-05: USE T-1S13-21-X-2
-06: USE T-1S13-08-X-2
(SEE NOTE 8)
39
.078 1.981
REF
02
40
2 MAX SWAY
(EITHER DIRECTION)
02
80
PLATING SPECIFICATION
-G: 20µ" GOLD ON CONTACT AREA,
3µ" GOLD ON TAIL
-T: MATTE TIN ON CONTACT AND TAIL
-S: 30µ" SELECTIVE GOLD ON
CONTACT, MATTE TIN ON TAIL
-L: 10µ" SELECTIVE GOLD ON
-F: 3µ" SELECTIVE GOLD ON
-H: 30µ" GOLD ON CONTACT,
3µ" GOLD MIN ON TAIL
-SM: 30µ" SELECTIVE GOLD ON
-TM: MATTE TIN ON CONTACT AND TAIL
-LM: 10µ" SELECTIVE GOLD ON
-FM: 3µ" SELECTIVE GOLD ON
OPTION
POLARIZED SPECIFY POS-XX AS
POS TO BE OMITTED
OPTION
-SM: SURFACE MOUNT
BODY SPECIFICATION
-S: SINGLE (TMM-50-S)
-D: DOUBLE (TMM-50-D)
.155 3.937 REF
* FOR EXISTING CUSTOMERS ONLY
C
79
01
2 MAX SWAY
(EITHER DIRECTION)
2 MAX SWAY
(EITHER DIRECTION)
2 MAX SWAY
(EITHER DIRECTION)
.020 0.500
SQ. REF. (TYP)
POST AREA
(SEE NOTE 7 & 9)
C
C
FIG 1
1. C REPRESENTS A CRITICAL DIMENSION.
2. MAX. PIN ROTATION IN BODY: 2°
3. PUSHOUT FORCE SHALL BE 1 lb MIN.
4. ALL DIMENSIONS IN BRACKETS [ ] TO BE MILLIMETERS.
5. PACKAGE POSITIONS 03-40 IN TUBES; LAYER PACKAGE -02 POSITION.
6. .050 [1.27] DIMS TO BE CHECKED AT BEND RADIUS, NOT AT END OF PIN.
7. PINS TO BE INSERTED TAIL SIDE FIRST TO AVOID SCRATCHES ON CONTACT.
8. SHEAR TAILS FOR -05 & -06 LEAD STYLE.
9. NO BANDOLIER MARKS ARE ALLOWED IN THE POST AREA.
10. MAX. CUT FLASH: .010 [.25].
11. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING
TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
12. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED.
+4°
90° - 0°
C
C
+4°
C
SEE TABLE 3
SEE TABLE 3
NOTES:
2 MAX SWAY
(EITHER DIRECTION)
C
POST AREA
(SEE NOTE 7& 9)
90° - 0°
.059 1.499 REF
"C"
N/A
.106 [2.69]
.106 [2.69]
N/A
C
.07874±.005 2.000±0.127
C
+.005
+0.127
"A" - .002 "A" - 0.051
(SEE TABLE 2)
TABLE 2
"A" POST
"B" (OAL)
.126 [3.20]
.302 [7.67]
.075 [1.91]
.255 [6.48]
.065 [1.65]
.323 [8.20]
.168 [4.27]
.476 [12.09]
LEAD STYLE
-01
-04
-05
-06
.190 4.83 REF
C
+.000
.050 - .010
.278 7.06 MAX
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
.XX: .01
.XXX: .005
.XXXX: .0020
-S
(SEE NOTE 6)
-D
DECIMALS
0.000
1.270 - 0.254
ANGLES
2
PROPRIETARY NOTE
DO NOT SCALE DRAWING
F:\DWG\MISC\MKTG\TMM-1XX-XX-XX-X-SM-XX-X-MKT.SLDDRW
SHEET SCALE: 4:1
0.000
C
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
MATERIAL
BODIES:
LCP UL 94 VO, COLOR BLACK
TERMINALS:
PHOSPHER BRONZE
+.000
.050 - .010 1.267 - 0.254
(SEE NOTE 6)
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
2MM TERMINAL STRIP ASSEMBLY
DWG. NO.
BY: REIDINGER
05-22-1991 SHEET 1 OF 3
REVISION CH
"R"
LMP-04: .225 [5.72] REF
PPP-28: .315 [8.00] REF
PPP-11: .400 [10.2] REF
.200 5.080 REF
.197 5.004 REF
.144 3.658
REF
"S" ±.020
.210 5.33
REF
"R"= PAD SIZE ABOVE
"S" =((No OF POS x .07874)-"R")/2
PPP-11
DOUBLE
+.005
+0.127
(SEE TABLE 2)
"C" REF MIN GOLD
(SEE TABLE 2)
PPP-28
LMP-04
.072 1.829
REF
-M: PICK & PLACE PAD
DOUBLE ONLY
SINGLE
FIG 2
SM-A8H
.090 2.286
"B" REF
(SEE TABLE 2)
.0430 1.092
REF
2 MAX TOE
(EITHER DIRECTION)
PT-1-24-01-17
TMM-1XX-XX-X-X-SM-S
TMM-1XX-XX-X-X-SM-S-P
-D
IN-PROCESS 1
PT-TMMH001-DV-P
TMM-1XX-XX-X-X-SM-D
TUBE VIEW
-S
TABLE 1 (SEE NOTE 5)
PKG TUBE
PT-1-24-01-17
OPTION
-S, -S-P
(NO. OF POS.-2)
X .07874±.003
[2.000±.08]
A" ±.005 [.13]
SEE TABLE 2)
-D, -D-A, -D-M, -D- PT-TMMH001-DV-P
A-M, -D-P, D-A-P
PROPRIETARY NOTE
+.002
.118 - .008
(SEE NOTE 8)
-S
IN-PROCESS 2
-05 & -06 LEAD STYLE ONLY
FIG 3
-A: ALINGMENT PIN
SHEET SCALE: 4:1
PLUG
TP-24
TP-03
-D
PT-TMMH001-DV-P
TMM-1XX-XX-X-X-SM-D-M
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: REIDINGER 05-22-1991
SHEET 2 OF 3
REVISION CH
ROUND HOLES
"A"
"A"
OBLONG HOLES
USER DIRECTION OF UNREELING
TAPE AND REEL VIEW
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 3 OF 3
