SHF-105-01-L-D-TH
SHF-105-01-L-D-TH
    SAMTEC(申泰)
    插件,P=1.27mm
    特性:绝缘材料:黑色液晶聚合物。端子材料:磷青铜。镀层:在50 μin(1.27 μm)镍上镀锡或金。工作温度范围:-55°C至+125°C。无铅可焊:是。SMT引脚共面性:最大(0.10 mm) ....
SHF-105-01-L-D-TH 数据手册
REVISION V DO NOT SCALE FROM THIS PRINT NOTES: SHF-1XX-01-X-D-XX-XX 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 1 LB[4.45N]. 3. MAXIMUM ALLOWABLE BOW: .002[0.05] INCH/INCH AFTER ASSEMBLY. 4. POST HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13]. 5. FOR ALL PINS: NO BAND MARKS ALLOWED IN POST AREA. 6. MINIMUM RETENTION FOR LOCKING CLIPS: .75LB[3.336N] 7. MEASURE AT BEND. 8. MAXIMUM PIN ROTATION IN BODY TO BE 2 . 9. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 10. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. C (No OF POS x .050[1.27]) + .250[6.35] REF .0500 1.270 (TYP) CL .020 0.51 REF 02 No OF POSITIONS -02 THRU -25 LEAD STYLE -01: PLATING SPECIFICATION -L: 10µ" LIGHT SELECTIVE IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL C .037 0.94 REF .140 3.56 REF CL C .0500 1.270 01 03 .220 5.59 C REF (No OF POS x .050[1.27]) + .180[4.57] REF .056 1.42 REF (No OF POS - 1) x .0500[1.270] C .100 2.54 REF (ONLY FOR POSITION -05 THRU -25) OPTION -LC: LOCKING CLIP (NOT AVAILBLE WITH -RA) -K: POLYIMIDE FILM (-SM ONLY) (AVAILABLE IN TAPE & REEL ONLY) (USE K-DOT-.256-.375-.005) -TR: TAPE & REEL(SEE NOTE 10) -FR: FULL REEL QTY. TAPE & REEL (SEE NOTE 11) BODY HEIGHT -TH: THROUGH HOLE (SEE FIG 1, SHT. 1) -RA: RIGHT ANGLE (SEE FIG 2, SHT. 2) -SM: SURFACE MOUNT (SEE FIG 3, SHT. 3) ROW SPECIFICATION -D: DOUBLE DETAIL 'B' SCALE 8 : 1 2 MAX SWAY (EITHER DIRECTION) FIRST POSITION INDICATOR SHF-XX-D-LC .120 3.05 C C .210 5.33 REF LC-06-TM C .055 1.40 .020 0.51 REF .010 0.25 REF (TYP) 2 MAX SWAY (EITHER DIRECTION) CL 2 MAX SWAY (EITHER DIRECTION) SHF-XX-D-LC T-1S71-01-X .030 0.76 REF .016 0.41 SQ REF (TYP) C .165 4.19 FIG 1 (SHF-110-01-X-D-TH-LC SHOWN) F:\DWG\MISC\MKTG\SHF-1XX-01-X-D-XX-XX-MKT.SLDDRW DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 INSULATOR: SUMIKA E6810LHF, UL 94 VO, COLOR: BLACK TERMINAL: PHOS BRONZE (FOR -TH ONLY) 2 MAX SWAY (EITHER DIRECTION) (No OF POS - 1) x .0500[1.270] C MATERIAL: IN-PROCESS 1 'B' (No OF POS x .0500[1.270]) + .2120[5.385] C UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: .260 6.60 C REF .075 1.91 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SHROUDED TERMINAL STRIP DWG. NO. SHF-1XX-01-X-D-XX-XX BY: T NEWTON 1/10/2008 SHEET 1 OF 4 REVISION V .040 1.02 REF C .390 9.91 REF .285 7.24 .040 1.02 REF C .120 3.05 90° C .120 3.05 .040 1.02 C .122 3.09 SHF-XX-D-LC C .490 12.45 REF C C .385 9.78 T-1S71-02-X T-1S71-03-X IN-PROCESS 2 IN-PROCESS 1 (FOR -RA ONLY) (FOR -RA ONLY) IN-PROCESS 3 IN-PROCESS 4 (FOR -RA ONLY) (FOR -RA ONLY) C (No OF POS - 1) x .0500[1.270] 2 MAX SWAY (EITHER DIRECTION) "C" .120 3.05 .0500 1.27 C (TYP) .085 2.15 REF 90° C (TYP) .040 1.02 REF 02 90° C .050 1.26 C (SEE NOTE 7) C .120 3.05 .172 4.36 .050 1.27 C (SEE NOTE 7) 01 03 C SECTION "C"-"C" "C" IN-PROCESS 5 (VIEW ROTATED 90°) F:\DWG\MISC\MKTG\SHF-1XX-01-X-D-XX-XX-MKT.SLDDRW * FIG 2 (SHF-110-01-X-D-RA SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (FOR -RA ONLY) 2 MAX SWAY (EITHER DIRECTION) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SHROUDED TERMINAL STRIP DWG. NO. SHF-1XX-01-X-D-XX-XX BY: T NEWTON 1/10/2008 SHEET 2 OF 4 REVISION V SHF-XX-D-LC "D" T-1S71-01-X 02 .020 0.51 REF 01 .260 6.60 C REF "D" C .175 4.45 T-1S71-01-X-2 CL IN-PROCESS 1 +0° 90° - 5° (TYP) C C .120 3.05 (FOR -SM ONLY) .215 5.46 REF (SEE NOTE 7) C .004[0.10] .055 1.40 .240 6.10 REF (VIEW ROTATED 90°) 2 MAX SWAY (EITHER DIRECTION) C .0500 1.27 (TYP) .020 0.51 REF .190 4.83 REF .105 2.67 REF C (No OF POS - 1) x .0500[1.270] F:\DWG\MISC\MKTG\SHF-1XX-01-X-D-XX-XX-MKT.SLDDRW .240±.010 6.10±0.254 IN-PROCESS 2 (FOR -SM ONLY) FIG 3 (SHF-110-01-X-D-SM-LC SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SHROUDED TERMINAL STRIP DWG. NO. SHF-1XX-01-X-D-XX-XX BY: T NEWTON 1/10/2008 SHEET 3 OF 4 REVISION V C .256 6.50 REF .220 5.59 C (VIEW ROTATED 90°) "S" (SEE NOTE) .028±.020 0.71±0.51 "R" (SEE NOTE) FIG 4 NOTE: "R" = USED MEASURED DIMENSION (REF) "S" = {("R" -.256[6.50])/2} 0.020[0.51] (SHF-110-01-X-D-SM-K SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) PT-FTSH002-DV-A-P-M PT-1-24-18-09 PT-1-24-01-45 NOTE: ALL POSITIONS ARE TO BE TUBED PACKAGING ALL PARTS ARE LOADED WITH POSITION 1 TOWARD THE ARROW "EXCEPT -RA" * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 F:\DWG\MISC\MKTG\SHF-1XX-01-X-D-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SHROUDED TERMINAL STRIP DWG. NO. SHF-1XX-01-X-D-XX-XX BY: T NEWTON 1/10/2008 SHEET 4 OF 4
SHF-105-01-L-D-TH 价格&库存
很抱歉,暂时无法提供与“SHF-105-01-L-D-TH”相匹配的价格&库存,您可以联系我们找货
