IPT1-105-01-S-D
IPT1-105-01-S-D
    SAMTEC(申泰)
    插件
    特性:单独的屏蔽触点,提供电气和机械保护。间距为2.54mm和4.19mm。表面贴装或通孔安装。垂直和直角设计,适用于平行、垂直和共面应用。有锁定夹、键极化和导柱选项。采用16 30 AWG PVC或...
IPT1-105-01-S-D 数据手册
REVISION AA DO NOT SCALE FROM THIS PRINT IPT1-1XX-XX-XX-D-XX OPTION (SEE NOTE 11) -PL: POSITION #1 REMOVED (USE IPT1-XX-D-P) (SEE NOTE 12) -FL: FRICTION LOCK [POS -05 THRU -25] (USE IPT1-XX-D-FL-X & T-1S64-XX-X) (ONLY AVAILABLE ON -01 & -03 LEAD STYLES) No OF POS PER ROW -02 THRU -25 ((No OF POS x .1000 [2.540]) + .0200[0.508])±.010[0.25] .060 1.52 LEAD STYLE SEE TABLE 1, SHEET 2 02 CL .100 2.54 REF .200 5.08 REF ROW SPECIFICATION (SEE NOTE 11) -D: DOUBLE (USE IPT1-XX-D-XX-X) 01 PLATING SPECIFICATION SEE NOTE 8 "A" -S: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL -SM: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL -L: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL SEE TABLE 1 IPT1-50-D (SEE NOTE 11) .250 6.35 REF .155 3.94 REF .020 0.51 REF .085 2.16 C1 "A" .025 0.64 SQ REF (TYP) .100 2.54 FIG 1 SECTION "A"-"A" (IPT1-125-01-XX-D-XXX SHOWN) 02 T-1S64-06-X -FL: FRICTION LOCK OPTION (IPT1-110-01-X-D-FL SHOWN) NOTES: 20 01 19 IPT1-XX-D-P -PL: POLARIZED OPTION (IPT1-110-01-X-D-PL SHOWN) 2 MAX SWAY (TYP) 1. C REPRESENTS A CRITICAL DIMENSION. 2. MAXIMUM ALLOWABLE CUT FLASH: .010[0.25]. 3. MINIMUM TERMINAL PUSH OUT FORCE: 2 LBS 4. MAXIMUM VARIATION BETWEEN PIN ROWS: .005[0.13]. 5. "END WALLS" AFTER CUTTING SHOULD BE .010+/-.003[0.25+/-0.08]. 6. PARTS TO BE TUBE PACKAGED. 7. ALL DIMENSIONS TO BE ABOUT CENTERLINE WITHIN +/-.005[0.13]. 8. PRESENCE OF VOIDS IS OPTIONAL AND PATTERN TO WHICH THEY OCCUR IS VARIABLE. 9. -T PLATING OPTION AVAILABLE FOR EXISTING CUSTOMERS ONLY. 10. NOTE DELETED. 11. STANDARD BODIES CAN BE CUT TO POSITION. FOR -PL & -FL OPTIONS, BODIES MUST BE MOLDED TO POSITION. 12. FOR EXISTING CUSTOMERS ONLY, -POL CAN BE SUBSTITUED FOR -PL. 13. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOS BRONZE, 510, 3/4 HARD c:\enterprisevault\DWG\MISC\MKTG\IPT1-1XX-XX-XX-D-XX-MKT.SLDDRW SHEET SCALE: 1:0.4 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 DOUBLE ROW SHROUDED TERMINAL ASSEMBLY DWG. NO. IPT1-1XX-XX-XX-D-XX BY: DEAN P 11-05-2002 SHEET 1 OF 2 REVISION AA PT-1-24-03-47 "B" IPT1-XX-D-XX-X .155 3.94 REF "B" (SEE TABLE 1) HTSW-50-D-LCP SEE TABLE1 "B" [ ] ((No OF POS x .100 [2.54])+-.005 .010 0.13 0.25 "C" C (SEE TABLE 1) SECTION "B"-"B" PT-1-24-02-105 PT-1-24-08-15 PT-1-24-01-103 FIG 2 (IPT1-110-02-XX-D-XXX SHOWN) -08 -01 -02 PT-1-24-07-51 PT-1-24-01-152 "D" -06 "D" PT-1-24-02-47 LEAD STYLE -02 TO -09 LEAD STYLE -01 IN-PROCESS -03, -04, -05 FIG 3 TUBE VIEWS -07 * PROPRIETARY NOTE -09 * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 c:\enterprisevault\DWG\MISC\MKTG\IPT1-1XX-XX-XX-D-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 DOUBLE ROW SHROUDED TERMINAL ASSEMBLY DWG. NO. IPT1-1XX-XX-XX-D-XX BY: DEAN P 11-05-2002 SHEET 2 OF 2
