IPL1-115-01-L-S-K
IPL1-115-01-L-S-K
    SAMTEC(申泰)
    插件
IPL1-115-01-L-S-K 数据手册
IPL1-1XX-XX-XXX-S-XX-X-XX REVISION W (No OF POS x .100[2.54]) +.060[1.52] REF .080 2.03 REF (No OF POS -1) x .100[2.54] REF 01 LEAD STYLE -01: THROUGH HOLE (USE T-1S64-XX-XX) -02: SURFACE MOUNT (SEE FIG. 2, SHT 2) (USE T-1S64-XX-XX) 02 .240 6.10 REF CL .010 0.25 REF TERMINAL OFFSET FOR POLARIZATION .040 1.02 REF ROW SPECIFICATION PLATING SPECIFICATION -S: SINGLE (USE IPL1-XX-S) -F: FLASH SELECTIVE (USE T-1S64-XX-F) -L: LIGHT SELECTIVE (USE T-1S64-XX-L) -S: SELECTIVE (USE T-1S64-XX-S) -H: HEAVY GOLD (USE T-1S64-XX-H) -FM: FLASH SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-F) -LM: LIGHT SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-L) -SM: SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-S) -STL: LIGHT SELECTIVE TIN/LEAD (USE T-1S64-XX-STL) CL .100 2.54 REF DO NOT SCALE FROM THIS PRINT PACKAGING BLANK: TUBES (SEE NOTE 12) -TR: TAPE & REEL (SEE NOTES 12 & 13) (AVAILABLE WITH -02 LEAD STYLE ONLY) (MUST USE K-DOT-.177-.281-.005) (SEE FIG 5, SHT 3) -FR: FULL REEL QTY. TAPE & REEL (SEE NOTES 12 & 13) (AVAILABLE WITH -02 LEAD STYLE ONLY) (MUST USE K-DOT-.177-.281-.005) POLARIZATION OPTION -K: KEYED POLARIZATION (USE IPL1-XX-S-K) (SEE FIG 4, SHEET 3) (LEAVE BLANK FOR NO POLARIZATION, SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS AS OF REV J) OPTION -RA: RIGHT ANGLE (SEE FIG 3, SHT 3) (AVAILABLE WITH -01 LEAD STYLE ONLY) No OF POSITIONS -02 THRU -25 IPL1-XX-S SEE NOTE 7 C SEE NOTE 4 "A" .300 7.62 REF .215 5.46 REF .320 8.13 REF .120 3.05 REF T-1S64-07-XXX C 2° MAX SWAY (EITHER DIRECTION) C C "A" .025 0.64 SQ REF 2° MAX SWAY (EITHER DIRECTION) SECTION "A"-"A" .100 2.54 C ((No OF POS - 1) x .100[2.54])±.008[0.20] NOTES: 1. REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM TERMINAL RETENTION: 1 LB [4.45 N]. 3. PARTS TO BE MOLDED TO POSITION. 4. POST MUST BE WITHIN .005[0.13] OF EACH OTHER. 5. ALL PIN TO PIN DIMENSIONS TO BE MEASURED FROM TIP TO TIP. 6. DIMENSION TO BE MEASURED AT BEND. 7. TIP TO BE FLUSH TO .015[0.38] BELOW TOP OF SHROUD. 8. NOTE DELETED. 9. PACKAGE ALL POSITIONS. 10. NOTE DELETED. 11. NOTE DELETED. 12. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM 13. ATTACH LABEL-4X2 TO EACH REEL. FIG 1 IPL1-106-01-XXX-S SHOWN CPC THIS SHEET UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] .XXX: .005[0.13] .XXXX: .0020[0.051] C1, C2, C3, C4, C5 MATERIAL: 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 STANDARD INSULATOR: LCP UL94-V0, COLOR: BLACK -K INSULATOR: LCP UL94-V0, COLOR: NATURAL TERMINAL: PHOS BRONZE F:\DWG\MISC\MKTG\IPL1-1XX-XX-XXX-S-XX-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] SINGLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-XX-XXX-S-XX-X-XX BY: D PURVIS 05/02/2005 SHEET 1 OF 3 REVISION W 01 C (SEE NOTE 7) 02 .106 2.69 C .119 3.02 REF +0° 90° - 4° .215 5.46 .231 5.87 REF .345 8.76 SEE TABLE 2 T-1S64-08-XXX .028 0.72 REF T-1S64-08-XXX -02: SURFACE MOUNT IN-PROCESS 1 .277 7.04 REF FIG 2 STYLE -02: SURFACE MOUNT IPL1-106-02-XXX-S SHOWN [DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1] PT-1-24-01-123 PT-1-24-04-40 PT-1-24-01-127 C +0° 90° - 4° .125 3.18 .277±.010 7.04±0.25 -02: SURFACE MOUNT IN-PROCESS 2 F:\DWG\MISC\MKTG\IPL1-1XX-XX-XXX-S-XX-X-XX-MKT.SLDDRW CPC THIS SHEET PACKAGING VIEWS (PARTS TO HAVE POSITION #1 LOADED IN SAME DIRECTION AS ARROW ON TUBE) C6, C7, C10 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] SINGLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-XX-XXX-S-XX-X-XX BY: D PURVIS 05/02/2005 SHEET 2 OF 3 REVISION W .110 2.79 C .040 1.02 REF 90° C .115 2.92 REF .655 16.64 REF .545 13.84 REF .160 4.06 IPL1-06-S-K .085 2.16 REF T-1S64-19-XXX 01 FIG 4 -RA: IN-PROCESS 2 -RA: IN-PROCESS 1 -K: KEYED POLARIZATION (IPL1-106-01-XXX-S-K SHOWN) (SAME AS FIG 1 UNLESS OTHERWISE STATED) 02 .240 6.10 REF T-1S64-19-XXX ((NO OF POS x .100[2.54] - .117 [2.97]) / 2) .020 [0.51] (SEE NOTE 7) C "B" .031±.020 0.80±0.51 .215 5.46 REF .350 8.89 .177 4.50 REF .060 1.52 (SEE NOTE 6) "B" FIG 5 .085 2.16 REF (IPL1-106-02-XXX-S-TR SHOWN) (MUST USE K-DOT-.177-.281-.005) (SAME AS FIG 2,"B"-"B" UNLESS OTHERWISE STATED) SECTION FIG 3 -RA: RIGHT ANGLE IPL1-106-01-XXX-S-RA SHOWN [DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1] CPC THIS SHEET C8, C9, C11 * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\IPL1-1XX-XX-XXX-S-XX-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] SINGLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-XX-XXX-S-XX-X-XX BY: D PURVIS 05/02/2005 SHEET 3 OF 3
IPL1-115-01-L-S-K 价格&库存
很抱歉,暂时无法提供与“IPL1-115-01-L-S-K”相匹配的价格&库存,您可以联系我们找货
IPL1-115-01-L-S-K
    • 1+28.524621+3.68197
    IPL1-115-01-L-S-K
      • 14+29.32068
      • 28+25.54829
      • 56+23.14218
      • 112+20.14361
      • 504+17.39896
      库存:894
