RUGGED TIGER EYE™ SYSTEMS
(1.27 mm) .050" PITCH
MAX
3.2
A
m
p
s
8
G b p s
FEATURES & BENEFITS
• S
crew down, locking clip, friction latching and
weld tab ruggedizing options
• Shrouded, polarized and keyed
• Surface mount or through-hole tails
• High-density, four row design (FOLC/MOLC Series)
• Discrete wire assemblies available in single or double row, 28
and 30 AWG PVC or Teflon® wire; contact asp@samtec.com
for custom solutions
• Cable components (ISDF/CC03) and tooling available
IDC cable
assemblies with
rugged strain relief
(FFSD/FFMD, FFTP/FMTP)
Dupont™ Teflon® is a registered trademark of the
E.I. du Pont de Nemours and Company or its affiliates.
KEY SPECIFICATIONS (TFM/SFM)
PITCH
STACK
HEIGHTS
INSULATOR
MATERIAL
CONTACT
MATERIAL
BeCu (SFM)
1.27 mm
F-221
6 to 12 mm
Black LCP
Phosphor Bronze
(TFM)
PLATING
Au or Sn over 50 µ"
(1.27 µm) Ni
OPERATING
TEMP RANGE
-55 °C to +125 °C
CURRENT
RATING
3.2 A per pin
(2 pins powered)
Locking for
increased
unmating force
(SFML/TFML)
VOLTAGE
RATING
250 VAC
MAX
CYCLES
10,000
with 30 µ"
(0.76 µm) Au
(Call Samtec for
E.L.P.™ plating
option)
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MAX
3.2
A
(1.27 mm) .050" • SMT/THROUGH-HOLE HEADER
SERIES
-1
TFM
NO. PINS
PER ROW
03, 04,
06, 08
= Standard
(TFM –01 &
–02 only)
TFML
= Locking
(–01 & –02
lead style
only)
05, 07,
10, 15, 20,
25, 30, 35,
40, 45, 50
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
–L
= 15 µ"
(0.38 µm)
Gold on post,
Matte Tin on tail
(Call Samtec
for E.L.P.™
plating option)
(Standard sizes)
p
s
8 25
G b p s
ROW
OPTION
OPTIONS
–S
Specify only –RA,
–RE1 or –RE2
–D
= Right-angle
(Lead style
–01 only)
= Single Row
(TFM only)
= Double Row
–DH*
= Double
Horizontal
(TFM lead
style –02 only)
(05 thru 50
positions only)
(–TR or –FR
option only
available)
–RA
–RE1
= Right-angle
Elevated for
(1.60 mm) .062" PCB
(Requires TFM
lead style –01,
–D row and –WT)
SMT lead styles only
Specify only –A,
Specify only –K or –P
–LC, –DS or –WT
Not available with –RA,
–RE1 and –RE2 unless
–K
otherwise noted.
= Polyimide Film
Pick & Place Pad
–A
= Alignment Pin
–LC
= Locking Clip
(Manual Placement
required)
–P
= Plastic Pick
& Place Pad
(5 positions min.)
(Not available with
5 position with –WT)
Specify –TR or -FR last
–DS
(Not available with –DS)
= Dual
–RE2
Screw Down
= Right-angle
–TR
for (1.60 mm)
Elevated for
= Tape & Reel
.062" PCB
(2.36 mm) .093" PCB (05, 07, 10, 15, 20,
(Requires TFM lead
25, 30, 35, 40
–FR
style –01, –D row
positions only)
= Full Reel
and –WT)
(TFM lead styles
Tape & Reel
–01 and –02 only)
(must order max.
(Requires –D
quantity per reel;
row option)
contact Samtec for
MATED HEIGHTS*
(Mates with
quantity breaks)
SFM–DS
option
and
LEAD STYLE (SMT)
SFSD/SFSDT
–SS
and
MATED HEIGHT*
–DS option only)
TFM
SFM
(Not available with –A,
–LC, –WT, –K, –P, –XR)
-02
(6.35) .250
TFM
Board Mates:
SFM, SFMC
Cable Mates:
SFSD
TFML
Board Mates:
SFML
–12
(1.27) .050 x
No. of Positions + (3.18) .125
(8.13) .320
-02
-22
(9.91) .390
-32
(11.81) .465
LEAD STYLE (T/H)
MATED HEIGHT*
TFM
SFM
-01
(5.97) .235
–03
(5.97) .235
-11
(7.75) .305
-13
(7.75) .305
-01
-21
(9.53) .375
-23
(9.53) .375
-31
(11.43) .450
*Processing conditions will affect mated height.
(4.45)
.175
SINGLE ROW
(1.27) .050 x
(See website for –REX,
–DH, –DS, –WT OAL)
(5.72)
.225
LEAD STYLE (SMT)
B
A
C
THROUGH-HOLE
–A
Note:
Some lengths, styles and options
are non-standard, non-returnable.
A
–02
(5.72) .225
–12*
(7.49) .295
–22*
(9.27) .365
–32*
(11.18) .440
* N/A with 07, -DH or -S row option
DOUBLE ROW
–LC
m
LEAD STYLE
(T/H)
–WT
= Weld Tab
(TFM lead styles
–01 and –02 only)
(Required callout
for –RE1 & –RE2)
(Mates to SFSS/SFSD
–SR and –DR
option only)
25, 30, 35, 40, 45, 50
positions only)
B
C
–01
(5.59) .220 (1.97) .078
–03*
(5.59) .220 (2.77) .109
–11*
(7.37) .290 (1.97) .078
–13*
(7.37) .290 (2.77) .109
–21*
(9.14) .360 (1.97) .078
–23*
(9.14) .360 (2.77) .109
–31*
(11.05) .435 (1.97) .078
* Not Available with 07 or -S row option
SURFACE MOUNT
–WT
–DS
–DH*
–RA
–RE1 & –RE2
View complete specifications at: samtec.com?TFM & samtec.com?TFML
F-221
