EHT-112-01-S-D
EHT-112-01-S-D
    SAMTEC(申泰)
    插件
EHT-112-01-S-D 数据手册
REVISION BM EHT-1XX-01-XX-D-XX-XX-X-XX-XX No OF POSITIONS -05 THRU -25 DO NOT SCALE FROM THIS PRINT OPTION 2 -LC: LOCKING CLIP(SEE NOTE 4) ( FOR -SM ONLY) (SEE FIG 4, SHT 2, USE LC-09-TM) LEAD STYLE -01 .311 7.90 REF .100 2.54 REF .300 7.62 REF .1775 4.509 REF 02 CL .0787 2.000 "A" "A" 01 .020 0.51 REF OPTION 3 -TR: TAPE AND REEL PACKAGING (FOR -SM, -SM-P, AND -SM-K ONLY) PLATING SPECIFICATION -S: 30µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -F: 3µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -T: MATTE TIN. -H: 30µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL. -L: 10µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -SM: 30µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -FM: 3µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -TM: MATTE TIN. -LM: 10µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL. OPTION 1 -P: PICK & PLACE PAD (SEE FIG 5, SHT 2) (FOR -SM ONLY, USE PPP-24) (USE PPP-55 WITH -SM-TR OPTION) -K: OPTION (POLYIMIDE FILM, SEE FIG 3, SHT 2) (FOR -SM ONLY) POLARIZED OPTION -XX = PIN OMITTED TAIL OPTION -RA: RIGHT ANGLE (FIG 2, SHT 2) -SM: SURFACE MOUNT (SEE FIG 4, SHT 2) (LEAVE BLANK FOR THRU HOLE) ROW SPECIFICATION -D: DOUBLE C No OF POS x .0787[2.000] + .543[13.79] REF No OF POS x .0787[2.000] + .177[4.50] REF (No OF POS x .0787[2.000]) - .0787[2.000] ±.005[0.13] POLARIZATION WINDOW .020 0.50 SQ REF (TYP) POS 1 INDICATOR EHH-XX-D .120 3.04 .370 9.40 REF REF .114 2.90 T-1S13-05-XXX-2 (SEE TABLE 2) 2 MAX SWAY (EITHER DIRECTION) FIG1 NOTES: 1. 2. 3. 4. 2 MAX SWAY (EITHER DIRECTION) SECTION "A"-"A" (EHT-105-01-XX-D SHOWN) (LATCH EHA-01 REMOVED FOR CLARITY) C REPRESENTS A CRITICAL DIMENSION. MINIMUM PUSHOUT FORCE: 1 LB. MAXIMUM PIN ROTATION IN BODY: 2° DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION. F:\DWG\MISC\MKTG\EHT-1XX-01-XX-D-XX-XX-X-XX-XX-MKT.SLDDRW C UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 VO, COLOR: BLACK TERMINAL: PHOS BRONZE SHEET SCALE: 2.5:1 DESCRIPTION: 2MM EJECTOR HEADER ASSEMBLY DWG. NO. EHT-1XX-01-XX-D-XX-XX-X-XX-XX BY: PURVIS 02/28/1994 SHEET 1 OF 3 REVISION BM .295 7.501 REF "S" (SEE NOTE) .018±.020 0.45±0.508 .120 3.05 REF POLARIZATION WINDOW "R" (SEE NOTE) 90° NOTE: "R" = USE MEASURED DIMENSION (REF) "S" = {("R" -.2953[7.50]/2) ±.020[0.51]} .272 6.92 .431 10.96 FIG 3 C .060±.010 1.52±0.254 T-1S13-06-XX-2 (EHT-105-01-XX-D-SM-K SHOWN) -K OPTION (K-DOT-.295-.406-.005) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) T-1S13-15-XX-2 -RA IN PROCESS FIG 2 C .0787±.0050 2.000±0.127 NOTE: "R" = USE MEASURED DIMENSION (REF) "S" = {("R" -.325[8.26]/2) ±.020[0.51]} (EHT-1XX-01-XX-D-RA SHOWN) RIGHT ANGLE (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) .325 8.26 REF .237 6.03 REF 90° .079 2.01 .190±.0025 4.84±0.064 .350+-.020 .010 C T-1S13-05-XX-2 "R" (SEE NOTE) "S" (SEE NOTE) 8.90+-0.508 0.254 PPP-24 -SM IN-PROCESS 2 -SM IN-PROCESS 1 .338 8.59 PIN TO BE FLUSH OR BELOW LINE FORMED BY BODY 90° FIG 5 (LATCH EHA-01 REMOVED FOR CLARITY) (EHT-105-01-XX-D-SM-P SHOWN) PICK AND PLACE PAD (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) .375 9.52 C C * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS .004[0.10] AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE .060 1.52 +.020 .350 - .010 LC-09-TM (No OF POS x .079[2.00] + .272[6.91]) REF +0.508 8.89 - 0.254 C FIG 4 (EHT-105-01-XX-D-SM-LC SHOWN) SURFACE MOUNT VERSION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.571429 F:\DWG\MISC\MKTG\EHT-1XX-01-XX-D-XX-XX-X-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR DESCRIPTION: 2MM EJECTOR HEADER ASSEMBLY DWG. NO. EHT-1XX-01-XX-D-XX-XX-X-XX-XX BY: PURVIS 02/28/1994 SHEET 2 OF 3 REVISION BM NO OF POS X .0787[2.000] + .783[19.89] REF .380 9.65 REF .484 12.28 REF .526 13.36 .097 2.45 REF LATCH OPEN VIEW IN-PROCESS ARM ASSEMBLY & ROTATION FIG 6 APPLICATION VIEW EHT MATED TO TCSD AND EC2 POSITION 1 PPP-55 PT-1-24-16-29 "B" SM W/ LC PT-1-24-01-58 "B" C POLARIZATION NOTCH USER DIRECTION OF UN-REELING POCKET NOT DETAILED SM W/O LC PT-1-24-01-08 SECTION "B"-"B" SCALE 1 : 1 * ASP-90341-01-S FIG 7 PACKAGING VIEWS PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\EHT-1XX-01-XX-D-XX-XX-X-XX-XX-MKT.SLDDRW DESCRIPTION: 2MM EJECTOR HEADER ASSEMBLY DWG. NO. EHT-1XX-01-XX-D-XX-XX-X-XX-XX BY: PURVIS 02/28/1994 SHEET 3 OF 3
EHT-112-01-S-D 价格&库存
很抱歉,暂时无法提供与“EHT-112-01-S-D”相匹配的价格&库存,您可以联系我们找货
EHT-112-01-S-D
  • 14+79.47416
  • 28+75.18186
  • 56+68.32626
  • 112+57.61363
库存:374
EHT-112-01-S-D
    • 1+59.31360
    • 10+58.09320
    • 28+57.28320
    • 98+56.47320
