8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2796
INITIAL RELEASE
7/1/2013
JH
F
F
CONTACT IDs:
(LETTERS G, I, O & Q NOT USED)
SIZE 06 THRU 50, EXCEPT 35 & 36
1 2 ... 23 24 ... 45 46 ...
A B ... a b ... AA BB ...
E
D
E
E
B
A
2X
DETAIL CONTACT
SCALE 4 : 1
.075 1.91
SEE NOTE 13
.125 3.18 TYP
D
.125 3.18
F
C
A
D
.030 0.76
.025 0.64
.431 10.95
.265 6.73
INSERTION DEPTH
.110 2.79
CONTACT POINT
.245 6.22
.063 1.60 X.007[0.18]
C
B
A
A
SECTION A-A
MP_ _ - _ 125 - _ _ - DSE - 1_ _ _
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
16. MODIFICATION: CARD EXTENDER BEND FOR LOW PROFILE CONNECTOR,
.055" INSIDE DIMENSION FOR .062" PCB
8
7
6
.225±.025 5.71±0.64
TAIL LENGTH
ACCEPTS .062 PCB
5
C
B
REFERENCE: _ _ A_ _DRV_-P13, P39, P71
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
6/24/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
MP_ _-125-_ _-DSE-_ _ _ _
CAGE CODE
54453
SCALE: 2:1
3
A
CARD EDGE, .125 CC LP
2
DWG. NO.
C12239
SHEET 1 OF 3
1
REV
A
FILE NAME: C12239, MP_ _-_125-_ _-DSE-_ _ _ _, REF _ _A_ _DRV_-P13, P39, P71
8
7
4
5
6
F
2X FLOATING ROBBIN
.116[2.95] CLEARANCE
FOR #4 SCREW
2X #4-40
THREADED
INSERT
F
1
2
3
E
E
MP_ _ - _ 125 - _ _ - DSE - 3_ _ _
MP_ _ - _ 125 - _ _ - DSE - 2_ _ _
D
D
C
2X
C
D
.125 3.18
C
2X .135 3.43
MP_ _ - _ 125 - _ _ - DSE - 8_ _ _
MP_ _ - _ 125 - _ _ - DSE - 4_ _ _
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
6/24/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C12239
SHEET 2 OF 3
1
REV
A
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
6/24/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C12239
SHEET 3 OF 3
1
REV
A
MPSL-0125-31-DSE-4K 价格&库存
很抱歉,暂时无法提供与“MPSL-0125-31-DSE-4K”相匹配的价格&库存,您可以联系我们找货
