HVC Series
Stackpole Electronics, Inc.
High Voltage Thick Film Chip Resistor
Resistive Product Solutions
Features:
Ohmic values to 50G
Available with wire bondable terminations
Tight tolerances to 0.1%
Utilizes fine film resistor deposition technology
Superior pulse handling capabilities
Low TCR to 25 ppm/ºC
Low VCR to 1 ppm/volt
Very low noise
Ultra-high stability
Custom sizes available
Higher (up to 1TΩ) or lower resistance values may be available (contact Stackpole)
Standard HVC parts are unmarked
RoHS compliant and halogen free
REACH compliant
Electrical Specifications
Type /
Code
Power
Rating
(W)
@ 70ºC
Maximum
Working
Voltage (V)
Ohmic Range (Ω) and Tolerance
TCR
(ppm/ºC)
(1)
0.1%
0.25%
0.5%
1%
2%
5%
10%
20%
±50
10K - 100M
10K - 500M
HVC0603
0.06
400
±100
10K - 10M
10K - 1G
10K - 500M
10K - 1G
±200
10K - 10G 10K - 50G
±50
10K - 500M
HVC0805
0.2
600
±100
10K - 10M
10K - 1G
10K - 1G
±200
10K - 10G
10K - 50G
±25
1M - 100M
1M - 100M
±50
100K - 100M 100K - 100M
100K - 500M
HVC1206
0.33
1500
±100
10K - 1G
10K - 100M
10K - 100M 10K - 500M
10K - 1G
±200
10K - 10G
10K - 50G
±25
1M - 100M
1M - 100M
±50
100K - 500M
HVC2010
1
2000
±100
10K - 1G
10K - 100M
10K - 1G
±200
10K - 10G
10K - 50G
±25
1M - 100M
1M - 500M
±50
100K - 100M 100K - 500M
100K - 1G
HVC2512
2
3000
±100
100K - 10G
10K - 100M
10K - 500M
10K - 1G
10K - 10G
±200
100K - 50G
±25
1M - 100M
1M - 500M
±50
100K - 1G
HVC3512
3
3500
±100
100K - 10G
10K - 100M
10K - 500M
10K - 1G
10K - 10G
±200
100K - 50G
Proper terminal isolation is required to achieve the voltage ratings for each given size.
(1) The continuous maximum voltage applied cannot exceed the maximum power rating and is ohmic value dependent.
Note: Other case sizes and tolerances are available.
Mechanical Specifications
Type / Code
HVC0603
HVC0805
HVC1206
L
Body Length
0.063 ± 0.01
1.60 ± 0.25
0.079 ± 0.01
2.01 ± 0.25
0.126 ± 0.01
3.20 ± 0.25
W
Body Width
0.031 ± 0.005
0.79 ± 0.13
0.050 ± 0.005
1.27 ± 0.13
0.063 ± 0.005
1.60 ± 0.13
Rev Date: 11/18/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
H
Body Height (Max.)
0.020
0.51
0.025
0.64
0.030
0.76
1
a
Top Termination
0.010 ± 0.005
0.25 ± 0.13
0.010 ± 0.005
0.25 ± 0.13
0.010 ± 0.005
0.25 ± 0.13
b
Bottom Termination
0.012 ± 0.008
0.30 ± 0.20
0.013 ± 0.008
0.33 ± 0.20
0.020 ± 0.010
0.51 ± 0.25
Unit
inches
mm
inches
mm
inches
mm
www.seielect.com
marketing@seielect.com
HVC Series
Mechanical Specifications (cont.)
L
Body Length
0.200 ± 0.01
5.08 ± 0.25
0.250 ± 0.01
6.35 ± 0.25
0.350 ± 0.01
8.89 ± 0.25
Type / Code
HVC2010
HVC2512
HVC3512
W
Body Width
0.100 ± 0.005
2.54 ± 0.13
0.125 ± 0.005
3.18 ± 0.13
0.125 ± 0.005
3.18 ± 0.13
H
Body Height (Max.)
0.030
0.76
0.030
0.76
0.030
0.76
a
Top Termination
0.018 ± 0.010
0.46 ± 0.25
0.020 ± 0.010
0.51 ± 0.25
0.020 ± 0.010
0.51 ± 0.25
b
Bottom Termination
0.020 ± 0.010
0.51 ± 0.25
0.024 ± 0.010
0.61 ± 0.25
0.024 ± 0.010
0.61 ± 0.25
Unit
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Typical Performance
Short Time Overload
Load Life
Temperature Cycle
Moisture Resistance
Shock
Vibration
Dielectric Withstanding Voltage
Resistance to Soldering Heat
Parameter
0.1%
0.1%
0.1%
0.1%
0.05%
0.05%
0.05%
0.05%
Typical
TCR
measured from 25°C to 75°C
10X rated wattage
Consult Stackpole for custom pulse applications
Measured at 100V
Consult Stackpole for custom test voltages
Pulse Capability
Resistance Value
Operating temperature range is -55ºC to +150ºC
Power Derating Curve:
Recommended Pad Layouts
Type / Code
HVC0603
HVC0805
A
0.031
0.80
0.047
1.20
B
0.083
2.10
0.118
3.00
2
C
0.035
0.90
0.051
1.30
Unit
inches
mm
inches
mm
www.seielect.com
HVC Series
Recommended Pad Layouts (cont.)
Type / Code
HVC1206
HVC2010
HVC2512
A
B
C
Unit
0.087
2.20
0.138
3.50
0.150
3.80
0.165
4.20
0.240
6.10
0.315
8.00
0.063
1.60
0.110
2.80
0.138
3.50
inches
mm
inches
mm
inches
mm
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
3
www.seielect.com
HVC Series
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
SMD
Surface Mount Chip Resistor
Note (1): RoHS Compliant by means of exemption 7c-I.
HVC
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
YES(1)
100% Matte Sn ("T")
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
4
www.seielect.com
HVC Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
Code
HVCB
HVCG
HVCS
HVCZ
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
H
V
C
B
2
5
1
2
F
K
C
1
M
Product Series
Description
Solderable wraparound
(100% matte tin)
Wire bondable (gold)
Solderable single surface
(Sn/Pb)
(100% matte tin)
Size
Code
W
0603 0.06
0805
0.2
1206 0.33
2010
1
2512
2
3512
3
Tolerance
Code Tol
B
0.1%
C 0.25%
D
0.5%
F
1%
G
2%
J
5%
K
10%
M
20%
Packaging
Code
7" Reel - Paper Tape
T
7" Reel - Plastic Tape
K
D
B
Description
Bulk
5
TCR
Size
Quantity Code ppm
0603, 0805
5000
E
25
1206
4000
C
50
2010
4000
D
100
2512
2000
L
200
0603, 0805, 1206 1000
M 300
2010, 2512, 3512 1000
0603, 0805, 1206
500
2010, 2512, 3512
500
All Sizes
1000
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
10 Kohm = 10K0
1 Mohm = 1M00
10 Gohm = 10G0
www.seielect.com
很抱歉,暂时无法提供与“HVCB2010FKC100M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+32.89577
- 10+26.31312
- 25+22.93000
- 100+21.25156
- 250+21.12043
- 国内价格 香港价格
- 1+52.711021+6.39887
- 10+33.5734510+4.07566
- 50+25.8680250+3.14026
- 100+23.52984100+2.85641
- 500+19.40154500+2.35526
- 国内价格 香港价格
- 1000+18.025531000+2.18822
- 3000+17.199933000+2.08799
