1.27mm Pitch Two-Piece Connectors
HIF6 Series
Connector in combination with the HIF6 series connection type
●HIF3B Series
(MIL-C-83503)
●HIF2 Series
(Board direct mount type)
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1
●HIF5 Series
(Card edge type)
2
●FD Series
(D sub-ribbon connector)
■Features
1. Product Variation
The connection method is available with the board to
board type and insulation displacement type.
Fig.1 (For further information, refer to catalog page B86.)
2. Broad applications
HIF2E, HIF3B and HIF5 can be combined one other,
because the 1.27mm pitch flat cable is used. (Fig.1)
3. Applicable Cables
The applicable cable is a (UL2651) 28 AWG flat cable
(7cores: 0.127mm, outer jacket diameter: 0.8 to1.0mm)
4. Mis-insertion Preventive Structure
The mis-insertion preventive guide prevents misinsertion.
■Product Specifications
Rating
Current rating : 0.5A
Operating Temperature Range : -55 to +85 ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2)
Voltage rating : 125V AC Operating Humidity Range : 40 to 80%
Item
Operating Humidity Range : 40 to 70%
Specification
(Note 2)
Condition
1.Insulation Resistance 1000MΩ min.
250V DC
2.Withstanding Voltage No flashover or insulation breakdown.
300V AC/1 minute.
3.Contact Resistance
30mΩ max.
0.1A
4.Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5.Humidity (Steady state) Insulation resistance : 1000MΩ min.
96 hours at temperature of 40ç and humidity of 90% to 95%
6.Temperature Cycle
(-65ç : 30 minutes→15 to 35ç : 5 minutes max.→
125ç : 30 minutes→15 to 35ç : 5 minutes max.) 5 cycles
No damage, cracks, or parts looseness.
7.Durability (Mating/un-mating) Contact resistance : 30mΩ max.
8.Resistance to Soldering heat No deformation of components affecting performance.
500 cycles
Solder bath : 260ç for 10 seconds
Manual soldering : 360ç for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3 : Please note that there is a risk of deforming the lock when an excessive load is applied to the inside.
B69
HIF6 Series●1.27mm Pitch Two-Piece Connectors
■Materials / Finish
Parts
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Socket Contact
Copper alloy
Pin header Contact
Brass
Selective gold plating
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Socket and Receptacle
HIF6 A – * D A – 1.27 DSA L
q
w
e
r
t
y
u
i
q Series Name : HIF6
w Blank
: Ribbon cable insulation displacement type
A
: Without board mounting hole
B
: With board mounting hole
e Number of contacts : 20, 26, 32, 34, 40, 50, 52, 60, 68, 80, 100
r
D
: Socket or receptacle
t
A
: Selective gold plated
y Contact pitch : 1.27mm
u Contact type : DS
: Right angle type
DSA : Straight type
R
: Ribbon cable ID type
i L : Board pre-fixed lock pin
●Pin Header
HIF6 A – * P A – 1.27 DSA L
q
w
r
e
t
y
u
i
w Blank
: With lock
A
B
r
P
: Pin header
t
A
u Contact style : DS
DSA
: Right angle type
: Straight type
B70
BFunction Chart
Pin Header
Socket or Receptacle Side
Right Angle
Type with lock
Two pieces of 1.27mm
pitch cable used
a2.54 pitch connector
(MIL-C-83503)
Straight Type
with lock
HIF2B series
HIF3B series
HIF5 series
Ribbon cable FD
(D sub) connector
Right Angle
Type with
Right Angle
mounting hole
Type with
mounting hole
Straight Type
with mounting
hole
Straight Type
with mounting
hole
Right Angle
Type without
mounting hole
Right Angle
Type without
mounting hole
Straight Type
without
mounting hole
Straight Type
without
mounting hole
B71
■Cable ID Connector
Unit : mm
Unit : mm
B72
Part No.
HRS No.
No. of Contacts
A
B
C
D
HIF6-020D-1.27R(20)
630-0001-4 20
11.43
13.95
16.35
HIF6-026D-1.27R(20)
630-0002-7 20
26
22.36
15.24
17.76
20.16
HIF6-032D-1.27R(20)
630-0003-0 20
32
26.17
19.05
21.57
23.97
HIF6-034D-1.27R(20)
630-0004-2 20
34
27.44
20.32
22.84
25.24
HIF6-040D-1.27R(20)
630-0005-5 20
40
31.25
24.13
26.65
29.05
HIF6-050D-1.27R(20)
630-0006-8 20
50
37.60
30.48
33.00
35.40
HIF6-052D-1.27R(20)
630-0007-0 20
52
38.87
31.75
34.27
36.67
HIF6-060D-1.27R(20)
630-0008-3 20
60
43.95
36.83
39.35
41.75
HIF6-068D-1.27R(20)
630-0009-6 20
68
49.03
41.91
44.43
46.83
HIF6-080D-1.27R(20)
630-0010-5 20
80
56.65
49.53
52.05
54.45
HIF6-100D-1.27R(20)
630-0011-8 20
100
69.35
62.23
64.75
67.15
RoHS
YES
■Pin Header Right Angle Type with lock
Unit : mm
n=
Number of Contacts
2
Note : Size F indicates the state where the lock is open.
BPCB mounting pattern
● Indicate
Mating Side
mark position.
Mating Side
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
F
HIF6-020PA-1.27DS(71)
630-0051-2 71
11.43
24.55
18.75
21.59
43.55
HIF6-026PA-1.27DS(71)
630-0052-5 71
26
34.76
15.24
28.36
22.56
25.40
47.36
HIF6-032PA-1.27DS(71)
630-0053-8 71
32
38.57
19.05
32.17
26.37
29.21
51.17
HIF6-034PA-1.27DS(71)
630-0054-0 71
34
39.84
20.32
33.44
27.64
30.48
52.44
HIF6-040PA-1.27DS(71)
630-0055-3 71
40
43.65
24.13
37.25
31.45
34.29
56.25
HIF6-050PA-1.27DS(71)
630-0056-6 71
50
50.00
30.48
43.60
37.80
40.64
62.60
HIF6-052PA-1.27DS(71)
630-0057-9 71
52
51.27
31.75
44.87
39.07
41.91
63.87
HIF6-060PA-1.27DS(71)
630-0058-1 71
60
56.35
36.83
49.95
44.15
46.99
68.95
HIF6-068PA-1.27DS(71)
630-0059-4 71
68
61.43
41.91
55.03
49.23
52.07
74.03
HIF6-080PA-1.27DS(71)
630-0060-3 71
80
69.05
49.53
62.65
56.85
59.69
81.65
HIF6-100PA-1.27DS(71)
630-0061-6 71
100
81.75
62.23
75.35
69.55
72.39
94.35
RoHS
YES
B73
■Pin Header Straight Type with lock
Unit : mm
n=
Number of Contacts
2
Guide Key Side
(20, 32, 40, 52, 60, 68, 80, 100 contacts)
Guide Key Side
● Indicate
mark position.
(26, 34, 50 contacts)
Note : Size G indicates a state where the lock is open.
Unit : mm
B74
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
F
G
HIF6-020PA-1.27DSA(71)
630-0101-9 71
11.43
24.55
18.75
14.95
21.59
43.55
HIF6-026PA-1.27DSA(71)
630-0102-1 71
26
34.76
15.24
28.36
22.56
18.76
25.40
47.36
HIF6-032PA-1.27DSA(71)
630-0103-4 71
32
38.57
19.05
32.17
26.37
22.57
29.21
51.17
HIF6-034PA-1.27DSA(71)
630-0104-7 71
34
39.84
20.32
33.44
27.64
23.84
30.48
52.44
HIF6-040PA-1.27DSA(71)
630-0105-0 71
40
43.65
24.13
37.25
31.45
27.65
34.29
56.25
HIF6-050PA-1.27DSA(71)
630-0106-2 71
50
50.00
30.48
43.60
37.80
34.00
40.64
62.60
HIF6-052PA-1.27DSA(71)
630-0107-5 71
52
51.27
31.75
44.87
39.07
35.27
41.91
63.87
HIF6-060PA-1.27DSA(71)
630-0108-8 71
60
56.35
36.83
49.95
44.15
40.35
46.99
68.95
HIF6-068PA-1.27DSA(71)
630-0109-0 71
68
61.43
41.91
55.03
49.23
45.43
52.07
74.03
HIF6-080PA-1.27DSA(71)
630-0110-0 71
80
69.05
49.53
62.65
56.85
53.05
59.69
81.65
HIF6-100PA-1.27DSA(71)
630-0111-2 71
100
81.75
62.23
75.35
69.55
65.75
72.39
94.35
RoHS
YES
■Receptacle Right Angle Type with Mounting hole
Unit : mm
n=
Number of Contacts
2
Mating Side
BApplication Pattern
(20, 32, 40, 52, 60, 68, 80 contacts)
Mating Side
Mounting hole center line
Unit : mm
No. of Contacts
A
B
C
D
E
HIF6B-20DA-1.27DS(71) 631-0051-9 71
20.95
11.43
26.67
18.55
HIF6B-26DA-1.27DS(71) 631-0052-1 71
26
34.76
24.76
15.24
30.48
22.36
HIF6B-32DA-1.27DS(71) 631-0053-4 71
32
38.57
28.57
19.05
34.29
26.17
HIF6B-34DA-1.27DS(71) 631-0054-7 71
34
39.84
29.84
20.32
35.56
27.44
HIF6B-40DA-1.27DS(71) 631-0055-0 71
40
43.65
33.65
24.13
39.37
31.25
HIF6B-50DA-1.27DS(71) 631-0056-2 71
50
50.00
40.00
30.48
45.72
37.60
HIF6B-52DA-1.27DS(71) 631-0057-5 71
52
51.27
41.27
31.75
46.99
38.87
HIF6B-60DA-1.27DS(71) 631-0058-8 71
60
56.35
46.35
36.83
52.07
43.95
HIF6B-68DA-1.27DS(71) 631-0059-0 71
68
61.43
51.43
41.91
57.15
49.03
HIF6B-80DA-1.27DS(71) 631-0060-0 71
80
69.05
59.05
49.53
64.77
56.65
Part No.
*Lock pin type is
also available.
HRS No.
RoHS
YES
B75
■Receptacle Right Angle Type Without Mounting hole
Unit : mm
n=
Mating Side
Mating Side
Unit : mm
B76
Part No.
HRS No.
No. of Contacts
A
B
C
HIF6A-20DA-1.27DS(71)
631-0001-0 71
11.43
18.55
HIF6A-26DA-1.27DS(71)
631-0002-3 71
26
24.76
15.24
22.36
HIF6A-32DA-1.27DS(71)
631-0003-6 71
32
28.57
19.05
26.17
HIF6A-34DA-1.27DS(71)
631-0004-9 71
34
29.84
20.32
27.44
HIF6A-40DA-1.27DS(71)
631-0005-1 71
40
33.65
24.13
31.25
HIF6A-50DA-1.27DS(71)
631-0006-4 71
50
40.00
30.48
37.60
HIF6A-52DA-1.27DS(71)
631-0007-7 71
52
41.27
31.75
38.87
HIF6A-60DA-1.27DS(71)
631-0008-0 71
60
46.35
36.83
43.95
HIF6A-68DA-1.27DS(71)
631-0009-2 71
68
51.43
41.91
49.03
HIF6A-80DA-1.27DS(71)
631-0010-1 71
80
59.05
49.53
56.65
RoHS
YES
Number of Contacts
2
■Receptacle Straight Type with Mounting hole
Unit : mm
n=
Number of Contacts
2
Guide Key Side
Guide Key Side
Unit : mm
No. of Contacts
A
B
C
D
HIF6B-020DA-1.27DSA(71) 631-0151-3 71
26.67
11.43
18.55
HIF6B-026DA-1.27DSA(71) 631-0152-6 71
26
34.76
30.48
15.24
22.36
HIF6B-032DA-1.27DSA(71) 631-0153-9 71
32
38.57
34.29
19.05
26.17
HIF6B-034DA-1.27DSA(71) 631-0154-1 71
34
39.84
35.56
20.32
27.44
HIF6B-040DA-1.27DSA(71) 631-0155-4 71
40
43.65
39.37
24.13
31.25
HIF6B-050DA-1.27DSA(71) 631-0156-7 71
50
50.00
45.72
30.48
37.60
HIF6B-052DA-1.27DSA(71) 631-0157-0 71
52
51.27
46.99
31.75
38.87
HIF6B-060DA-1.27DSA(71) 631-0158-2 71
60
56.35
52.07
36.83
43.95
HIF6B-068DA-1.27DSA(71) 631-0159-5 71
68
61.43
57.15
41.91
49.03
HIF6B-080DA-1.27DSA(71) 631-0160-4 71
80
69.05
64.77
49.53
56.65
HIF6B-100DA-1.27DSA(71) 631-0161-7 71
100
81.75
77.47
62.23
69.35
Part No.
*Lock pin type is
also available.
HRS No.
RoHS
YES
B77
■Receptacle Straight Type without Mounting hole
Unit : mm
n=
Guide Key Side
Guide Key Side
Unit : mm
Part No.
B78
No. of Contacts
A
B
C
HIF6A-020DA-1.27DSA(71) 631-0101-5 71
HRS No.
11.43
18.55
HIF6A-026DA-1.27DSA(71) 631-0102-8 71
26
24.76
15.24
22.36
HIF6A-032DA-1.27DSA(71) 631-0103-0 71
32
28.57
19.05
26.17
HIF6A-034DA-1.27DSA(71) 631-0104-3 71
34
29.84
20.32
27.44
HIF6A-040DA-1.27DSA(71) 631-0105-6 71
40
33.65
24.13
31.25
HIF6A-050DA-1.27DSA(71) 631-0106-9 71
50
40.00
30.48
37.60
HIF6A-052DA-1.27DSA(71) 631-0107-1 71
52
41.27
31.75
38.87
HIF6A-060DA-1.27DSA(71) 631-0108-4 71
60
46.35
36.83
43.95
HIF6A-068DA-1.27DSA(71) 631-0109-7 71
68
51.43
41.91
49.03
HIF6A-080DA-1.27DSA(71) 631-0110-6 71
80
59.05
49.53
56.65
HIF6A-100DA-1.27DSA(71) 631-0111-9 71
100
71.75
62.23
69.35
RoHS
YES
Number of Contacts
2
■Pin Header Right Angle Type with Mounting hole
Unit : mm
n=
Number of Contacts
2
Mating Side
Mating Side
Unit : mm
No. of Contacts
A
B
C
D
E
HIF6B-020PA-1.27DS(71) 631-0251-8 71
20.95
18.75
11.43
26.67
HIF6B-026PA-1.27DS(71) 631-0252-0 71
26
34.76
24.76
22.56
15.24
30.48
HIF6B-032PA-1.27DS(71) 631-0253-3 71
32
38.57
28.57
26.37
19.05
34.29
HIF6B-034PA-1.27DS(71) 631-0254-6 71
34
39.84
29.84
27.64
20.32
35.56
HIF6B-040PA-1.27DS(71) 631-0255-9 71
40
43.65
33.65
31.45
24.13
39.37
HIF6B-050PA-1.27DS(71) 631-0256-1 71
50
50.00
40.00
37.80
30.48
45.72
HIF6B-052PA-1.27DS(71) 631-0257-4 71
52
51.27
41.27
39.07
31.75
46.99
HIF6B-060PA-1.27DS(71) 631-0258-7 71
60
56.35
46.35
44.15
36.83
52.07
HIF6B-068PA-1.27DS(71) 631-0259-0 71
68
61.43
51.43
49.23
41.91
57.15
HIF6B-080PA-1.27DS(71) 631-0260-9 71
80
69.05
59.05
56.85
49.53
64.77
HIF6B-100PA-1.27DS(71) 631-0261-1 71
100
81.75
71.75
69.55
62.23
77.47
Part No.
πLock pin type is
also available.
HRS No.
RoHS
YES
B79
■Pin Header Right Angle Type Without Mounting hole
Unit : mm
n=
Mating Side
Mating Side
Unit : mm
Part No.
B80
No. of Contacts
A
B
C
HIF6A-020PA-1.27DS(71) 631-0201-0 71
HRS No.
18.75
11.43
HIF6A-026PA-1.27DS(71) 631-0202-2 71
26
24.76
22.56
15.24
HIF6A-032PA-1.27DS(71) 631-0203-5 71
32
28.57
26.37
19.05
HIF6A-034PA-1.27DS(71) 631-0204-8 71
34
29.84
27.64
20.32
HIF6A-040PA-1.27DS(71) 631-0205-0 71
40
33.65
31.45
24.13
HIF6A-050PA-1.27DS(71) 631-0206-3 71
50
40.00
37.80
30.48
HIF6A-052PA-1.27DS(71) 631-0207-6 71
52
41.27
39.07
31.75
HIF6A-060PA-1.27DS(71) 631-0208-9 71
60
46.35
44.15
36.83
HIF6A-068PA-1.27DS(71) 631-0209-1 71
68
51.43
49.23
41.91
HIF6A-080PA-1.27DS(71) 631-0210-0 71
80
59.05
56.85
49.53
HIF6A-100PA-1.27DS(71) 631-0211-3 71
100
71.75
69.55
62.23
RoHS
YES
Number of Contacts
2
■Pin Header Straight Type with Mounting hole
Unit : mm
n=
Number of Contacts
2
Guide Key Side
Guide Key Side
Unit : mm
No. of Contacts
A
B
C
D
E
HIF6B-020PA-1.27DSA(71) 631-0351-2 71
26.67
20.95
11.43
18.75
HIF6B-026PA-1.27DSA(71) 631-0352-5 71
26
34.76
30.48
24.76
15.24
22.56
HIF6B-032PA-1.27DSA(71) 631-0353-8 71
32
38.57
34.29
28.57
19.05
26.37
HIF6B-034PA-1.27DSA(71) 631-0354-0 71
34
39.84
35.56
29.84
20.32
27.64
HIF6B-040PA-1.27DSA(71) 631-0355-3 71
40
43.65
39.37
33.65
24.13
31.45
HIF6B-050PA-1.27DSA(71) 631-0356-6 71
50
50.00
45.72
40.00
30.48
37.80
HIF6B-052PA-1.27DSA(71) 631-0357-9 71
52
51.27
46.99
41.27
31.75
39.07
HIF6B-060PA-1.27DSA(71) 631-0358-1 71
60
56.35
52.07
46.35
36.83
44.15
HIF6B-068PA-1.27DSA(71) 631-0359-4 71
68
61.43
57.15
51.43
41.91
49.23
HIF6B-080PA-1.27DSA(71) 631-0360-3 71
80
69.05
64.77
59.05
49.53
56.85
HIF6B-100PA-1.27DSA(71) 631-0361-6 71
100
81.75
77.47
71.75
62.23
69.55
Part No.
*Lock pin type is
also available.
HRS No.
RoHS
YES
B81
■Pin Header Straight Type Without Mounting hole
Unit : mm
n=
Guide Key Side
Guide Key Side
Unit : mm
Part No.
B82
No. of Contacts
A
B
C
HIF6A-020PA-1.27DSA(71) 631-0301-4 71
HRS No.
11.43
18.75
HIF6A-026PA-1.27DSA(71) 631-0302-7 71
26
24.76
15.24
22.56
HIF6A-032PA-1.27DSA(71) 631-0303-0 71
32
28.57
19.05
26.37
HIF6A-034PA-1.27DSA(71) 631-0304-2 71
34
29.84
20.32
27.64
HIF6A-040PA-1.27DSA(71) 631-0305-5 71
40
33.65
24.13
31.45
HIF6A-050PA-1.27DSA(71) 631-0306-8 71
50
40.00
30.48
37.80
HIF6A-052PA-1.27DSA(71) 631-0307-0 71
52
41.27
31.75
39.07
HIF6A-060PA-1.27DSA(71) 631-0308-3 71
60
46.35
36.83
44.15
HIF6A-068PA-1.27DSA(71) 631-0309-6 71
68
51.43
41.91
49.23
HIF6A-080PA-1.27DSA(71) 631-0310-5 71
80
59.05
49.53
56.85
HIF6A-100PA-1.27DSA(71) 631-0311-8 71
100
71.75
62.23
69.55
RoHS
YES
Number of Contacts
2
BConnection Circuit
n=
Connection of Cable 1
A1
2
B2
bn
1
1
bn
B1
an
an
A2
Number of Contacts
Connection of Cable 2
An
a1
Bn
b1
Type A, A
A1
b1
B1
a1
A2
b2
B2
a2
Type A, B
An
bn
Bn
an
B83
BConnection Circuit
(26, 40, 50 contacts)
n=
Type A, B
A1
B2
bn
1
1
bn
B1
an
an
A2
An
a1
Bn
b1
Type A, A
B84
A2
b2
B2
a2
a1
B1
b1
A1
An
bn
Bn
an
Number of Contacts
2
BConnection Jig
●Guide Plate
●Hi-Flex Connection Press
Hi-Flex Connection Press HHP502
550 - 0082 - 2
HIF 6 - GPA
550 - 0165 - 8
*Pressing Block
Part No.
HRS No.
Pressing Block A-01
550-0133-1
●Cable Cutter
●Instruction Manual for HIF6 Connection Service Method
HIF6 Cable Cutter-FC601
14 Pages
550 - 0166 - 0
B85
■HIF6 Series: Connection Type Coupled Connector
HIF3B Series (MIL-C-83503)
●Compliant with the MIL standard
●The VA idea is reflected on both pin header and socket.
●Products with pull-out tab are available.
●Countermeasures are taken against noises in combination with the applicable cover case.
●The type aligned in single-row, low profile type, is available for pin header locking
system, in addition to standard products.
Number of contacts: 6, 10, 14, 16, 20, 26, 30, 34, 40, 50, 60, 64
HIF2 Series (Board direct mount type)
12-row parallel type (HIF2E)
Number of contacts: 10, 14, 16, 20, 26, 30, 34, 40, 50, 60
2.54mm grid alignment facilitates to the design pattern.
24-row staggered type (HIF2C)
Mounting height is 4.9mm low profile type.
1
HIF5 Series (Card edge ribbon type)
●Three types of full hole, semi-hole and no mount area are provided for the unit mount area.
●Connectors are connected in the bus line system.
●Cables can be returned within the connector mold width.
Number of contacts: 20, 26, 34, 40, 50, 60
FD Series (D sub-ribbon connector)
●The standard pitch 1.27mm ribbon cable can be insulated and displaced by replacing a
jig, in addition to the same pitch 1.38mm as for the D sub connector.
●The space saving type allows to reduce the thickness on the connection side according
to set miniaturization.
●Connectors can be installed from both front and rear sides of the chassis or panel.
Number of contacts: 9, 15, 25, 37
B86
2
