RC0603JR-0710RP
RC0603JR-0710RP
    YAGEO(国巨)
    贴片电阻 0603 10Ω ±5% 1/10W ±300ppm/℃
RC0603JR-0710RP 数据手册
DATA SHEET LEAD FREE CHIP RESISTORS RC_P series ±0.5%, ±1%, ±5% Product specification – September 5, 2018 V.0 Sizes 0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with made by thick film process. APPLICATIONS  All general purpose application RC_P SERIES 2 8 0201 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX P (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Total lead free without RoHS exemption  Halogen Free Epoxy  Reducing environmentally hazardous wastes  High component and equipment reliability (2) TOLERANCE  Saving of PCB space (4) TEMPERATURE COEFFICIENT OF RESISTANCE D = ± 0.5% F = ± 1.0% J = ± 5.0% ( for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 13 =13 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point. Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter P is lead free (without RoHS exemption) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩ with ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KP. www.yageo.com Sep. 05, 2018 V.1 Product specification Chip Resistor Surface Mount RC_P SERIES 3 8 0201 to 2512 MARKING RC0201 / RC0402 No Marking Fig. 1 RC0603 03 Fig. 2 E24 series: 3 digits, 5% First two digits for significant figure and 3rd digit for number of zeros Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC1218 / RC2010 / RC2512 00 Fig. 3 Value = 10 KΩ E24/E96 series: 4 digits, 1%, 0.5% First three digits for significant figure and 4th digit for number of zeros Note For further marking information, please see special data sheet "Chip resistors marking". CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added, as shown in Fig.4. Outlines For dimensions, please refer to Table 1 Fig. 4 Chip resistor outlines www.yageo.com Sep. 05, 2018 V.1 Product specification Chip Resistor Surface Mount SERIES RC_P 4 8 0201 to 2512 DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS RESISTANCE RANGE TYPE Fig. 4 Chip resistor outlines RC0201 Operating Max. Temperature Working Range Voltage -55 °C to +125 °C RC0402 1Ω≤R≤10Ω: -100~+500ppm/℃ 10Ω
RC0603JR-0710RP 价格&库存
很抱歉,暂时无法提供与“RC0603JR-0710RP”相匹配的价格&库存,您可以联系我们找货
RC0603JR-0710RP
    • 1+1.41050
    • 100+0.86320
    • 1000+0.55420
    • 2500+0.35520
    • 5000+0.25290
    库存:35
    RC0603JR-0710RP
    • 5000+0.059415000+0.00772
    • 10000+0.0532210000+0.00691
    • 15000+0.0502015000+0.00652
    • 25000+0.0469425000+0.00610
    • 35000+0.0450835000+0.00586
    • 50000+0.0433250000+0.00563
    库存:514
    RC0603JR-0710RP
      RC0603JR-0710RP
      • 1+0.884041+0.11477
      • 10+0.2993010+0.03886
      • 25+0.2253825+0.02926
      • 50+0.1832050+0.02379
      • 100+0.15061100+0.01956
      • 250+0.11840250+0.01537
      • 500+0.10006500+0.01299
      • 1000+0.085701000+0.01113
      库存:514
