581-01-24-011
581-01-24-011
    CINCH
    MODICEME-MX24POSITION
581-01-24-011 数据手册
8 6 7 4 5 3 1 2 DRAWING REVISIONS (RELEASE DATE ON FILE) 4.54 [115.3] D TERMINAL POSITION1 TERMINAL POSITION 6 REV DOCUMENT APP APPROVAL DATE A INITIAL RELEASE KR 7/28/14 TERMINAL POSITION 1 T D TERMINAL POSITION 6 1.61 [40.9] TERMINAL POSITION 7 SEE NOTE 6. C T TERMINAL POSITION 7 TERMINAL POSITION 12 .13 [3.3] TYP. TERMINAL POSITION 12 SECTION T-T SEE NOTE 5 C NOTES: .52 [13.2] TYP. 1. DIMENSIONS ARE IN INCHES EXCEPT DIMENSIONS INSIDE [XX] ARE IN mm. ALL DIMENSIONS ARE FOR REFERENCE ONLY. .25 [6.35] TYP. .25 [6.35] 2. MATERIALS: HEADER INSULATOR: 30% GLASS FILLED POLYMER, COLOR BLACK. TERMINAL BLADES: 1.5mm BRASS WITH TIN OVER NICKEL PLATING. 3. HEADERS ARE REFLOW OR WAVE SOLDERING PROCESS ROHS COMPLIANT. 4. SEE SHEET 2 FOR PCB DETAILS. .138 [3.5] TYP. .138 [3.5] TYP. .625 [15.88] B 5. RIGHT SIDE MATES WITH MOLEX FEMALE CONNECTOR PART NUMBER 33472-1201 (COLOR BLACK). .157 [4.0] TYP. .625 [15.88] 6. LEFT SIDE MATES WITH MOLEX FEMALE CONNECTOR PART NUMBER 33472-1202 (COLOR GRAY). B 4.96 [126.0] TYP. MODELED BY: K. ROSBOROUGH UNITS PRO/E ENGLISH INCHES DO NOT SCALE DRAWING UNLESS OTHERWISE SPECIFIED: ALL DIMENSIONS ARE IN INCHES A FILLET/RADII .02 MAX. DESIGN ENGINEER K. ROSBOROUGH 6 5 4 MODICE ME-MX 24 POSITION ASSEMBLY 07/11/14 CONTROL SPEC NUMBER NOTED APPROVALS ON FILE THIS DOCUMENT IS THE PROPERTY OF CINCH. NEITHER THIS DOCUMENT NOR ANY OF THE INFORMATION CONTAINED IN IT MAY BE DUPLICATED OR DISCLOSED WITHOUT PRIOR WRITTEN CONSENT OF CINCH. ©COPYRIGHT 2012 CINCH 7 1700 FINLEY RD LOMBARD, IL. 60148 TITLE MATERIAL TOLERANCES .X ± .1 .XX ± .01 .XXX ± .005 ANGULAR ± .5 ° CONFIDENTIAL 8 DATE MATERIAL SPEC NUMBER PROJECT NUMBER A15123 CAD FILE NUMBER DRAWING NUMBER 5810124011S CAGE IDENT NO. SIZE 71785 3 FINISH 2 B SCALE 581 01 24 011 S 1:1 SHEET 1 OF 2 1 A 8 7 5 6 3 4 PCB TOP SIDE 24X .010 E F G D 1.675 [42.54] CL SYMETRICAL .120 [3.05] SEE NOTE 4 .475 [12.07] .990 [25.15] E .625 [15.88] TYP. .318 [8.08]TYP. .134 [3.4] .157 [4.0] TYP. .280 [7.11] .990 [25.15] .062 [1.57] SEE NOTE 1 .138 [3.5] TYP. .610 [15.5] C .475 [12.07] .990 [25.15] .020 E F G .138 [3.5] TYP. D G CL SYMETRICAL .990 [25.15] 1 PCB BOTTOM SIDE G .05 [1.27] 2 12 7 12 7 6 1 6 1 .610 [15.5] .610 [15.5] .610 [15.5] 1 1 2 2 2 TERMINAL POSITION NUMBER 4.242±.015 [107.75±0.38] C F F 3.400 [86.36] 1 1 1 1 2 3.400 [86.36] 3.400 [86.36] 3.400 [86.36] B B 1 .360 [9.14] .060 [1.52] .175 [4.45] UNITS ENGLISH INCHES 3.350±.010 [85.1±0.25] UNLESS OTHERWISE SPECIFIED: ALL DIMENSIONS ARE IN INCHES 2. AREAS INDICATED BY 1 ARE COMPONENT AND TRACE KEEP OUT AREAS. 3. AREAS INDICATED BY 2 ARE COMPONENT KEEP OUT AREAS. FILLET/RADII .02 MAX. 6 5 4 THIS DOCUMENT IS THE PROPERTY OF CINCH. NEITHER THIS DOCUMENT NOR ANY OF THE INFORMATION CONTAINED IN IT MAY BE DUPLICATED OR DISCLOSED WITHOUT PRIOR WRITTEN CONSENT OF CINCH. ©COPYRIGHT 2012 CINCH 3 MODICE ME-MX 24 POSITION ASSEMBLY TITLE TOLERANCES .X ± .1 .XX ± .01 .XXX ± .005 ANGULAR ± .5 ° CONFIDENTIAL 4. SUGGESTED SCREW TO SECURE PCB TO HEADER: #4 THREAD CUTTING SCREW (TYPE 23 OR SIMILAR) TORQUED TO 2-3 IN-LBS [0.23-0.34 N-m]. 7 1700 FINLEY RD LOMBARD, IL. 60148 DO NOT SCALE DRAWING 1. SUGGESTED PCB THICKNESS .062 [1.57]. 8 .175 [4.45] .175 [4.45] .175 [4.45] PCB NOTES: A 2X 0.12 [3.0] X 45° CHAMFER PRO/E DRAWING CAD FILE NUMBER DRAWING NUMBER 5810124011S CAGE IDENT NO. SIZE 71785 2 B SCALE REV 581 01 24 011 S A 1:1 SHEET 2 OF 2 1
581-01-24-011 价格&库存
很抱歉,暂时无法提供与“581-01-24-011”相匹配的价格&库存,您可以联系我们找货
