8
6
7
4
5
3
1
2
DRAWING REVISIONS
4.54 [115.3]
TERMINAL
POSITION 1
T
TERMINAL
POSITION 10
TERMINAL
POSITION 1
(RELEASE DATE ON FILE)
D
REV
DOCUMENT
APP
APPROVAL
DATE
A
INITIAL RELEASE
KR
7/28/14
TERMINAL
POSITION 6
D
.13 [3.3] TYP.
1.61 [40.9]
TERMINAL
POSITION 12
C
SECTION T-T
T
TERMINAL
POSITION 11
TERMINAL
POSITION 20
TERMINAL
POSITION 7
SEE NOTE 6
SEE NOTE 5
C
NOTES:
1. DIMENSIONS ARE IN INCHES EXCEPT DIMENSIONS INSIDE [XX] ARE IN mm.
ALL DIMENSIONS ARE FOR REFERENCE ONLY.
.52 [13.2] TYP.
2. MATERIALS:
HEADER INSULATON: 30% GLASS FILLED POLYMER, COLOR BLACK.
TERMINALS BLADES: 1.5 mm BRASS WITH TIN OVER NICKEL PLATING.
.25 [6.35] TYP.
3. HEADERS ARE REFLOW OR WAVE SOLDERING PROCESS ROHS COMPLIANT.
4. SEE SHEET 2 FOR PCB DETAILS.
5. RIGHT SIDE MATES WITH MOLEX FEMALE CONNECTOR PART NUMBER 33472-1201 (COLOR BLACK).
.25 [6.35]
.138 [3.5] TYP.
B
6. LEFT SIDE MATES WITH MOLEX FEMALE CONNECTOR PART NUMBER 33472-2002 (COLOR GRAY).
.157[4.0] TYP.
.625 [15.88]
.35 [8.9]
.138 [3.5] TYP.
B
4.96 [126.0] TYP.
MODELED BY:
K. ROSBOROUGH
UNITS
PRO/E
ENGLISH INCHES
DO NOT SCALE DRAWING
UNLESS OTHERWISE SPECIFIED:
ALL DIMENSIONS ARE IN INCHES
A
FILLET/RADII
.02 MAX.
DESIGN ENGINEER
K. ROSBOOUGH
6
5
4
MODICE ME-MX
32 POSITION ASSEMBLY
07/14/14
CONTROL SPEC NUMBER
NOTED
APPROVALS
ON FILE
THIS DOCUMENT IS THE PROPERTY OF CINCH.
NEITHER THIS DOCUMENT NOR ANY OF
THE INFORMATION CONTAINED IN IT MAY
BE DUPLICATED OR DISCLOSED WITHOUT
PRIOR WRITTEN CONSENT OF CINCH.
©COPYRIGHT 2014 CINCH
7
1700 FINLEY RD
LOMBARD, IL. 60148
TITLE
MATERIAL
TOLERANCES
.X ± .1
.XX ± .01
.XXX ± .005
ANGULAR ± .5 °
CONFIDENTIAL
8
DATE
MATERIAL SPEC NUMBER
PROJECT NUMBER
A15123
CAD FILE NUMBER
DRAWING NUMBER
5810132011S
CAGE IDENT NO. SIZE
71785
3
FINISH
2
B
SCALE
581 01 32 011 S
1:1
SHEET 1 OF 2
1
A
8
7
5
6
3
4
PCB TOP SIDE
2
1
PCB BOTTOM SIDE
G
D
.280 [7.11]
.215 [5.46]
1.675 [42.55]
.990 [25.15]
.475 [12.07]
.138 [3.5] TYP.
.625 [15.88] TYP.
32X
.138 [3.5] TYP.
.157 [4.0] TYP.
.610 [15.5]
.268 [6.8]
.134 [3.4]
12
7
6
1
C
2
.120 [3.05]
SEE NOTE 4
.020 E F G
.215 [5.46]
.475 [12.07]
.062 [1.57]
SEE NOTE 1
11
10
1
.610 [15.5]
.610 [15.5]
F
.610 [15.5]
2
2
C
2
1
TERMINAL
POSITION
NUMBER
4.242±.015
[107.75±0.38]
F
.990
[25.15]
.450 [11.5]
E
.010 E F G
.350 [8.89] TYP.
.318 [8.08] TYP.
.050 [1.27]
D
G
1
3.400
[86.36]
1
1
1
3.400
[86.36]
3.400
[86.36]
3.400
[86.36]
1
B
B
.360 [9.14]
.175 [4.45]
2X .12 [3.0] X 45°
CHAMFER
.060 [1.52]
.175 [4.45]
.120 [3.04]
.175 [4.45]
.175 [4.45]
3.350±.010
[85.1±0.25]
UNITS
ENGLISH INCHES
PCB NOTES:
1. SUGGESTED PCB THICKNESS .062 [1.57].
A
2. AREAS INDICATED BY
1
ARE COMPONENT AND TRACE KEEP OUT AREAS.
3. AREAS INDICATED BY
2
ARE COMPONENT KEEP OUT AREAS.
FILLET/RADII
.02 MAX.
4. SUGGESTED SCREW TO SECURE PCB TO HEADER: #4 THREAD CUTTING SCREW (TYPE 23 OR SIMILAR) TORQUED TO 2-3 IN-LBS [0.23-0.34 N-m].
8
7
1700 FINLEY RD
LOMBARD, IL. 60148
6
5
4
TOLERANCES
.X ± .1
.XX ± .01
.XXX ± .005
ANGULAR ± .5 °
CONFIDENTIAL
3
MODICE ME-MX
TITLE
PRO/E DRAWING
CAD FILE NUMBER
DRAWING NUMBER
5810132011S
CAGE IDENT NO. SIZE
71785
2
B
SCALE
REV
581 01 32 011 S A
1:1
SHEET 2 OF 2
1
很抱歉,暂时无法提供与“581-01-32-011”相匹配的价格&库存,您可以联系我们找货
