HSEC8-180-01-L-DV-A-K
    SAMTEC(申泰)
    SMD,P=0.8mm
    0.8MM P数:160P
HSEC8-180-01-L-DV-A-K 数据手册
REVISION BW HSEC8-1XXX-XX-XX-DV-X-XX DESIGNED & DIMENSIONED IN MILLIMETERS (INCHES FOR REFERENCE ONLY) DO NOT SCALE FROM THIS PRINT No OF POSITIONS (PER ROW) -10, -20, -30 (SEE FIG 1) ■-09, -13, -25, -37, -49, -40, -50, -60, -70, -80, -90, -100 (SEE FIG 2, SHT 2) (No OF POS x 0.800 [.0315]) + 4.600 [.1811] 1.126 CARD THICKNESS (SEE TABLE 9, SHT 3) -01: 1.57 [.062] CARD -03: 2.36 [.093] CARD (10-100 POS, MULTIPLES OF 10 ONLY) (-K & -TR ONLY FOR OPTION 2) (USE RHSEC8-XXX-03-DV-XX) (SEE NOTE 7 & 10) (No OF POS x 0.800 [.0315]) + 1.400[.0551] REF C 2.70 .106 REF (No OF POS -1 ) x 0.800 [.0315]±0.100 C 02 0.800±0.100 .0315±.0039 (TOL NON ACCUM) CL 60 "A" P" REF "Q" REF "A" 01 POSITION #1 INDICATOR CL OPTION 2 **-PE: PASS THROUGH (SHT 7, FIG 7) (10, 13, & 20 POS ONLY) (-A OPTION ONLY) (NOT AVAILABLE WITH ANY OTHER OPTION 2, EXCEPT -K AND/OR -TR & -FR) **-BL: BOARD LOCK (SHT 5, FIG 5) (SEE NOTE 11) (-A OPTION ONLY) **-GR: GUIDE RAILS (SHT 6, FIG 6) (10-60 POS, MULTIPLES OF 10 ONLY) (SEE NOTE 11)(-TR & -FR PACKAGING ONLY) -WT: WELD TAB (SHT 7, FIG 8) (-A OPTION ONLY) **-L: LATCHING (SHT 4, FIG 4) (13, 25, 37, & 49 POS ONLY) (SEE NOTE 11) (-A OPTION ONLY) **-L2: ECDP LATCHING (SHT 8, FIG 9) (09, 13, 25, & 49 POS ONLY) (SEE NOTE 11) (-A OPTION ONLY) -K: POLYIMIDE FILM PAD (SEE SHT 2, FIG 3) -TR: TAPE & REEL (SEE NOTE 16) (09 THRU 70 POS ONLY) -FR: FULL REEL QTY. TAPE & REEL (SEE NOTE 15) (09 THRU 70 POS ONLY) (LEAVE BLANK FOR TRAY) 59 XHSEC8X-XXX-XX-DV-XX 7.80 .307 REF PLATING SPECIFICATION -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL "T"' REF -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD TAIL) -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL OPTION 1 (LEAVE BLANK FOR NO ALIGNMENT PIN, USE XHSEC8-XXX-01-DV-LC, NOT AVAILABLE FOR CARD THICKNESS -02 & -03 SEE FIG 10, SHT 3) -A: ALIGNMENT PIN (USE XHSEC8X-XXX-XX-DV-A) ROW SPECIFICATION -DV: DOUBLE VERTICAL 1.32 .052 REF (2 PLCS) ** = AVAILABLE ONLY WITH -01 CARD THICKNESS ■ = AVAILABLE ONLY WITH END OPTIONS -BL, -WT, & -L2 SEE NOTE 12 (SOME FEATURES NOT SHOWN FOR CLARITY) C 3.60 .142 REF 1.12 .044 REF (TYP) +.004 "V"+-0.09 0.26 "V" - .010 C-188-XX-XX "W" REF (No OF POS x 0.800[.0315]) + 2.200[.0866] REF 1.50 .059 REF 2.92 .115 REF CL 3.03 .119 REF C 7.98±0.15 .314±.006 (TYP) SEE TABLE 1 C NOTES: C 0.800±0.100 .0315±.0039 (TOL NON ACCUM) C CL "Y"±0.20 "Y"±.008 SECTION "A"-"A" FIG 1 ((No OF POS -1 ) x 0.800 [.0315])±0.08 FOR POSITIONS -10, -20 & -30 1. C REPRESENTS A CRITICAL DIMENSION. HSEC8-130-01-XX-DV-A SHOWN 2. BURR ALLOWANCE: 0.04[.0015] MAX. (SOME FEATURES NOT SHOWN FOR CLARITY) 3. MINIMUM PUSHOUT FORCE: 2.2 NEWTONS. 4. ALL TAIL TO TAIL DIMENSIONS MEASURED TIP TO TIP. (SEE NOTE 12) 5. ASSEMBLIES TO BE PACKAGED IN TRAYS, UNLESS -TR IS SPECIFIED. F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW 6. NOTE DELETED. PROPRIETARY NOTE UNLESS OTHERWISE SPECIFIED, * * THIS DOCUMENT CONTAINS CONFIDENTIAL AND 7. MATING EDGE CARD THICKNESS TOLERANCE TO BE ±0.15 [.006] OF NOMINAL. DIMENSIONS ARE IN MILLIMETERS. PROPRIETARY INFORMATION AND ALL DESIGN, 8. NOTE DELETED. MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS TOLERANCES ARE: AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, 9. NOTE DELETED. DECIMALS ANGLES INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 10. MATING CARD MUST HAVE LEAD-IN. SEE SAMTEC FOOTPRINT FOR SPECIFICATIONS. OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR .X: .3 [.01] 2 520 PARK EAST BLVD, NEW ALBANY, IN 47150 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY 11. L, L2, & BL IS NOT APPLICABLE FOR GUIDE RAIL TYPE USE. GR NOT APPLICABLE FOR L, .XX: .13 [.005] PHONE: 812-944-6733 FAX: 812-948-5047 OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS L2, OR BL TYPE USE. .XXX: .051 [.0020] WRITTEN CONSENT OF SAMTEC, INC. e-Mail: info@SAMTEC.com code: 55322 12. CORNER VOIDS AT VENDOR DISCRETION, AND MAY OR MAY NOT BE PRESENT. SHEET SCALE: 2.5:1 MATERIAL: DO NOT SCALE DRAWING DESCRIPTION: 13. MEASURE DIMENSION WITH LATCH IN LOCKED, PERPENDICULAR POSITION. 0.8mm HIGH SPEED EDGE CARD ASSEMBLY INSULATOR: LCP, 14. VOID WIDTH, LOCATION, AND FREQUENCY TO BE AT VENDORS DISCRETION. COLOR: -01 CARD THICKNESS BLACK, DWG. NO. 15. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, -02 & -03 CARD THICKNESS NATURAL BASED ON OPTIONS SELECTED. CONTACT: BeCu 16. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM SHEET 1 OF 8 BY: BRATCHER 01/24/03 HSEC8-1XXX-XX-XX-DV-X-XX FIG 3 REVISION BW -K OPTION (SOME FEATURES NOT SHOWN FOR CLARITY) "R" (No OF POS x 0.800[.0315]) + 7.800[.3071] REF 2.70 .106 REF C "D" REF 02 8.11 .319 "S" "G" REF "A" REF 120 "H" 0.51 .020 K-DOT-.XXX-.XXX-.XXX "K" 01 119 4.00 .157 C "B" SPACES @ .800 = "C"±0.100 C C (No OF POS + 3) x 0.800[.0315]±0.100 ((No OF POS + 6) x 0.800[.0315]) + 0.600[.0236] REF 13.83±0.15 .545±.006 CL C [(No OF POS + 3) x 0.800[.0315] 0.100 "U" 0.13 FIG 2 IN-PROCESS ■ FOR POSITIONS ■ **-09, **-13, **-25, **-37, -40, **-49, -50, -60, -70, -80, -90, -100 HSEC8-160-01-XX-DV-A SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (SOME FEATURES NOT SHOWN FOR CLARITY) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. (** = AVAILABLE ONLY WITH -01 CARD THICKNESS) DO NOT SCALE DRAWING SHEET SCALE: 2.25:1 ■ = AVAILABLE ONLY WITH END OPTIONS -BL, -WT & -L2 F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 0.8mm HIGH SPEED EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XXX-XX-XX-DV-X-XX BY: BRATCHER 01/24/03 SHEET 2 OF 8 REVISION BW 0.635 .025 MAX C CL 3 MAX SWAY (TYP) 7.80 .307 REF C-188-XXX-X IN-PROCESS VIEW FIG 10 **NON-ALIGNMENT PIN OPTION HSEC8-130-01-XX-DV SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (** = AVAILABLE ONLY WITH -01 CARD THICKNESS) (SOME FEATURES NOT SHOWN FOR CLARITY) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DO NOT SCALE DRAWING 0.8mm HIGH SPEED EDGE CARD ASSEMBLY SHEET SCALE: 2:1 HSEC8-1XXX-XX-XX-DV-X-XX DWG. NO. BY: BRATCHER 01/24/03 SHEET 3 OF 8 REVISION BW (No OF POS x 0.80[.0315]) + 18.40[.724] REF "D" "C" RHSEC8-XXX-01-DV-XX-L "C" "D" WT-25-02-T C C-188-02-X C 2 MAX SWAY (EITHER DIRECTION) (No OF POS x 0.80[.0315]) + 14.90[.587] 1.59 .063 0.64 .025 REF 0.25 .010 REF SECTION "D"-"D" SECTION "C"-"C" FIG 4 **-L: LATCHING OPTION HSEC8-137-01-XX-DV-A-L SHOWN AVAILABLE IN -13, -25, -37 & -49 POSITIONS ONLY (NOT AVAILABLE FOR -GR TYPE USE) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) (SOME FEATURES NOT SHOWN FOR CLARITY) (** = AVAILABLE ONLY WITH -01 CARD THICKNESS) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 0.8mm HIGH SPEED EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XXX-XX-XX-DV-X-XX BY: BRATCHER 01/24/03 SHEET 4 OF 8 REVISION BW "E" REF "F" "H" "E" "E" "H" "F" C 2.1±0.40 .083±.016 1.325 .0522 RHSEC8-XXX-01-DV-XX-BL WT-25-02-T LTC-04 12.20 .480 REF 1.48 .058 0.25 .010 REF (TYP) C-188-02-X C 2 MAX SWAY (EITHER DIRECTION) "F" 0.64 .025 REF SECTION "E"-"E" SECTION "H"-"H" SECTION "F"-"F" FIG 5 **-BL: BOARD LOCK OPTION HSEC8-160-01-XX-DV-A-BL SHOWN (NOT AVAILABLE FOR -GR TYPE USE) (FOR -09, -13, -25, 37, -40, -49, -50, -60, -70, -80, -90 & -100 POSITIONS DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) (FOR -10, -20 & -30 POSITIONS DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (** = AVAILABLE ONLY WITH -01 CARD THICKNESS) (SOME FEATURES NOT SHOWN FOR CLARITY) (AVAILABLE IN ALL POSITIONS) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW C 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 0.8mm HIGH SPEED EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XXX-XX-XX-DV-X-XX BY: BRATCHER 01/24/03 SHEET 5 OF 8 REVISION BW 0.70 .027 REF 2.30 .090 REF 4.40 .173 REF "J" RHSEC8-XXX-01-DV-XX-GR 1.75 .069 REF 11.75 .463 REF C-188-02-X "J" SECTION "J"-"J" FIG 6 **-GR: GUIDE RAILS OPTION HSEC8-160-01-XX-DV-A-GR SHOWN AVAILABLE IN -10, -20, -30, -40, -50, & -60 POSITIONS ONLY (NOT AVAILABLE FOR -L; -BL TYPE USE) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) (SOME FEATURES NOT SHOWN FOR CLARITY) (** = AVAILABLE ONLY WITH -01 CARD THICKNESS) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 0.8mm HIGH SPEED EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XXX-XX-XX-DV-X-XX BY: BRATCHER 01/24/03 SHEET 6 OF 8 REVISION BW (No OF POS x 0.800 [.0315]) + 7.000 [.2756] REF CL "G" +.004 0.56+-0.09 0.30 .022 - .012 HSEC8-XX-01-DV-A-PE C C-188-01-X "G" (No OF POS X 0.80[.032]) + 4.60[.18] REF SECTION "G"-"G" FIG 7 **-PE: PASS THROUGH OPTION HSEC8-120-01-XX-DV-A-PE SHOWN AVAILABLE IN -10, *-13 & -20 POSITIONS ONLY (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (SOME FEATURES NOT SHOWN FOR CLARITY) ** = AVAILABLE ONLY WITH -01 CARD THICKNESS *-13 IS A ONE BANK PART "J" REF "L" RHSEC8-XXX-XX-DV-A-WT WT-25-02-T "L" C 1.48 .058 0.64 .025 REF SECTION "L"-"L" 0.25 .010 REF (TYP) C-188-02-X C "F" (SEE TABLE 4, SHT 5) FIG 8 -WT: WELD TAB OPTION HSEC8-160-01-XX-DV-A-WT SHOWN AVAILABLE IN ALL POSITIONS (-A OPTION REQUIRED) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) (SOME FEATURES NOT SHOWN FOR CLARITY) 2 MAX SWAY (EITHER DIRECTION) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8mm HIGH SPEED EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XXX-XX-XX-DV-X-XX BY: BRATCHER 01/24/03 SHEET 7 OF 8 REVISION BW BOTH WT'S LANCE SHOULD FACE TO OUTSIDE (No OF POS X 0.80[.031]) + 13.66 [.538] REF 'N' RHSEC8-XXX-01-DV-XX-L2 "M" WT-25-09-X 1.48 .058 C-188-02-X 2 MAX SWAY (EITHER DIRECTION) "M" 0.25 .010 REF (TYP) 0.64 .025 REF C (No OF POS X 0.80[.031]) + 8.59 [.338] C SECTION "M"-"M" (No OF POS X 0.800[.031]) + 11.090 [.4366] REF 1.50 .059 REF FIG 9 **-L2: ECDP LATCHING OPTION HSEC8-125-01-XX-DV-A-L2 SHOWN (AVAILABLE IN 9, 13, 25, & 49 POS ONLY) (NOT AVAILABLE FOR -GR TYPE USE) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) (SOME FEATURES NOT SHOWN FOR CLARITY) (** = AVAILABLE ONLY WITH -01 CARD THICKNESS) DETAIL 'N' SCALE 10 : 1 F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8mm HIGH SPEED EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XXX-XX-XX-DV-X-XX BY: BRATCHER 01/24/03 SHEET 8 OF 8
HSEC8-180-01-L-DV-A-K 价格&库存
很抱歉,暂时无法提供与“HSEC8-180-01-L-DV-A-K”相匹配的价格&库存,您可以联系我们找货
  • 1+67.956901+8.79632
  • 42+61.38602
  • 84+59.14919
  • 126+45.94581
  • 504+37.80857
  • 1008+30.17915
  • 2016+24.00064
库存:75
    • 1+91.71360
    • 10+73.11903
    • 30+59.06067
    • 100+53.94190
    库存:6
