ECA28DSCN-S288
ECA28DSCN-S288
    SULLINS
    CONN EDGECARD 56POS .125"
ECA28DSCN-S288 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2702 INITIAL RELEASE 11/13/2012 JH F F E E CONTACT IDs: 1 3 5 ... 45 47... 99 2 4 6 ... 46 48... 100 E D D D B A 2X .075 1.91 SEE NOTE 13 +0.13 +.005 9.40 .370 - 0.38 - .015 .125 3.18 C C CONTACT ID SCALE 4:1 (PINS OMITTED FOR CLARITY) .180 4.57 .030 0.76 A .297 7.54 INSERTION DEPTH .250 6.35 C .550 13.97 .205±.025 5.21±0.64 .125 3.18 B A ACCEPTS .062 [1.57] PCB A F NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING _ _A_ _DSCH-S288 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMPS 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 16. MODIFICATION: CARD EXTENDER BEND FOR .062[1.57] PCB 8 7 6 5 B SECTION A-A CUSTOMER COPY Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 11/13/2012 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 2 _ _A_ _DSC_-S288 CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD, .125 CC, HP DWG. NO. C12115 SHEET 1 OF 2 1 REV A FILE NAME: C12115, _ _A_ _DSC_-S288 8 7 4 5 6 1 2 3 F F E E D D A 2X D 2X .095 2.41 L±.015[0.38] (L= DIM 'A'+.190[4.83] ) .125 3.18 .245 6.22 C C _ _A_ _DSCB-S288 _ _A_ _DSCS-S288 2X #4-40 THREADED INSERTS C B B CUSTOMER COPY _ _A_ _DSCN-S288 _ _A_ _DSCI-S288 Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 11/13/2012 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 2 _ _A_ _DSC_-S288 CAGE CODE 54453 SCALE: 2:1.5 3 A EDGECARD, .125 CC, HP DWG. NO. C12115 SHEET 2 OF 2 1 REV A FILE NAME: C12115, _ _A_ _DSC_-S288
ECA28DSCN-S288 价格&库存
很抱歉,暂时无法提供与“ECA28DSCN-S288”相匹配的价格&库存,您可以联系我们找货
