DF13-10P-1.25DS(50)
DF13-10P-1.25DS(50)
    HRS(广濑)
    10 位 接头,有罩 连接器 0.049"(1.25mm) 通孔,直角 金
DF13-10P-1.25DS(50) 数据手册
1.25mm Pitch Miniature Crimping Connector (UL Listed) DF13 Series Right Angle Type Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Type Type Mounting Type Mounting Height(h) DIP 5.3mm SMT 5.8mm DIP 3.6mm SMT ■Features Correspond to Automatic Mounting 1. Miniature Size Secure the automatic plain area for the absorption type automatic mounting machine. Designed in the low profile at mounting height 5.8mm. (SMT mounting straight type) (For DIP type, the mounting height is to 5.3mm to the straight and 3.6mm at the right angle) Straight Type Absorption area 2. Multi-contact The double row type achieves the multi-contact up to 40 contacts, and secures 30% higher density in the mounting area, compared with the single row type. 3. Correspond to Automatic Mounting The header provides the grade with the vacuum absorption area, and secures automatic mounting by the embossed tape packaging. In addition, the tube packaging can be selected. (Fig.1) Metal fitting 4. Integral Basic Function Despite Miniature Size The header is designed in a scoop-proof box structure, and completely prevents mis-insertion. In addition, the surface mounting (SMT) header is equipped with the metal fitting to prevent solder peeling. (Fig.1) Right Angle Type Absorption area 5. UL Certifled ■Applications Note PC, mobile terminal, miniature type business equipment, and other various consumer equipment, including video camera Fig.1 2022.4 1 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Product Specifications Specification 1A/pin UL Specification 150V AC/DC Voltage rating UL 29.9V AC/DC Current rating Rating Item Operating Temperature Range : -35 to +85ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2) Operating Moisture Range : 20 to 80% (Note 3) Storage Moisture Range : 40 to 70% (Note 2) Specification Condition 1.Insulation Resistance 500Mø min. 100V DC 2.Withstanding voltage No flashover or insulation breakdown. 500V AC/1 minute 3.Contact Resistance 30mø max. 100mA 4.Vibration No electrical discontinuity of 1μs or more Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5.Humidity (Steady state) Contact resistance : 30mø max. Insulation resistance : 500Mø min. 6.Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% Contact resistance : 30mø max. Insulation resistance : 500Mø min. (-55ç : 30 minutes➝ 5 to 35ç : 10 minutes➝ 85ç : 30 minutes➝ 5 to 35ç : 10 minutes) 5 cycles Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7.Durability (Mating/un-mating) Contact resistance : 30mø max. Tin plating : 30 cycles Gold plating : 50 cycles 8.Resistance to Soldering heat No deformation of components affecting performance. Flow : 250ç for 10 seconds Manual soldering : 300ç for 3 seconds Reflow : At the recommended temperature profile Manual soldering : 300ç for 3 seconds ●UL File No. and Recognition Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. No. UL : E52653 Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Use without condensation on parts. Note 4 : Information contained in ths catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials/Finish Product Crimping Socket Crimping Contact for Socket Pin Header (Through hole) Pin Header (SMT Single row) Pin Header (SMT Double row) Part Insulator Contact Insulator Contact Insulator Contact Metal Fitting Insulator Contact Metal Fitting Material Polyamide Phosphor copper Polyamide Brass Polyamide Brass Phosphor copper Polyamide Brass Phosphor copper Finish Beige Tin plated or gold plated Beige Tin plated Beige Tin plated or gold plated Tin plated Beige Tin plated or gold plated Tin plated Remarks UL94V-0 UL94V-0 UL94V-0 UL94V-0 - RoHS2 Yes ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Connector DF13 - * S - 1.25 C q q Series Name : DF13 w e r t e Connector Type t Connection Form / Contact Style. w Number of Contacts S : Single row socket C : Crimping socket r Single row : 2 to 12, 14, 15 P : Single row pin header DSA : Straight through hole r Double row : 10, 20, 30, 40 DS : Double row socket DS : Right angle through hole DP : Double row pin header V : Straight SMT r Contact Pitch : 1.25mm H : Right angle SMT ●Contact DF13 # - 2630 SCF A q w e r q Style Symbol Blank : Standard w Applicable Cable Size 2630 : 26 to 30 AWG 3032 : 30 to 32 AWG 2 e Packaging Type SCF : Socket Contact/Reel G : Low insertion / extraction r Plating Type Blank : Tin plated A : Gold plated DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Single Row Socket Photo: Contact insertion Part No. HRS No. No. of Contacts A 536-0001-4 1.25 DF13-2S-1.25C 2 536-0002-7 2.50 DF13-3S-1.25C 3 536-0003-0 3.75 DF13-4S-1.25C 4 536-0004-2 5.00 DF13-5S-1.25C 5 536-0005-5 6.25 DF13-6S-1.25C 6 536-0006-8 7.50 DF13-7S-1.25C 7 536-0007-0 8.75 DF13-8S-1.25C 8 Note 1 : The quantity is delivered per bag (100pcs.). B Part No. HRS No. No. of Contacts 4.15 536-0008-3 DF13- 9S-1.25C 9 536-0009-6 5.40 DF13-10S-1.25C 10 6.65 536-0010-5 DF13-11S-1.25C 11 7.90 536-0011-8 DF13-12S-1.25C 12 9.15 536-0012-0 DF13-13S-1.25C 13 10.40 536-0013-3 DF13-14S-1.25C 14 11.65 536-0014-6 DF13-15S-1.25C 15 If needed, please select and order the products per bag. Unit : mm A B 10.00 12.90 11.25 14.15 12.50 15.40 13.75 16.65 15.00 17.90 16.25 19.15 17.50 20.40 ■Double Row Socket Photo: Contact insertion state Unit : mm Part No. HRS No. No. of Contacts A B DF13-10DS-1.25C 536-0550-2 10 10.40 5.00 DF13-20DS-1.25C 536-0555-6 20 16.65 11.25 DF13-30DS-1.25C(10) 536-0560-6 10 30 22.90 17.50 DF13-40DS-1.25C(10) 536-0565-0 10 40 29.15 23.75 Note : The quantity is delivered per bag (100pcs). If needed, please select and order the products per bag. 3 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Single Row Straight Pin Header (Through hole) [Specific No.] (05) : Tin plated (25) : Tin plated, tube packaging BTube Dimensions 10 5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Board Through-hole Diameter : Ø0.6±0.03 Part No. HRS No. No. of Contacts A B Tube Packaging Quantity Part No. 115 DF13-2P-1.25DSA(**) 536-0101-9 ** 2 1.25 4.15 DF13- 9P-1.25DSA(**) 89 DF13-3P-1.25DSA(**) 536-0102-1 ** 3 2.50 5.40 DF13-10P-1.25DSA(**) 72 DF13-4P-1.25DSA(**) 536-0103-4 ** 4 3.75 6.65 DF13-11P-1.25DSA(**) 61 DF13-5P-1.25DSA(**) 536-0104-7 ** 5 5.00 7.90 DF13-12P-1.25DSA(**) 52 DF13-6P-1.25DSA(**) 536-0105-0 ** 6 6.25 9.15 DF13-13P-1.25DSA(**) 46 DF13-7P-1.25DSA(**) 536-0106-2 ** 7 7.50 10.40 DF13-14P-1.25DSA(**) 41 DF13-8P-1.25DSA(**) 536-0107-5 ** 8 8.75 11.65 DF13-15P-1.25DSA(**) Note 1 : The quantity at the specific No."05" is delivered per bag (100pcs.). If needed, Note 2 : Order the tube packaging product, multiplying the tube packaging quantity. Unit: mm HRS No. No. of Contacts A B Tube Packaging Quantity 37 536-0108-8 ** 9 10.00 12.90 34 536-0109-0 ** 10 11.25 14.15 31 536-0110-0 ** 11 12.50 15.40 29 536-0111-2 ** 12 13.75 16.65 27 536-0112-5 ** 13 15.00 17.90 25 536-0113-8 ** 14 16.25 19.15 23 536-0114-0 ** 15 17.50 20.40 please select and order the products per bag. ■Single Row Right Angle Pin Header (Through hole) [Specific No.] (**), ** (25) : Tin plated tube packaging BTube Dimensions ●Board Through-hole Diameter : Ø0.6±0.03 Part No. DF13-2P-1.25DS(25) DF13-3P-1.25DS(25) DF13-4P-1.25DS(25) DF13-5P-1.25DS(25) DF13-6P-1.25DS(25) DF13-7P-1.25DS(25) DF13-8P-1.25DS(25) Note 1 : Order the 4 HRS No. No. of Contacts A B Tube Packaging Quantity Part No. 2 1.25 4.15 115 536-0151-7 25 DF13- 9P-1.25DS(25) 3 2.50 5.40 89 536-0152-0 25 DF13-10P-1.25DS(25) 4 3.75 6.65 72 536-0153-2 25 DF13-11P-1.25DS(25) 5 5.00 7.90 61 536-0154-5 25 DF13-12P-1.25DS(25) 6 6.25 9.15 52 536-0155-8 25 DF13-14P-1.25DS(25) 7 7.50 10.40 46 536-0156-0 25 DF13-15P-1.25DS(25) 8 8.75 11.65 41 536-0157-3 25 tube packaging product, multiplying the tube packaging quantity. HRS No. No. of Contacts 9 536-0158-6 25 10 536-0159-9 25 11 536-0160-8 25 12 536-0161-0 25 14 536-0163-6 25 15 536-0164-9 25 Unit : mm A B Tube Packaging Quantity 10.00 12.90 37 11.25 14.15 34 12.50 15.40 31 13.75 16.65 29 16.25 19.15 25 17.50 20.40 23 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Single Row Straight Pin Header (SMT) ■(Three-Wall/Correspond to Vacuum Absorption) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.8 BPCB mounting pattern Note 1.Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. This pin header is a three-wall type, header has sufficiently large flat areas to allow pick-up with vacuum nozzles of automatic placement equipment. [Specific No.] (**), ** (21) : Tin plated embossed tape packaging (51) : Gold plated embossed tape packaging Unit : mm Part No. HRS No. No. of Contacts A B C D E F 1.25 4.15 7.15 5.65 1.95 2.20 2 536-0401-2 ** DF13C- 2P-1.25V(**) 2.50 5.40 8.40 6.90 3.20 3.45 3 536-0402-5 ** DF13C- 3P-1.25V(**) 3.75 6.65 9.65 8.15 4.45 3.10 4 536-0403-8 ** DF13C- 4P-1.25V(**) 5.00 7.90 10.90 9.40 5.70 4.35 5 536-0404-0 ** DF13C- 5P-1.25V(**) 6.25 9.15 12.15 10.65 6.95 5.60 6 536-0405-3 ** DF13C- 6P-1.25V(**) 7.50 10.40 13.40 11.90 8.20 6.85 7 536-0406-6 ** DF13C- 7P-1.25V(**) 8.75 11.65 14.65 13.15 9.45 8.10 8 536-0407-9 ** DF13C- 8P-1.25V(**) 10.00 12.90 15.90 14.40 10.70 9.35 9 536-0408-1 ** DF13C- 9P-1.25V(**) 11.25 14.15 17.15 15.65 11.95 10.60 10 536-0409-4 ** DF13C-10P-1.25V(**) 12.50 15.40 18.40 16.90 13.20 11.85 11 536-0410-3 ** DF13C-11P-1.25V(**) 13.75 16.65 19.65 18.15 14.45 13.10 12 536-0411-6 ** DF13C-12P-1.25V(**) 16.25 19.15 22.15 20.65 16.95 15.60 14 536-0413-1 ** DF13C-14P-1.25V(**) 17.50 20.40 23.40 21.90 18.20 16.85 15 536-0414-4 ** DF13C-15P-1.25V(**) Note 1 : Please order the embossed tape packaging product according to reel number. (1000pcs/reel) Emboss Width 16 16 24 24 24 24 24 24 24 32 32 32 44 5 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Single Row Right Angle Pin Header (SMT) ■(Four-Wall/Correspond to Vacuum Absorption) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.8 BPCB mounting pattern [Specific No.] (**), ** (21) : Tin plated embossed tape packaging (51) : Gold plated embossed tape packaging Unit : mm Part No. HRS No. No. of Contacts A B C D Emboss Width 1.25 4.15 7.15 5.65 16 2 536-0301-8 ** DF13A- 2P-1.25H(**) 2.50 5.40 8.40 6.90 16 3 536-0302-0 ** DF13A- 3P-1.25H(**) 3.75 6.65 9.65 8.15 24 4 536-0303-3 ** DF13A- 4P-1.25H(**) 5.00 7.90 10.90 9.40 24 5 536-0304-6 ** DF13A- 5P-1.25H(**) 6.25 9.15 12.15 10.65 24 6 536-0305-9 ** DF13A- 6P-1.25H(**) 7.50 10.40 13.40 11.90 24 7 536-0306-1 ** DF13A- 7P-1.25H(**) 8.75 11.65 14.65 13.15 24 536-0307-4 ** 8 DF13A- 8P-1.25H(**) 10.00 12.90 15.90 14.40 24 9 536-0308-7 ** DF13A- 9P-1.25H(**) 11.25 14.15 17.15 15.65 24 10 536-0309-0 ** DF13A-10P-1.25H(**) 12.50 15.40 18.40 16.90 32 11 536-0310-9 ** DF13A-11P-1.25H(**) 13.75 16.65 19.65 18.15 32 12 536-0311-1 ** DF13A-12P-1.25H(**) 16.25 19.15 22.15 20.65 32 14 536-0313-7 ** DF13A-14P-1.25H(**) 17.50 20.40 23.40 21.90 44 15 536-0314-0 ** DF13A-15P-1.25H(**) Note 1 : Please order the embossed tape packaging product according to reel number. (1000pcs/reel) 6 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Double Row Straight Pin Header (SMT) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■(Four-Wall/Correspond to Vacuum Absorption) BPCB mounting pattern Note 1. Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. [Specific No.] (**), ** (22) : Tin plated embossed tape packaging (52) : Gold plated embossed tape packaging Unit : mm Spec No. Spec No. Emboss HRS No. No. of Contacts A B C (22) (52) Width DF13EA-10DP-1.25V(**) 536-0570-0 10 12.10 5.00 8.70 ✔ ✔ 24 DF13EA-20DP-1.25V(**) 536-0571-0 20 18.35 11.25 14.95 ✔ ✔ 32 44 44 Part No. DF13EA-30DP-1.25V(**) 536-0572-0 30 24.60 17.50 21.20 ✔ ✔ DF13EA-40DP-1.25V(**) 536-0573-0 40 30.85 23.75 27.45 – ✔ Note 1 : Please order the embossed tape packaging product according to reel number. (1000pcs/reel) Note 2 : The absorption cap is attached to the embossed tape packaging product. 7 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Crimping Contact KDF13 KDF13G 1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8 0.5 7.2 2 0.9 3.7 3.3 0.8 1.5 0.15 BApplication Pattern Through hole (Single Row Product) SMT (Double Row Product) Right Angle SMT (Single Row Product) Straight Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) 9 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) BEmbossed Carrier Tape Dimensions A−A (1.4) 3± 0 Ø370±2 B±0.1 A±0.3 Ø21±0.8 (Ø80) Product name label A A Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2±0.5 0.4±0.1 C±0.1 4±0.1 5.2±0.15 Ø1 12±0.1 A 1.75±0.1 0 Ø5.25 +0.1 2±0.1(A<44mm) 2±0.15(A≧44mm) .2 KDF13C-*P-1.25V (**) +2 D 0 (D+6)MAX A   DIRECTION OF UNREELING 0.2 A−A (1.1) 2±0.5 3± 4.1±0.15 0.3±0.1 Ø1 Ø21± (Ø80) A C±0.1 B±0.1 A±0.3 Product name label Ø330±2 2±0.1(A
DF13-10P-1.25DS(50)
物料型号:DF13系列,1.25mm间距微型压接连接器(UL认证)
器件简介: - 该连接器具有微型尺寸,SMT直插型安装高度为5.8mm,DIP型直插为5.3mm,直角为3.6mm。 - 双排类型最多可实现40个接触点,与单排类型相比,在安装面积上提高了30%的密度。 - 兼容自动化安装,具有真空吸附区域,并通过压纹带包装确保自动化安装。 - 尽管尺寸微型,但具有防误插的勺形结构,SMT类型还配备了金属配件以防止焊接剥落。
引脚分配:根据接触点数量不同,有单排和双排两种类型,单排接触点数量从2到15不等,双排接触点数量有10、20、30、40。
参数特性: - 工作温度范围:-35°C至+85°C - 存储温度范围:-10°C至+60°C - 工作湿度范围:20%至80% - 存储湿度范围:40%至70% - 电流额定值:每针1A - 电压额定值:150V AC/DC
功能详解: - 连接器设计有防误插结构,SMT类型配有金属配件以防止焊接剥落。 - 通过UL认证,具有绝缘电阻、耐电压、接触电阻、振动、湿度和温度循环等多项测试标准。
应用信息:适用于个人电脑、移动终端、微型商务设备以及其他各种消费类设备,包括视频摄像头。
封装信息: - 材料:绝缘体为聚酰胺(Polyamide),接触件为磷青铜(Phosphor copper)或黄铜(Brass),表面处理为镀锡或镀金。 - 封装类型包括直插式、直角式、SMT单排和双排。
注意事项: - 焊接温度曲线、清洗条件、手工焊接条件等有详细推荐值。 - 提供了压接工具和压接质量标准的相关文档。
DF13-10P-1.25DS(50) 价格&库存
很抱歉,暂时无法提供与“DF13-10P-1.25DS(50)”相匹配的价格&库存,您可以联系我们找货
